POV-Ray : Newsgroups : povray.newusers : strange shading Server Time
16 Jul 2025 06:12:33 EDT (-0400)
  strange shading (Message 1 to 5 of 5)
Subject: strange shading
Date: 18 Jul 2005 18:15:01
Message: <web.42dc2937c2ea591bec84c21d0@news.povray.org>
Im trying to use a mesh of smooth_triangles to generate a molecular
structure. The structure generates fine, but the shading looks like its
coming from a completely different light source than the one i defined. I
defined an area light directly out from the origin (about 500 units on the
z axis), and have my camera looking at the origin and located along the z
axis just like the light, just not as far out. I assumed this would
generate shading based on the shape of the object. However, the left and
right edges are extremely bright and the center so dark the shape is almost
completely lost... I increased the ambience of my textures which helped
some, but the shape of the object is still lost at the center. I tried
adding a second light source but it just made the current result more
drastic... Am I just missing something?
Subject: Re: strange shading
Date: 18 Jul 2005 23:20:29
Message: <CQWj7AA5DH3CFwbX@econym.demon.co.uk>
Is it possible that you've calculated your normals incorrectly. For
example, if they're all pointing in the opposite direction from what
they should be, then the surface would look smooth and continuous but
the shading would be inside out.
Mike Williams
Gentleman of Leisure
Date: 19 Jul 2005 01:52:41
Message: <42dc9529@news.povray.org>
A simple example scene would help answering your question a lot...
Date: 19 Jul 2005 13:15:01
Message: <web.42dd34d0fa1fe4541068d2140@news.povray.org>
Its possible that ive calculated the normals incorrectly. Im actually
starting from a vrml file generated by a modeling program which contains
the normals. Then I use the vectors from the vrml file and write my pov.
And I know the file works correctly in the modeling program... Is there a
conversion factor or difference between vrml normals and pov normals that
im not aware of?
How would I go about posting an example scene? Im not able to post
attachments on the newsgroup so what would be the easiest way?
Thank you!
Jammin
Date: 19 Jul 2005 16:25:00
Message: <web.42dd6136fa1fe4541068d2140@news.povray.org>
Ok I figured it out. The problem WAS the normals. The modeling program i was
using is a right-handed universe, while POV is a left-handed. So i just
used a matrix to switch POV to a right handed and things suddenly worked.
Thank you for your help!!
Jammin
