POV-Ray : Newsgroups : povray.newusers : using a .jpeg as a texture Server Time
24 Jan 2025 14:49:20 EST (-0500)
  using a .jpeg as a texture (Message 1 to 7 of 7)
Subject: using a .jpeg as a texture
Date: 28 Apr 2006 02:00:07
Message: <web.4451af049f851e8316cc43700@news.povray.org>
I want to use a .jpeg format picture as a texture, how do I do it?
Subject: Re: using a .jpeg as a texture
Date: 28 Apr 2006 02:30:01
Message: <web.4451b5372b743d3e76ba2c900@news.povray.org>
If you just want to 'paint' the jpeg image onto a surface, use image_map.
But if (as I suspect) you want to sort-of 'carve' the jpeg into your object
to create a textured surface, then you want to use bump_map. In the 3.6
docs, see '3.5.1.5  Image Maps' and '3.5.2.3  Bump Maps'. Or look at the
online docs.
I know the docs are big, but you really do have to read them to know what
POV can do for you. :)
For an example of a bump_map picture I did see
http://news.povray.org/povray.binaries.images/attachment/%3Cweb.42556d981db933923d6ca37a0%40news.povray.org%3E/earthk1.
png
Check out the rest of the "Blue Marble" thread for code & other examples
that use image maps.
Date: 28 Apr 2006 03:35:01
Message: <web.4451c4262b743d3e16cc43700@news.povray.org>
> online docs.
1.
> png
Thanks for the help.I tried using an 'image map'.I put in:
plane { <0, 1, 0>, 0
  pigment { image_map {jpeg "pavement1-512x512.jpeg"}
but I get "Parse Error: cannot open JPEG file.". The jpeg is in the same
directory as the .pov file. can you help?
Date: 28 Apr 2006 04:16:35
Message: <4451cf63@news.povray.org>
maybe the file extension is jpg ...
in this case the image_map line  should be
pigment { image_map {jpeg "pavement1-512x512.jpg"}
Marc
Date: 28 Apr 2006 04:16:38
Message: <4451cf66@news.povray.org>
"mine" <nomail@nomail> wrote in message
news:web.4451c4262b743d3e16cc43700@news.povray.org...
> ... snip ...
I tried pasting your sample into a scene file and creating a jpeg of the
name you've used and it worked fine on Windows XP with POV-Ray 3.6.
A few possibilities spring to mind -
1. Your file name may not be exactly the same (l (L)instead of 1 (one),
underscore instead of hyphen, space in front of or at the end of the file
name, case difference (p vs P).)
2. Something a bit odd with the file format (incorrect conversion to JPEG,
corrupted file)
3. Something operating system specific about the name - try renaming it to
aaa.jpg and see if that works.
p.s. with the plane you defined you won't see much as the image is projected
onto the XY plane. You need <0,0,1> or to rotate the pigment through x*90.
Hope that helps.
Chris B.
Date: 28 Apr 2006 04:30:00
Message: <web.4451d1932b743d3e16cc43700@news.povray.org>
thanks for your help. I used an 'image_map'. I put this in:
But I get "Parse Error: Cannot open JPEG file.", can you help? The jpeg is
in the same directory as the .pov file. The reason is probably really
obvious, but I can't figure it out.
Date: 28 Apr 2006 04:35:01
Message: <web.4451d2cd2b743d3e16cc43700@news.povray.org>
sorry about last post, mistake. thanks for help
