POV-Ray : Newsgroups : povray.newusers : Use of macros returning values Server Time
3 May 2026 02:14:16 EDT (-0400)
  Use of macros returning values (Message 1 to 7 of 7)
Subject: Use of macros returning values
Date: 7 Sep 2005 11:25:00
Message: <web.431f0609ffcf6ed9b279c3b00@news.povray.org>
I'm attempting to write a macro that looks up a value in a table, as follows
#macro __get_table_element1( tbl, e, n )
 // Macro to calculate interpolated value from table.
 #local tick = clock * 1399;
 #local ftick = floor( tick );
 #local i0 = ( ftick * n ) + e;
 #local i1 = i0 + n;
 #if ( 1399 - ftick )
  ( tbl[i1] )
 #else
  ( tbl[i0] )
When I invoke the macro, as here
 #local q10 = __get_table_element1( clip_array, 0, 6 )
for example, I get the folloiwng error:
File: fnord  Line: 141
Possible Parse Error: All #version and #declares of float, vector, and color
 require semi-colon ';' at end.
In order to get the script to work, I have to run in version 3.1 mode.
If I add a semicolon, either after the return value or at the end of the
local declaration, I get a syntax error.
I believe I've R'd TFM, but I may have missed something.
Thanx.
Subject: Re: Use of macros returning values
Date: 7 Sep 2005 12:00:21
Message: <437diPAM6wHDFwLB@econym.demon.co.uk>
Why not just add the ";"s that it's asking for. This works:
 #local i1 = i0 + n;
  ( tbl[i1] );
 #else
  ( tbl[i0] );
Mike Williams
Gentleman of Leisure
Date: 7 Sep 2005 13:08:02
Message: <431f1e72@news.povray.org>
  Because you might want to use the macro somewhere where you shouldn't
use a ";".
  The proper way is:
#macro Whatever(...)
  #if(something)
    #local Result = foo;
  #else
    #local Result = bar;
  Result
Date: 7 Sep 2005 13:09:56
Message: <431f1ee4$1@news.povray.org>
>  #local i1 = i0 + n;
>   ( tbl[i1] );
>  #else
>   ( tbl[i0] );
>  #end
> #end
Adding the ";" to the end of the declaration, as in
  #local q10 = __get_table_element1( clip_array, 0, 6 );
would be even better, because it does not break things like
  #local q10 = __get_table_element1( clip_array, 0, 6 )*100;
HTH,
Florian
Date: 7 Sep 2005 13:40:41
Message: <R1u3yCAYQyHDFwu0@econym.demon.co.uk>
An excellent solution apart from the fact that it still throws the
error.
Mike Williams
Date: 7 Sep 2005 13:45:01
Message: <web.431f2695eb77a74eb279c3b00@news.povray.org>
Thanx.  For some reason it didn't work the first time I tried it.  I
probably had something else hosed that was masking the real solution.
Date: 7 Sep 2005 18:49:50
Message: <431f6e8e$1@news.povray.org>
> error.
Ah, shame on me, I didn't test it :(
It felt right, but now I see that it needs Warp's addition to work.
Sorry for the confusion!
Florian
