POV-Ray : Newsgroups : povray.newusers : Smooth inclined surface with hills Server Time
3 May 2026 02:14:47 EDT (-0400)
  Smooth inclined surface with hills (Message 1 to 6 of 6)
Subject: Smooth inclined surface with hills
Date: 20 Jul 2005 14:00:00
Message: <web.42de90b114fef1afa040ba090@news.povray.org>
I have a specific scene in mind. I want to create a smooth land with small
hills. From the camera, surface goes down and comes back up in the
distance.  I was'nt able to create a heightfield that can be rendered as I
wanted. Heightfield generators seem to work well for randomly created
terrains but not for specific topologies. I tried terragen and was very
unhappy with the result.
1) Is there a an easy way to paint the heightfield in any tool?
2) Isosurface seems promising but need some guidence. Isosurface tutorial
was not helpful for generating a special terrain.
Thanks in advance
Subject: Re: Smooth inclined surface with hills
Date: 20 Jul 2005 19:09:07
Message: <42ded993$1@news.povray.org>
Architect nous apporta ses lumieres en ce 2005-07-20 13:58:
> Hi,
> Thanks in advance
All in POV Ray:
You can light a plane with lights, some with negative colour. Place a spot_light where
you want the
ground to rise. Place a negative one for low parts that are still to high. You can
then add some
pigment to get some variations.
In your case, there should be a light near the wanted camera position, another for the
hill in the
distance, maybe a cylindrical parallel negative one grazing the plane for the dip.
Render as TGA and use glabal_settings{hf_grey_16). place the camera to look
perpendicular to the
plane, generaly, it's good to use an orthorgaphic camera for that kind of renders.
You now have an hight_field you can use in your scene. You need to scale it to the
actual size of
your scene (start as contained in a 1*1*1 box set one corner at the origin)
Using the windows version, enter "+ft" in the text box left to the resolutions list.
You can also
set the size of the image using +w<width> +h<hight> (-w100 -h76 for example to get a
100*76 image).
For a sample of this trick, you can look at the crater_dat.pov sample in the objects
folder. It use
3 spot_light to create a crater hight_field.
Date: 21 Jul 2005 04:29:54
Message: <42df5d02@news.povray.org>
Any paint program should allow you to produce an image that you can base the
height field on.
Date: 4 Oct 2005 15:25:01
Message: <web.4342d6979cd175b055cad30e0@news.povray.org>
> height field on.
Just create a grey-scale image (the bigger the better, so as to get some
good resolution), with tonal values that range between black (lowest
elevation) to white (highest elevation), then save it in one of the file
formats POV supports for heightfields. Note that most image editors create
8-bit images, not 16-bit.  This means that no matter how LARGE your image
map, the grey-scale values will still be "divided up" into a set number of
finite steps. That is, changing the size or resolution of the image won't
alter this min. to max. tonal value. So even with a large-size (or
high-resolution) image, you'll still probably see some "stepping" in the
vertical direction of the generated heightfield, particularly when you
scale up the HF in that direction. 16-bit images have MUCH finer grey-scale
"steps." But in my experience, even Photoshop doesn't create or edit 16-bit
images. POV -Ray itself does, strangely enough!  (See the comments made
earlier.)
Date: 4 Oct 2005 23:39:31
Message: <43434af3@news.povray.org>
Architect wrote:
> Hi,
Try planetgenesis...  http://planetgenesis.sourceforge.net/
It has a number of different noise generators and you can combine them
in different ways. Some ripples with a gradient should get what you
describe.
Check out Cinepaint http://cinepaint.sourceforge.net/
It can handle 16 bit greyscales, I use it to tweak the output from
planetgenesis, great for carving rivers and stuff...
RG
Date: 5 Oct 2005 09:20:00
Message: <web.4343d23e9cd175b09cfde9c40@news.povray.org>
> earlier.)
I'm pretty sure the whole NetPBM package can work with 16-bit .ppm images,
although some programs may not function correctly with high bit depths. See
http://netpbm.sourceforge.net/README
NetPBM is the 'home' of the .ppm family of image formats. These command-line
programs are quite stable, having been around for ages. They are very handy
for processing huge images & batch processing.
