POV-Ray : Newsgroups : povray.newusers : Replacing a sky_sphere with a cylinder. Server Time
2 May 2026 17:52:26 EDT (-0400)
  Replacing a sky_sphere with a cylinder. (Message 1 to 8 of 8)
Subject: Replacing a sky_sphere with a cylinder.
Date: 25 Aug 2006 08:45:00
Message: <web.44eeefebc4397441fba358d80@news.povray.org>
I know this is a stupid question, but I haven't found how to change it yet
in the documentation.
At the moment, I have this:
// Create an infinite sphere around scene and allow any pigment on it
sky_sphere {
    gradient z
    color_map { [0.0 color rgb <180/255,230/255,255/255>] [1.0 color blue
0.5] }
I know how to put an image on it, that's no problem. I want it to be a
cylinder though so I can put a tiled image of a forest on it that will
repeat side by side, but not stack. I hope I'm making sense here. Can
someone help?
Subject: Re: Replacing a sky_sphere with a cylinder.
Date: 25 Aug 2006 09:20:01
Message: <web.44eef86a84f946e0c150d4c10@news.povray.org>
> sky_sphere {
>   pigment {
>     gradient z
> 0.5] }
> someone help?
This is not strictly possible, as the sky_spere has no actual dimensions,
basically if a ray misses everything else, the sky sphere is evaluted at
that ray.  Fowhat you want to do, perhaps look at either cylindrical
mapping onto the sky_sphere or using an actual cylinder, scaled large
enough for what you want it to look like.  The latter may be the best
option, as it allows you to have a sky_sphere beyond and above the forest
as well.
-tgq
Date: 25 Aug 2006 20:20:01
Message: <web.44ef934184f946e0fba358d80@news.povray.org>
> as well.
> -tgq
Can't believe I didn't think of that, thank you. It is possible to put a
cylinder in that encompasses the whole scene and the texture will be shown
on the inside?
Date: 26 Aug 2006 03:18:44
Message: <44eff5d4$1@news.povray.org>
"Ephphatha" <nomail@nomail> schreef in bericht
news:web.44ef934184f946e0fba358d80@news.povray.org...
> on the inside?
Yes.
Don't forget to make the cylinder hollow, otherwise you will get a warning,
and other things may not work, like fog.
Date: 26 Aug 2006 04:56:28
Message: <44f00cbc@news.povray.org>
  How about making it 'inverse' instead?
Date: 28 Aug 2006 08:14:00
Message: <44f2de08$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> schreef in bericht
news:44f00cbc@news.povray.org...
>> warning,
Yes, of course! Forgot about that extremely useful possibility!!!
Date: 29 Aug 2006 11:50:00
Message: <web.44f460fb84f946e01009749b0@news.povray.org>
Is 'inverse' better than 'hollow'?  Enlightenment, please.
Also, you should check out this thread in the p.general on repeating
patterns:
http://news.povray.org/povray.general/thread/%3C44e91914%241%40news.povray.org%3E/
Mike
Date: 29 Aug 2006 19:00:26
Message: <44f4c70a$1@news.povray.org>
Mike Sobers nous apporta ses lumieres en ce 29/08/2006 11:45:
>>                                                           - Warp
> Mike
Better,no, different, yes. They serve different purpose, but in some cases are
interchangeable.
Hollow make it possible to have media or fog to fill the object.
Inverse invert the interiorness of the object. What is inside the object is
considered outside of it. It was originaly created to make intersections before
the intersection was implemented. You'd do a difference of an object and the
inverse of the other.
In a scene with fog or uncontained media, an hollow object and the rest of the
scene will contain the media. The same scene but with inverse, the media/fog
will only exist inside the object.
To the world you may be one person, but to one
person you may be the world.
