POV-Ray : Newsgroups : povray.newusers : Problem with the EXTRUDE Server Time
3 May 2026 04:56:25 EDT (-0400)
  Problem with the EXTRUDE (Message 1 to 4 of 4)
Subject: Problem with the EXTRUDE
Date: 25 Apr 2005 22:35:00
Message: <web.426da894f3d9b99a1362b3f50@news.povray.org>
My program is below, but something wrong happens when I replace the A(...)
with object{A(...)} as I want to translate the object {A(...)}and it shows
"Prase Error: No matching } in 'object', box found instead."  Could someone
here hele me solve the problem?(Without object{} but just with A(...) it
runs smoothly and I guess I could invoke the macro with ".inc" but don't
know how to invoke it.)
#include "textures.inc"
#include "metals.inc"
camera{
       location <0,10,-20>
       direction <0,0,1>
       up <0,1,0>
       right <4/3,0,0>
       look_at <0,0,0>
background {color rgb <0.5,0.5,0.5>}
object {light_source {<20,100,-200> colour White}}
#macro A(Angle,Radius,y_rotate,A_rotate)
#local Index=0;
#while (Index<=y_rotate/Angle)
 #local x_delta_move=-Radius*(1-cos(Angle*Index));
 #local z_delta_move=-Radius*sin(Angle*Index);
 #local y_delta_rotate=Index*Angle;
 box{<-0.4,-0.4,-0.4>,<0.4,0.4,0.4>
     translate <x_delta_move,0,z_delta_move>
     rotate y_delta_rotate*y
     pigment{colour White}
     rotate A_rotate*y
     scale 0.2}
 #local Index=Index+1;
object{A (0.01*3.14/180,100,26*3.14/180,180)}
object{A (0.01*3.14/180,100,26*3.14/180,0)}
Subject: Re: Problem with the EXTRUDE
Date: 25 Apr 2005 23:45:53
Message: <426db971$1@news.povray.org>
> camera{
>        location <0,10,-20>
>        direction <0,0,1>
>        up <0,1,0>
>        right <4/3,0,0>
>        look_at <0,0,0>
> #local Index=0;
>      rotate A_rotate*y
>      scale 0.2}
> #end
> #end
I think you need  a union { } block
Date: 26 Apr 2005 04:53:35
Message: <426e018f@news.povray.org>
news:426db971$1@news.povray.org...
A(...)
shows
someone
> > camera{
> >        location <0,10,-20>
> >        direction <0,0,1>
> >        up <0,1,0>
> >        right <4/3,0,0>
> >        look_at <0,0,0>
> > #local Index=0;
> >      rotate A_rotate*y
> >      scale 0.2}
> > #end
> > #end
I agree with Jim. Your macro 'A' just returns a series of boxes, which is
fine when you call the macro on it's own.
When you use   object{A(...)}  it complains because the series of boxes is
not a single object (so it complains when it finds the second box).
You could add a union inside your macro by adding    'union {'   just after
your line '#macro A(Angle,Radius,y_rotate,A_rotate)
'  and '}' just before the end.
OR
You could use a union as a wrapper when you call your macro  e.g. 'union{A
(0.01*3.14/180,100,26*3.14/180,180)}'
Chris B.
Date: 27 Apr 2005 13:49:30
Message: <kurtzlepirate-0F77E6.19493027042005@news.povray.org>
In article <web.426da894f3d9b99a1362b3f50@news.povray.org>,
>>camera{
>>       location <0,10,-20>
>>       direction <0,0,1>
>>       up <0,1,0>
>>       right <4/3,0,0>
>>       look_at <0,0,0>
>>#local Index=0;
>>     rotate A_rotate*y
>>     scale 0.2}
>>#end
>>#end
make union{} in your macro like that :
#macro ...
#local index=0;
union {
  #while()
    box { }
klp
