POV-Ray : Newsgroups : povray.newusers : Textures and mesh2 objects Server Time
16 Jul 2025 17:36:03 EDT (-0400)
  Textures and mesh2 objects (Message 1 to 6 of 6)
Subject: Textures and mesh2 objects
Date: 30 Apr 2005 11:00:01
Message: <web.42739c9a41e1513486cac9ba0@news.povray.org>
Is there an easy way to texture a large (4 million+ triangle) mesh2 object
from an image file?  I'm trying to do some hi-res mars renders from
elevation data.  I can build the model, but I haven't thought of an easy to
to get the right colors onto it.  I have a .png mars texture, but it
doesn't want to play nice with the mesh2.  If someone could point me to an
example it would be much apreciated.
Subject: Re: Textures and mesh2 objects
Date: 30 Apr 2005 13:32:33
Message: <4273c131$1@news.povray.org>
povray nous apporta ses lumieres en ce 2005-04-30 10:56:
As your mesh2 is realy only a hight field, and your image probably a top-down view of
the same area.
Can you simply the image_map as on a plane? Rotate your mesh to match the plane of the
image_map,
translate the image so that both origins match.
Date: 30 Apr 2005 15:35:00
Message: <web.4273dd7df510728986cac9ba0@news.povray.org>
of the same area.
the image_map,
> Alain
actually, it's not a height field, it a mesh2 that is created using data for
the whole planet, it's basically a bumpy sphere... but I think I've thought
of a way to texture it... It's not gonna be nice, but it'll work.
Date: 1 May 2005 06:18:10
Message: <4274ace2$1@news.povray.org>
If you're building the mesh yourself, why not add uv-vectors to it? You
could then use uv-mapping to texture the mesh. See these chapters of the
documentation:
2.5.7 - UV Mapping
http://povray.org/documentation/view/3.6.1/357/
2.4.2.4 - Mesh2
http://povray.org/documentation/view/3.6.1/293/
HTH,
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
Date: 1 May 2005 10:29:24
Message: <4274e7c4$1@news.povray.org>
povray nous apporta ses lumieres en ce 2005-04-30 15:33:
of the same area.
the image_map,
>>Alain
I tough that it was only a section that could be assimilated to a bumpy plane. My bad
assumption.
OK! Then use a warp{... spherical } to map your image onto the spherical mesh. You can
adjust the
positioning using rotation. Read the documentation section: 3.5.12.6.5  Mapping using
warps
Date: 1 May 2005 13:05:01
Message: <web.42750c2ff510728986cac9ba0@news.povray.org>
of the same area.
the image_map,
> >>Alain
bad assumption.
can adjust the
using warps
> Alain
image_map with a map_type 1 works.  I didn't think to try that before for
some reason. Thanks for poiting me in the right direction.
