POV-Ray : Newsgroups : povray.newusers : blending out texture/pigment/image_map? Server Time
2 May 2026 21:23:43 EDT (-0400)
  blending out texture/pigment/image_map? (Message 1 to 6 of 6)
Subject: blending out texture/pigment/image_map?
Date: 1 Apr 2006 17:35:01
Message: <web.442eff71e5d17a4735c7a4050@news.povray.org>
Hi all,
I want to blend out the "elevation model" an also the complete height field
so that I can see what is below the surface (with timesteps by "clock").
But I don't understand what parameter I have to use to do this.
tnx, wolfgang
This is the code I have:
height_field {
 tga "dem15v2.tga"    // my height model
 smooth
                image_map { // an overlay graphic
                facing +z, top to +Y
                png "luft5.png"
                transmit all 0.4  // some transparence so that I can see
partly below surface
                once
             rotate x*90 // align map to height_field
  finish {
     ambient 0.6 // Very dark shadows
     diffuse 0.1 // Whiten the whites
     specular 0.25
     roughness 0.4
  scale <10980,65535,10980 > // dx,dz,dy of extent in meters
  translate < 419020, 0, 279020> // west_corner, 0, south_corner
Subject: Re: blending out texture/pigment/image_map?
Date: 2 Apr 2006 01:40:00
Message: <web.442f705fa51148e635c7a4050@news.povray.org>
to make it more clear, even with "transmit all 1" I get black pixels where
the view through the topology is flat.
An example image is found here:
http://www.student.kuleuven.ac.be/~s0167070/ttqv/test.png
Wolfgang
Date: 2 Apr 2006 01:43:09
Message: <442f727d@news.povray.org>
  Have you tried global_settings { max_trace_level 10 } just to make sure
it's not a problem with that?
Date: 2 Apr 2006 03:05:01
Message: <web.442f7703a51148e635c7a4050@news.povray.org>
Hello Warp,
that did the trick! I'm using povray since yesterday so I don't know all the
hints jet.
Wolfgang
Date: 3 Apr 2006 19:49:41
Message: <4431b495$1@news.povray.org>
wollinger nous apporta ses lumieres en ce 01/04/2006 17:32:
>   finish {
>      specular 0.25
>      roughness 0.4
The values in that finish don't fit the comments.
ambient 0.6 is a prety large value, it will make the shadows very light.
diffuse 0.1 is a low value, making your pigment interact very little with your
light_source.
Usual values are more like:
finish{
	ambient 0.01 // very dark, almost black shadow
	diffuse 0.99 // virtualy all illumination comes from incident light
42.7 percent of all statistics are made up on the spot.
Date: 18 Apr 2006 17:10:00
Message: <web.44455526a51148e6b44498390@news.povray.org>
Hi Alan,
that explains a lot! I was always wondering why the location of my light
source did not change anything in the shadows. Now my light source has an
influenceon the scene!
Thank you very much
Wolfgang
