POV-Ray : Newsgroups : povray.newusers : Using arrays of vectors Server Time
15 Jul 2025 21:15:34 EDT (-0400)
  Using arrays of vectors (Message 1 to 7 of 7)
Subject: Using arrays of vectors
Date: 26 Sep 2005 11:45:00
Message: <web.43381704dbe7c0a829d68ff20@news.povray.org>
I'm a new user and I'm trying to create macros for the creation of some
solid primitives.  And I was wondering how to create a SOR_Creation macro
that would create an SOR.
A very simple macro would look like that:
#macro SurfaceOfRevolution_Creation(VectorOfPoints, NbOfPoints, Texture)
sor {NbOfPoints,VectorOfPoints texture { Texture }}
The problem is that the sor function expects vectors, and not an array of
vectors.  My questions is - What's the easiest and simplest way to extract
the vectors of an array and make functions like sor work ?
Thank you very much,
David.
Subject: Re: Using arrays of vectors
Date: 26 Sep 2005 18:06:13
Message: <433870d5$1@news.povray.org>
pare03 nous apporta ses lumieres en ce 2005-09-26 11:43:
> Hi,
> #end
> David.
You need to use a loop to get each vertor. A code like:
sor{NbOfPoints,
#local Index = 0;
#while(Index < NbOfPoints - 1)
	VectorOfPoints[Index],
#local Index = Index + 1;
VectorOfPoints[Index] // No comma for last point
texture{Texture}
Quakers: Let us not fight over this shit.
Date: 26 Sep 2005 18:21:13
Message: <43387459@news.povray.org>
In most (all?) cases, it's fine to put an extra comma after the last thing
in a list.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 27 Sep 2005 02:23:52
Message: <4338e578@news.povray.org>
Alain <ele### [at] netscapenet> wrote:
> sor{NbOfPoints,
> #local Index = 0;
> #end
> texture{Texture}
  You don't need the commas at all. Besides, the number of points doesn't
need to be supplied explicitly.
  And by the way, be so kind to not to teach bad habits to beginners by
giving as example badly-indented code.
sor
    #local Amount = dimension_size(VectorOfPoints, 1);
    Amount
    #local Index = 0;
    #while(Index < Amount)
        #local Index = Index+1;
    texture { Texture }
Date: 28 Sep 2005 13:33:28
Message: <kurtzlepirate-BA70F2.19332728092005@news.povray.org>
In article <4338e578@news.povray.org>, Warp <war### [at] tagpovrayorg>
wrote:
::Alain <ele### [at] netscapenet> wrote:
::> sor{NbOfPoints,
::> #local Index = 0;
::> #while(Index < NbOfPoints - 1)
::>         VectorOfPoints[Index],
::> #local Index = Index + 1;
::> #end
::> VectorOfPoints[Index] // No comma for last point
::> texture{Texture}
::  You don't need the commas at all. Besides, the number of points doesn't
::need to be supplied explicitly.
::  And by the way, be so kind to not to teach bad habits to beginners by
::giving as example badly-indented code.
comma, no comma... documentation at
http://www.povray.org/documentation/view/3.6.1/286/ is a little a
ambiguous ! the syntax is :
SOR:
    sor
        Number_Of_Points, <Point_1>, <Point_2>, ... <Point_n>
        [ open ] [SOR_MODIFIERS...]
SOR_MODIFIER:
    sturm | OBJECT_MODIFIER
as you can see, there are comma between <Point_1> and <Point_2> and ...
but, in a simple vase exemple :
 #declare Vase = sor {
  7,
  <0.000000, 0.000000>
  <0.118143, 0.000000>
  <0.620253, 0.540084>
  <0.210970, 0.827004>
  <0.194093, 0.962025>
  <0.286920, 1.000000>
  <0.468354, 1.033755>
  open
there is NO comma... and as Warp say : no need at all !
have fun
klp
Date: 28 Sep 2005 18:22:05
Message: <433b178d$1@news.povray.org>
kurtz le pirate nous apporta ses lumieres en ce 2005-09-28 13:33:
> ::> sor{NbOfPoints,
> ::> #end
> SOR:
>     sor
> SOR_MODIFIER:
>   7,
>   open
> have fun
> klp
So, when using vectors, you don't need commas. But, if you use a simple float as a
shorthand when
the two coordinates are the same, I think that then you need the commas.
Elevators smell different to midgets
Date: 29 Sep 2005 03:25:42
Message: <433b96f6@news.povray.org>
  Yes, the documentation is a bit vague on the usage of commas as list
item separators.
  However, povray is very permissive about missing commas as long as it
is unambiguous where the limit between the items is. However, this should
be used with care.
  For example:
  #define A = array[3] { a b c };
is equal to
  #define A = array[3] { a, b, c };
and even:
  #define A = array[3] { 1 2 3 };
is equal to:
  #define A = array[3] { 1, 2, 3 };
  However, be very careful with lists like this:
  #define A = array[3] { 1 2 -3 };
because these can contain unexpected surprises.
  The optionality of commas in most places is very handy because it allows
you to create item lists in a loop without having to worry if a comma is
required/prohibited in some place.
