POV-Ray : Newsgroups : povray.newusers : help me with color_map, texture_map, bump_map with image_map Server Time
15 Jul 2025 10:08:18 EDT (-0400)
  help me with color_map, texture_map, bump_map with image_map (Message 1 to 4 of 4)
Subject: help me with color_map, texture_map, bump_map with image_map
Date: 2 Feb 2006 12:25:00
Message: <web.43e23f20c23a6d944fdbe430@news.povray.org>
I will enjoy if you can help me on this little problem
In fact i don't know how to order my texture with, color_map etc..
I would like to create some kind of grid, for that i have created a template
( called test_ch.jpg) which is the looking of my grid (black & white
picture)
in my texture i would like that the color 0 (white there) will be fully
transparent, and that all other color (grey and black) will be bump with the
color 'cu_rouille.jpg' image (which is a complete image with details)..
How can i do this?
Well, i still have the possibility to compute that 2 images to create only
one, but i m still stack for assigning to the color 0 the transparency
require ...
Thanks for answering ..
Subject: Re: help me with color_map, texture_map, bump_map with image_map
Date: 2 Feb 2006 13:13:58
Message: <43e24be6@news.povray.org>
news:web.43e23f20c23a6d944fdbe430@news.povray.org...
template
> picture)
the
> How can i do this?
> require ...
You could try image_pattern which is a very usefull feature (as well as
pigment_pattern)
The following code could do the trick
#declare T_transparent= texture{pigment{color rgbt 1}}
#declare T_rouille = texture {pigment {image_map {"cu_rouille.jpg"
interpolate 4}}}
#declare T_grille= texture {
      image_pattern
            jpg   "test_ch.jpg"
      texture_map
         [0.0     T_transparent]
         [1.0     T_rouille]
//Marc
Date: 2 Feb 2006 18:04:08
Message: <43e28fe8$1@news.povray.org>
The way I read the question, might be a need to change file format type to
something using only 256 colors or having an indexed "palette" because jpeg
(or jpg) image files, being non-paletted, won't have a specific index to
replace with a texture.
Section 3.5.5.3 of the Scene Help describes material_map and that could also
be useful.
Date: 6 Feb 2006 07:15:01
Message: <web.43e73ca91fdf6da23a0167500@news.povray.org>
> template
> > picture)
> the
> > How can i do this?
> > require ...
> pigment_pattern)
> interpolate 4}}}
>       image_pattern
>             jpg   "test_ch.jpg"
>       texture_map
>          [0.0     T_transparent]
>          [1.0     T_rouille]
> //Marc
thansk , thats what i was looking for ..
thanks for your help
