POV-Ray : Newsgroups : povray.newusers : Weird side-effect of wrinkles in a normal... Server Time
16 Jul 2025 17:37:57 EDT (-0400)
  Weird side-effect of wrinkles in a normal... (Message 1 to 5 of 5)
Subject: Weird side-effect of wrinkles in a normal...
Date: 8 May 2005 20:25:00
Message: <web.427ea840bc5bff406a3607400@news.povray.org>
Hi everybody!
I attempted to use "wrinkles" in a "normal" statement to give a rough finish
to the outer walls of some imaginary building. It is constructed
recursively and implies that its modules be rotated by 0, 90, 180, 270
degrees around the y-axis to take place at each corner. Now, i noticed a
slight difference in the appearance of the different modules. Investigating
further, i gathered the following minimal source to demonstrate a strange
behaviour...
#version 3.6;
global_settings {assumed_gamma 1.0}
#declare degre=3;
#declare pdd=pow(2,degre);
    location  <-.25*pdd, .85*pdd, -1.6*pdd>
    look_at   (2-pdd)*y
light_source {<-500, 260, -240> rgb 1}
#macro cell (n)
    box {-n, n}
        pigment {rgb 1}
        normal {wrinkles  scale .2}
#end //macro cell (n)
#macro pyramide (n)
    #if (n=1)
        object {cell (1)}
    #else
        union {
            #local quadrant=0;
            #while (quadrant<4)
                object {
                    pyramide (n-1)
                    translate -pow(2,n-1)/2
                    rotate quadrant*90*y
                #local quadrant=quadrant+1;
            #end //while
    #end //if
#end //macro pyramide (n)
object {pyramide (degre)}
You should see 16 distinct cubes grouped together, some of them much lighter
than the others. Yet stranger: if i set #version to 3.1, the 16 cubes
suddenly appear as one solid stone slab, as i expected them to. With
#version set to 3.2 or higher, the difference in color shows up. I tried to
change "noise_generator" to no avail.
Using POV-Ray for Windows, version 3.6.1a.icl8.win32, straight from the
official download site.
Any insight or explanation would be greatly appreciated!!!
J-Y
PS : a preview of said imaginary building is posted in p.b.i ...
Subject: Re: Weird side-effect of wrinkles in a normal...
Date: 8 May 2005 21:41:40
Message: <427ebfd4$1@news.povray.org>
lighter
to
That *is* weird. It looks like rotating the cubes is causing the normal
pattern to respond to light differently.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 9 May 2005 03:13:50
Message: <0H2e+AAb1wfCFwte@econym.demon.co.uk>
Wasn't it JYR who wrote:
>Hi everybody!
>behaviour...
I don't know why it happens, but if you're interested in a workround,
it's possible to arrange rotate the normals in the opposite direction to
the rotation of the quadrants, so that the cubes rotate but the wrinkles
don't.
#version 3.6;
#declare degre=3;
    look_at   (2-pdd)*y
#macro cell (n,Rot)
    box {-n, n}
        pigment {rgb 1}
        normal {wrinkles  scale .2 rotate -Rot*90*y}
#macro pyramide (n,Rot)
    #if (n=1)
        object {cell (1,Rot)}
    #else
        union {
            #local quadrant=0;
            #while (quadrant<4)
                object {
                    pyramide (n-1,Rot+quadrant)
            #end //while
    #end //if
object {pyramide (degre,0)}
Mike Williams
Gentleman of Leisure
Date: 9 May 2005 06:15:00
Message: <web.427f3756cae8a0092fb55320@news.povray.org>
> J-Y
No big insight, except that it might be related to the original normal
perturbation function used by wrinkles. Try substituting
pigment_pattern{wrinkles} or function{f_wrinkles(x,y,z)} (along with
functions.inc) for wrinkles. It's not a perfect solution, but at least it
is close.
Abe
Date: 9 May 2005 09:35:00
Message: <web.427f66a9cae8a0096a3607400@news.povray.org>
> is close.
> Abe
Thanks to all for your answers! Abe, "pigment_pattern{wrinkles}" works just
fine. I really didn't think of converting a pattern initially created for
normal (ditto POV-Ray manual, 3.5.11.37) into a pigment pattern to use it
in a normal. And even better: i think your workaround makes a better rough
wall finish than directly applying a "wrinkles" normal pattern.
I can now go on with my scene, but I guess that leaves the following issue
open: "is it a bug or a feature?" ;-)
J-Y
