POV-Ray : Newsgroups : povray.newusers : Another begineer: Server Time
16 Jul 2025 06:00:14 EDT (-0400)
  Another begineer: (Message 1 to 3 of 3)
Subject: Another begineer:
Date: 31 Jul 2005 03:25:00
Message: <web.42ec7befd63c4adb9e47bc2b0@news.povray.org>
Am new to POVRAY, but not to 3d; I draw signs which are internally lighted
and want to try POVRAY for its output, to see what images look like.  Are
there images on web, like what I do, so I can see them or perhaps study the
scripts involved?
The signs normally have plastic faces, or flexible style faces - like an
awning - and I draw awnings too; and I've got programs to try that will
interface to POVRAY, re script creation, but I wonder will I have any luck
with materials that let light pass through (the text on a sign or awning
face) and make a credible show of giving off light in the evening hours?
If any of you have general tips on the matter, I'd like to hear about
ways to approach the method.  (And I will continue reading POV's docs and
tutorials, of course).
I want to step up from my old trusty truSpace, which creates stuff that
looks like "PC graphics," if you know what I mean.
Thanks for ideas/opinions,
Best, --pat (the new kid on the block)
Subject: Re: Another begineer:
Date: 31 Jul 2005 07:00:38
Message: <42ecaf56@news.povray.org>
"Pat" <nomail@nomail> wrote in message
news:web.42ec7befd63c4adb9e47bc2b0@news.povray.org...
> the
> scripts involved?
Hiya Pat, welcome to the POV community.
Well, hmmm, can't think of any sample scenes included with POV that match
exactly what you're asking about.
You'll probably be using various amounts of filtered transparency, for one.
That's simple enough. Just use pigment colors with either rgbf
<0.1,0.2,0.3,0.4> or keyword filter 0.4. A light_source would be inside or
the backside of the sign object and shine through based on that filtered
amount. 0 = none, 1 = completely, and anything inbetween will vary the
transparency. The colors used will illuminate other objects in the path of
the light.
What you'll also need to read about is area_light, about its usefulness and
pitfalls (affects only shadows).
Since you might be mixing text with a surrounding object you'll no doubt
need separate pigments/filters for the parts, so if you understand about
putting together parts you should have an easy time applying different
textures to them.
Oh, I just thought of one thing anyway... take a look at the Insert menu,
Scene File Templates then Image Map (while a file is open in the editor). It
has filtering used on an image file. Well, okay, that's not much help unless
you use image maps, too. Maybe you'll do CSG (combining of shapes, like text
and box). Depends a lot on how you actually want to go about the
sign-making. Another possiblity is to use 'media' as a way to make the sign
glow.
Another thing before I go. You could also use radiosity and photons to get
the sign objects to illuminate their surroundings, perhaps more
realistically, but that gets tricky for a new user. Depends a lot on what
kind of environment exists around the sign. If you're idea is to show only
the sign itself, well, that'd be different, too. I'll leave you with that
thought, and hopefully not confused. I'm sleepy anyhow so that could cause
bad info.
Bob Hughes
Date: 31 Jul 2005 14:12:28
Message: <42ed148c$1@news.povray.org>
Pat nous apporta ses lumieres en ce 2005-07-31 03:21:
> scripts involved?
If you see only the sign, out of context. I'd use a box with an image_map with some
transparent
parts. Behind that, you put a box with a pigment that matches the light's colour you
want and a
finish{ambient 1 diffuse 0} to make it "glow".
It may looks something like this:
union{
	difference{//the case
		box{<10,5,1>,<-10,-5,-1>}
		box{<9.9,4.9,0.9>,<-9.9,-4.9,-0.9}
		texture{image_map{png"image.png"}}
	box{<9.9,4.9,0.8>,<-9.9,-4.9,0.88>texture{pigment{rgb 1}finish{ambient 1 diffuse 0}}}
//"light" source
In a "normal" scene it won't shed any light on nearby elements, but it will in a
radiosity scene.
