POV-Ray : Newsgroups : povray.newusers : orthographic camera plus torus Server Time
2 May 2026 21:23:43 EDT (-0400)
  orthographic camera plus torus (Message 1 to 6 of 6)
Subject: orthographic camera plus torus
Date: 18 Mar 2006 19:30:00
Message: <web.441ca59e3f4984764f3a1c170@news.povray.org>
I've modeled a CSG which is made up of 2 tori and many other shapes.  When
rendered with a normal camera it looks great however when I use a
orthographic camera the tori are covered in artifacts.  I assume I need to
set a higher accuracy for the tori but how exactly do I do that?
Help,
Carl
Subject: Re: orthographic camera plus torus
Date: 19 Mar 2006 03:46:36
Message: <441d1a6c@news.povray.org>
news:web.441ca59e3f4984764f3a1c170@news.povray.org...
> Help,
> Carl
Try sturm in your torus statement
Marc
Date: 19 Mar 2006 04:15:31
Message: <441d2133$1@news.povray.org>
Is your orthographic camera really far away? If so, bring it in as close as
you can and you'll probably find that the artifacts go away.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 19 Mar 2006 13:40:01
Message: <web.441da5452bf14de167f9ddf0@news.povray.org>
> Marc
That did the trick...
Thanks,
Carl
Date: 19 Mar 2006 14:00:00
Message: <web.441da9962bf14de167f9ddf0@news.povray.org>
>  - Slime
Not really.  Here is my camera statement...
camera {orthographic location center+5*y look_at center angle 30}
Where center is the center of my CSG and with this view the object fills
most of the screen.
Here is the image I'm working on.
http://www.wwwmwww.com/TRON/LCortho.png
You see a hint of the artifacts in the front view.  They are really bad in
the top view.  The other views here look clean but that's only because I
used a lot of AA and the artifacts were rare in these views and they
averaged out.  I'll now remake this image with sturm in the torus
statements.
By the way, is trial and error the bast way to place the light sources to
bring out as much detail as possible with an image like this?  I'm also
just moving the camera from one view to the next and using the same light
sources.  Maybe that's a mistake.  It seems if I add a light source to
bring out a detail in one view it washes out a detail in another view.  Any
tips...
Thanks again,
Carl
Date: 19 Mar 2006 16:25:01
Message: <web.441dcbab2bf14de167f9ddf0@news.povray.org>
Here is the corrected image:
http://www.wwwmwww.com/TRON/LCortho2.png
Carl
