POV-Ray : Newsgroups : povray.newusers : random rotated pattern Server Time
15 Jul 2025 06:30:17 EDT (-0400)
  random rotated pattern (Message 1 to 9 of 9)
Subject: random rotated pattern
Date: 1 Apr 2006 05:50:01
Message: <web.442e5a3e4051beb335dfc7790@news.povray.org>
Hi, i'm wondering if ther's a way to render a brick pattern in which every
brick have a random rotated pattern.
Thanks
matteo
Subject: Re: random rotated pattern
Date: 1 Apr 2006 07:54:25
Message: <fQKk7HA7fnLEFwg4@econym.demon.co.uk>
I don't think you can rotate a pattern randomly for different parts of a
texture. The problem is that rotations are handled at parse time rather
than at render time, so you can't use things like functions on them.
Here's a simple brick wall with random colours on the bricks. [To see
how it works, change the "offset" to "0.5*x". The "1000.5*x" causes the
bricks of the same colour to be shifted sideways by 1000 extra steps, so
you don't see the pattern repeat.]
#version 3.6;
global_settings {assumed_gamma 1.0}
camera {location  <5,0,-10> look_at <0,0,0> angle 50}
light_source {<-30, 100, -30> color rgb 1}
plane {z,0
  // random colours
    pigment {cells
      warp {repeat y offset 1000.5*x}
      colour_map {[0 rgb <1,0.7,0.4>][1 rgb <0.8,0.3,0>]}
      scale <1,0.5,1>
  // mortar applied as a texture layer
    pigment {brick rgb 1 rgbt 1
      brick_size <1,0.5,0.5>
      mortar 0.02
It's possible to pull out the pattern as a function
#declare F = function {pattern {cells
  scale <1,0.5,1>
and then use that to control a pigment or a texture_map
pigment {function{F(x,y,z)}
but you can't use it to control a rotation_map because there's no such
thing.
Mike Williams
Gentleman of Leisure
Date: 1 Apr 2006 08:01:03
Message: <nAJqPLA2knLEFwG4@econym.demon.co.uk>
>every brick have a random rotated pattern.
It turns out I was wrong. It is possible to write a texture rotation
function pattern. Here's one that rotates a one-dimensional gradient
function.
G: is the gradient function
F: is the function that chooses a random value for each cell
H: applies F as a rotation to G.x
If you want to rotate a two dimensional texture, then you have to change
H to apply rotations to G.x and G.y
#version 3.6;
  scale <1,0.5,1>
#declare G = function {x*6}
#declare H = function {G(x*sin(F(x,y,z)*2*pi)+y*cos(F(x,y,z)*2*pi),0,0)}
plane {z,0
    pigment { function {  H(x,y,0)  }
      colour_map {[0.5 rgb 0.5][0.5 rgb 0.6]}
      mortar 0.02
Mike Williams
Date: 1 Apr 2006 09:07:22
Message: <442e891a$1@news.povray.org>
Hey now, that isn't any April Fool's trick there. Looks very useful.
Date: 1 Apr 2006 09:35:00
Message: <web.442e8f19e10db4eb35dfc7790@news.povray.org>
"Bob H" <omniverse@charter%net> wrote:
Hei, many thanks, i'll try it.
Date: 1 Apr 2006 10:00:00
Message: <web.442e94b1e10db4eb35dfc7790@news.povray.org>
But a simple macro wouldn't work?
A macro with a texture argument that returns a random rotated texture?
Or the macro will be parsed only once?
I see that your way works, but it's not so understandable for me, so it's a
little uneasy to translate it in my scene.
Date: 1 Apr 2006 10:12:28
Message: <gewLYBAThpLEFwG8@econym.demon.co.uk>
You could easily write a macro that will generate a wall brick by brick
with a a separate texture on each brick, rotated randomly, but you asked
for a random rotated pattern, so I wrote a pattern that randomly
rotates.
Mike Williams
Date: 1 Apr 2006 10:45:01
Message: <web.442e9eebe10db4eb35dfc7790@news.povray.org>
> rotates.
> Mike Williams
I'm sorry. Your pattern works perfectly ant it's the thing that I wanted.
I don't want to generate the wall brick by brick, i want a pattern that can
be used like a pattern.
The problem is that i'm a little dumb and i haven't yet understood
completely your script.
The function F returns a pattern? The x inside the F function is the
parameter passed to the function or simple warp offset indication?
I thing that F returns a numeric value instead, because of how is used in
the H function. But what is this value? A random value generated by the
cells pattern?
So this script is cell pattern dependant?
Can I use to rotate an arbitrary pattern? This is what i don't understand.
Thanksalot anyway!
Date: 1 Apr 2006 15:14:11
Message: <z7MfROAhxsLEFwXz@econym.demon.co.uk>
Any function can be used as a pattern. A pattern is just something that
returns a numerical value between 0.0 and 1.0 for any point in space. A
function is something that returns a numerical value for any point in
space. When you use a function as a pattern, it just ignores the integer
part of the numerical value.
x, y and z between them indicate a point in space. When a ray hits a
surface, POV passes the x,y,z coordinates of that point to the function
or pattern to get the value for that point. It then does things like
looking up that numerical value in a colour_map to determine the colour
at that point in space.
>cells pattern?
The cells pattern returns the same random value for all points in the
same "cell". The pattern of cells is then offset and scaled to produce
something that matches the brick pattern. The brick layer is only there
to provide the mortar.
Yes
G is the arbitrary pattern function. I chose a simple gradient, because
it's easy to see when a gradient is rotated.
I could have used, say, a granite pattern for G, like this:
#version 3.6;
  scale <1,0.5,1>
#declare G = function {pattern {granite scale 5}}
y*sin(F(x,y,z)*2*pi)-x*cos(F(x,y,z)*2*pi),0)}
plane {z,0
      colour_map {[0.25 rgb <1.0,0.7,0.4>][0.75 rgb <0.8,0.3,0>]}
      mortar 0.02
But then it wouldn't be obvious that the granite pattern was actually
being rotated. The randomness of the granite pattern means that you get
an almost identical effect if the pattern is randomly translated (which
is somewhat easier):
#version 3.6;
  scale <1,0.5,1>
#declare H = function {G(x+F(x,y,z)*100,y,z)}
plane {z,0
      mortar 0.02
Mike Williams
