POV-Ray : Newsgroups : povray.newusers : Quaternion fractals Server Time
15 Jul 2025 14:49:36 EDT (-0400)
  Quaternion fractals (Message 1 to 7 of 7)
Subject: Quaternion fractals
Date: 24 Nov 2005 13:15:01
Message: <web.43860207e9c6fbad4b57c2700@news.povray.org>
Does anyone know why POV-Ray documentation states the following?:
"Of the two, the quaternions are much better known, but one can argue that
hypercomplex numbers are more useful for our purposes, since complex valued
functions such as sin, cos, etc. can be generalized to work for
hypercomplex numbers in a uniform way."
Long ago, I took as an exercise to write a document about the way every
elementary function could be extended to Hamilton's quaternions, by
recalling my lessons of Linear Algebra and the fact that the set of complex
the sum of a diagonal and an antisymmetric one, and applying the same rule
study this matter, and even a recent thread about a bunch of macros to work
with quaternions provided trigonometric and exponential functions for them,
as well as their inverses. So why do quaternion fractals have to be
restricted to quadratic and cubic functions? I'm also wondering why there
seems to be no engine capable of rendering quaternion Mandelbrot sets...
Subject: Re: Quaternion fractals
Date: 30 Nov 2005 03:40:01
Message: <web.438d6436a6fe73e3fe3bd1460@news.povray.org>
> elementary function could be extended to Hamilton's quaternions, ....
this has been discussed before, multiple times probably. I brought up the
question myself 3.5 years ago, though the thread strangely doesn't show
when you search here for "julia quaternion", see here :
http://news.povray.org/povray.general/thread/%3C3cdb6b98%40news.povray.org%3E/
The discussion then continued in personal mails between Peter Popov and me,
and the short version is:
- the original author of the quaternion stuff seems to have disappeared from
the net
- no active member (THEN, might have changed...) of the POV-team really
understands the quaternion-relevant code well enough to try to implement
new types
- there is a bug in the quaternion rendering that nobody can fix, for the
same reasons as above
One reason might be, that the "classical" Mandelbrot sets of formulas
pow(z,n)+c should look quite boring because any 3d-cut through them
orthogonal to the real axis is just a sphere ...
Greetings
Karl
Date: 2 Dec 2005 10:31:44
Message: <439068e0@news.povray.org>
Karl Anders wrote:
 > Hi,
Hi :)
Well, now that you show me its address, I remember reading that thread
shortly after it was created, when I'd been introduced to POV-Ray for
just a few months, and couldn't access the Internet from my own computer
to start writing here...
Since them, I've read a little about quaternions, namely a page titled
"Doing Physics with Quaternions"
(http://world.std.com/~sweetser/quaternions/qindex/qindex.html), where I
learnt that approach to them as the pair composed by a real number and
real triplet, quite suitable for representing time and space. As was to
be expected, your definition for the quaternion exponential function is
identical to the one I came up with by resorting to the corresponding 4
Lagrange-Sylvester interpolation polynomial, and the same happens
regarding circular and hyperbolic trigonometric functions, as they can
be defined in terms of exponentials. I've even written several macros to
handle quaternions with all those functions and their inverses, as well
as operating with them.
And now that I remembered this issue of quaternions in POV-Ray, I
Google-searched the whole site, but couldn't find a single thread about
it, so felt nothing was left but asking again from scratch...
and me,
disappeared from
 > the net
 > new types
What a pity... But I've seen Fractal Explorer and Quat, both of which
provide a slightly wider variety of iterating functions, but they're all
defined by a finite number of quaternion sums and products, or at most,
transcendental function like the exponential, and I find this at least
curious, and a bit disappointing...
Well, I hadn't taken the care to realize that :) But of course, it
wouldn't be the case of the fractal defined by the same iteration
formula q[n+1]=f(q[n])+c as Mandelbrot's, but where you could specify an
arbitrary quaternion q[0] as the initial term, instead of just setting
it to zero, so achieving the same single quaternion degree of freedom
we've got when selecting a Julia fractal for some given function.
Regards.
Date: 3 Dec 2005 05:55:01
Message: <web.439178b4a6fe73e38d97ad310@news.povray.org>
> (http://world.std.com/~sweetser/quaternions/qindex/qindex.html), ...
interesting link, thank you. Haven't got enough time to browse it seriously
just now, too much RealLife what with christmas suddenly being so close
again, but I will try to look into it in the near future.
Well, that might give some interesting pictures, but there is mathematical
reason for "THE" Mandelbrot Set being the one with z(0) = 0; it's simply
the only one with meaning - but you probably know that, don't you ;-)
Talking about shortcomings of POV-Ray's incorporation of quaternions there
is the additional problem that you can't choose the 3d-cut you want to see
freely ( see the docs; w != 0  !!!), and that the pictures are distorted !
Last point is easily seen by depicting sqr Julia with c=0; as with complex
numbers, this defines a 4D-sphere regardless of iteration-depth, and any
"plane" 3d-cut through a 4D-sphere is a 3D-sphere ( or a point or empty ).
BUT you get ellipsoids ...
Ah well, I fear that if we say too much, we will be asked to implement that
ourselves or shut up - that has happened before to very small minorities
asking for a lot of programmer's work - and rightfully so, I fear.
Have a nice weekend
Karl
Date: 11 Dec 2005 21:55:42
Message: <439ce6ae@news.povray.org>
connectivity of Julia sets? Otherwise, I don't know its mathematical
meaning, yet I'd be all ears :)
Well, according to the docs, what POV-Ray renders is not the
3D-hyperplane section itself of the 4D Julia set, but its projection
hyperplane which had a normal with a null fourth component would be
orthogonal to the scene's space, and so would end up wholly mapped into
a single 2D plane, with no volume, and probably devoid of almost all its
neat geometric intricacies; more or less the same way a 2D picture's
projection will be squashed into a line if its support plane is
perpendicular to the image plane.
We can, nevertheless, recover a (rotated in 4D space) copy of every 3D
section by any hyperplane with a non-zero normal's fourth component
(even if it should be quite close to zero) by stretching its projection
along the proper axis; for instance like so:
#declare SliceNormal=<2,-3,-1,1>;
#declare SliceOffset=0;
#include "transforms.inc"
julia_fractal{
   <-.2,.2,0,-.3>
   quaternion
   sqr
   max_iteration 200
   precision 100
   slice SliceNormal,SliceOffset
   #declare SliceNormalProj=<SliceNormal.x,SliceNormal.y,SliceNormal.z>;
   #if(vlength(SliceNormalProj)!=0)
     Axial_Scale_Trans(SliceNormalProj,
sqrt(pow(vlength(SliceNormalProj),2)+pow(SliceNormal.t,2))/SliceNormal.t)
   pigment{rgb<0,1,0>}
If you substitute a zero quaternion Julia parameter in this code, you'll
see the result is a sphere, no matter what SliceNormal you choose,
provided its fourth component keeps far enough from zero not to
challenge calculations' accuracy.
Well, this thread was by no means intended as a demand! I was just
curious about the matter. And I'm looking forward to dive into the code
that controls 4D Julia fractal rendering as soon as I learn C++ :))
> Have a nice weekend
Regards.
Date: 13 Dec 2005 04:40:00
Message: <web.439e958ca6fe73e3b50a2e470@news.povray.org>
When using only q(m+1)=q(m)^n+c, that's the ticket. In case of other
formulae, it's a bit more complicated and I just don't have the time right
now ...
suggested reading:
Peitgen&Richter "The Beauty of Fractals", ISBN 0-387-15851-0
Chapter 3, pp 53-55
Concerning your "skewing" of the fractal, I had thought about something like
that myself, but never managed to really do it; other projects came in the
way. I always thought that would be better implemented in the POV source,
so if you get there - have fun !!
best wishes
Karl
Date: 14 Dec 2005 22:00:00
Message: <web.43a0db8da6fe73e33400d9c10@news.povray.org>
> now ...
> suggested reading:
> Chapter 3, pp 53-55
the fractal rotated onto the scene's space, rather than projected upon it,
without having to program it in SDL... Anyway, thanks for your
encouragement :)
Regards.
