POV-Ray : Newsgroups : povray.newusers : Using A GIF for a background Server Time
24 Jan 2025 08:19:02 EST (-0500)
  Using A GIF for a background (Message 1 to 8 of 8)
Subject: Using A GIF for a background
Date: 26 Jul 2006 11:30:01
Message: <web.44c78a47651c1cb2c1709b0c0@news.povray.org>
I was starting a graphic and I wanted to use a photograph that I converted
into a GIF. How is it possible to make a Gif into a background and put a
metal sphere or another object into the foreground making it look like the
GIF in the background all fits together realistically, so it looks like all
one picture. Appreciate your attention.               Brian
Subject: Re: Using A GIF for a background
Date: 26 Jul 2006 14:55:00
Message: <web.44c7ba25961009c4c1709b0c0@news.povray.org>
Help my name is stuck
Date: 27 Jul 2006 03:40:01
Message: <web.44c86ced961009c4b1b469160@news.povray.org>
The concept of a background image is not supported in Pov-Ray, but you can
create a screen (cube) and use an image_map to project a bit-mapped image
on it. Then you can place your sphere in front of it.
See 3.5.1.5.1  Specifying an Image Map
Date: 27 Jul 2006 22:06:13
Message: <44c97115$1@news.povray.org>
bri### [at] hotmailcom nous apporta ses lumieres en ce 26/07/2006 11:29:
Place a large box behind all objects in your scene.
Apply your image as an image_map. Scale it to fit. The image start as an 1*1 tile.
Give it finish{ambient 1 diffuse 0} to prevent it from catching shadows. This
makes it ignore all light in the scene and be visible.
A mathematician is a machine for converting coffee into theorems.
Date: 10 Aug 2006 14:10:00
Message: <web.44db7571961009c47d8f11470@news.povray.org>
> Alain
Thank You, Alain. How would this look typed on the POV program itself?
Please Help. I need a book named POV for dummies.
Brian
Date: 10 Aug 2006 14:35:00
Message: <web.44db7bf2961009c47d8f11470@news.povray.org>
> Alain
How does this look in the program, please?
Brian
I need a 'POV for DUMMIES' book
Message: <web.44db7c51961009c47d8f11470@news.povray.org>
> Alain
Date: 10 Aug 2006 19:28:08
Message: <44dbc108@news.povray.org>
zombiebhp2 nous apporta ses lumieres en ce 10/08/2006 14:05:
>> Alain
> Brian
Assuming that all objects are no farther that +100 units along the +z axis and
that the camera is somewhere back along the same axis and looking toward +z.
With comments:
box{<1000,1000,100><-1000,-1000,101> // a large box
	image_map{gif "your gif.gif" // place the image from 0,0 to 1,1
		translate<-0.5,-0.5,0>// center it around the z axis
		scale<2000,2000,1> // stretch it to cover the whole box.
//adjust the scale values as needed
	finish{ambient 1 // make it fully illuminated
		diffuse 0} // independent of actual illumination, don't catch shadows
Obviously, if your image is not square, you need to change the scaling factor to
equal it's original proportions.
Fundamentalism: Shit must be born again.
