POV-Ray : Newsgroups : povray.newusers : Can povray ignore errors in scene definitions? Server Time
16 Jul 2025 17:19:25 EDT (-0400)
  Can povray ignore errors in scene definitions? (Message 1 to 7 of 7)
Subject: Can povray ignore errors in scene definitions?
Date: 3 Jun 2005 15:05:01
Message: <web.42a0a991567b3ade5c43ed910@news.povray.org>
On:
cylinder {
<-1.835, 1.012, -0.3288>, <-1.835, 1.012, -0.3288>, 0.02201
I Get:
Parse Error: Degenerate cylinder, base point = apex point.
Can I tell povray to ignore such an invalid cylinder def?
Cheers,
Jurgen
Subject: Re: Can povray ignore errors in scene definitions?
Date: 3 Jun 2005 17:19:02
Message: <42a0c946$1@news.povray.org>
jfd wrote:
> On:
> cylinder {
> I Get:
> Cheers,
> Jurgen
Are you trying to make a disk (i.e. 2D cylinder)?  If so there is a disk
object, I believe it is in "shapes.inc" (search the help file for
"disk").  Otherwise, why not draw the disk as being a very, very thin
cylinder:
cylinder {
<-1.835, 1.012, -0.3287>, <-1.835, 1.012, -0.3288>, 0.0220 }
Bryan
Date: 3 Jun 2005 17:34:00
Message: <42a0ccc8$1@news.povray.org>
I don't think so. If you're generating the cylinder automatically, you'll
probably have to use an #if to avoid creating it in the degenerate case. =(
 - Slime
 [ http://www.slimeland.com/ ]
Date: 4 Jun 2005 06:17:27
Message: <kurtzlepirate-214F5C.12172504062005@news.povray.org>
In article <42a0ccc8$1@news.povray.org>, "Slime" <fak### [at] emailaddress>
>> - Slime
i agree slime but, if cylinder like this is generated automatically, i
think there are some problems into the "generator" :)))
Date: 4 Jun 2005 10:06:17
Message: <42a1b559$1@news.povray.org>
kurtz le pirate nous apporta ses lumieres en ce 2005-06-04 06:17:
>>>- Slime
In that case, POV Ray should issue a warning and continue, not stop with an error. If
you have a
degenerate triangle, you get a warning and the parsing proceed. If you get a
degenerate bounding
box, you get a warning and parsing proceed. That last one hapened to me while making a
macro.
The behaviour I expect: there is a degenerate <anything>, issue a warning, completely
ignore that
element, proceed with the rest of the scene.
Date: 7 Jun 2005 17:10:01
Message: <web.42a60cf28c14f4445c43ed910@news.povray.org>
completely ignore that
> Alain
Thanks for your reactions guys. I agree with Alain that povray could simply
proceed after a warning. I can't change the generator (molmol).
Thanks,
Jurgen
Date: 7 Jun 2005 18:45:00
Message: <web.42a622f78c14f4446a3607400@news.povray.org>
> completely ignore that element, proceed with the rest of the scene.
hmm, could we go as far as saying that there is a consistency issue? A
degenerate cylinder gives a parse error. I could imagine at least one good
reason for that: POV-Ray prevents the caps of the cylinder from being
co-incident surfaces. Now, a degenerate box (with one and only one
dimension set to 0) raises no error, no warning, and is rendered as a
rectangle with no thickness... Am i missing something?
JYR
