POV-Ray : Newsgroups : povray.newusers : Texture Coords Server Time
15 Jul 2025 10:37:36 EDT (-0400)
  Texture Coords (Message 1 to 5 of 5)
Subject: Texture Coords
Date: 7 Mar 2006 06:05:00
Message: <web.440d67c267fdfdab35c1f0c60@news.povray.org>
Hello,
I am new to povray and trying to import an .iv file to povray. Here I
encountered a problem with the texture coords. Simply said: they get lost.
I googled around and found a page saying that povray does not support
texture-coords yet. Is this claim correct, and if it is, is that going to
change in the near future?
Thanks in advance,
Bo
ps: english is not my native language, so my excuses for bad grammer.
Subject: Re: Texture Coords
Date: 7 Mar 2006 08:05:00
Message: <web.440d82954a82760947d10e600@news.povray.org>
"Bo" <nomail@nomail> wrote:
> Hello,
> Thanks in advance,
> Bo
Well, i've never heard of *.iv files and google couldn't help me with that
in a rush. In addition i don't know how you "imported" them to POVRay
whereas the texture coordinates get lost (how can POVRay import files?).
Maybe this is a typo and you meant *.uv files (but i never heard of those
either) but from what you wrote i guess you mean uv mapping as it is called
in POVRay and that is supported very well! Maybe you want to look up
"2.5.7 UV Mapping" in the docs.
Hope that helpes
Regards Roman
ps: english isn't my native language either and i'm not the only one in this
forum. i was told there's no need to apologize for poor grammar :D
Date: 7 Mar 2006 11:00:15
Message: <440dae0f@news.povray.org>
"Roman Reiner" <lim### [at] gmxde> wrote in message
news:web.440d82954a82760947d10e600@news.povray.org...
>> Hello,
>> lost.
>> Thanks in advance,
>> Bo
> called
> Hope that helpes
> Regards Roman
> this
Hi Bo,
I also did a google search and eventually came up with .iv files being the
format used by Inventor, which has since been superceded by OpenInventor
(which uses the same format). I've seen some references that imply that this
is related to 3D Scanning technology?
I would guess that by 'Import' you mean you've converted some .iv files into
a format that POV-Ray can use. The web site at
http://www.csit.fsu.edu/~burkardt/data/iv/iv.html describes a number of
converters. What converter have you used and what is the format of the
output you ended up with (e.g. mesh, mesh2)?
I found a definition of Inventor texture coordinate mapping at
http://vsvr.medien.fh-duesseldorf.de/~herder/tech/OpenInventor/Workshop/Texture/texture-edit.html,
but this seems to describe a few alternative mechanisms for mapping textures
to surfaces and I'm not sure which method you are interested in emulating in
POV-Ray. From quickly looking through the examples on that web page it
doesn't seem to be doing anything much that POV-Ray can't do. It just seems
to be scaling, translating and rotating image maps.
POV-Ray can scale, translate, rotate and warp image maps as well as
providing alternative map types such as spherical and cylindrical,
Are you able to describe more fully what it is you're having difficulty
doing?
Chris B.
Date: 10 Mar 2006 03:25:00
Message: <web.4411376c4a827609ec325a890@news.povray.org>
Hi there, thanks for your time.
Okay, you are right. By saying "import" I meant that I have converted a Open
Invetor File (.iv) to .pov using a converter named "ivtopov.exe". I did not
look more closely to it asuming that it works correct (maybe an error :) ).
So I have a CAD Software called VPack (www.erpa.de) using OI (Open Inventor)
libs to create .iv Files. Those images are to be printed with a fairly high
resolution on DinA3 formated pages. That is where pov-ray comes in.
But for now my textures, which are stored in uv-coords in the .iv-File (so
thats what I guess from overlooking sample files) are not being displayed
correctly. Maybe thats a problem with the converter. I will try IVCON on
that one.
I hope I explained it a little better this time.
Bo
Date: 10 Mar 2006 05:02:22
Message: <44114eae$1@news.povray.org>
"Bo" <nomail@nomail> wrote in message
news:web.4411376c4a827609ec325a890@news.povray.org...
> Open
> not
> Inventor)
> high
> that one.
> Bo
Hi Bo,
The good news is that, from what I've just read, what you are attempting
seems to be possible.
POV-Ray 3.6 (and possibly earlier versions) supports UV mapping of textures
onto mesh objects. See section 3.5.7 UV Mapping of the docs where there's an
example of the syntax. You could take a look inside the output from
'ivtopov' to see whether it specifies a mesh or mesh2 with uv mapping and to
check whether it's specifying the syntax correctly. POV-Ray supports quite a
few formats - See Bitmap-Type in section 3.5.1.5.1  "Specifying an Image
Map" of the POV-Ray documentation.
You also need to check the file generated by the converter to see how the
texture is specified. I suspect it might be an RGB image in a separate file.
If it is you could open it in a graphics editor to check that it contains
the texture you think it should contain. Also make sure it is in a format
that POV-Ray understands and obviously check the POV-Ray message stream to
make sure it's not complaining about anything to do with the file.
I found a reference at
http://www.hammerve.com/NewHome/FreeStuff/Converters/iv2pov.c++ to iv2pov (a
google of 'ivtopov' came up empty).
I notice they say "The mapping between Inventor's texture scheme (UV
mapping) and POV 3.0's is (at best) an estimate - don't expect a perfect
fit.". They also say " By the way - it does not convert any .rgb files used
by textures into the .tga format POV wants - you have to do that by hand.".
If I had to guess, I'd say that the converters you are using are generating
a texture file as a bitmap and that the texture specification in the output
file isn't being set correctly.
If you can't spot the problems I would suggest cutting and pasting a few
lines of the mesh definition and a couple of lines showing the texture
definition into a posting here to see whether anyone can spot the problem.
Hope this helps.
Chris B.
