POV-Ray : Newsgroups : povray.newusers : How to extrude a box along curve? Server Time
3 May 2026 04:56:23 EDT (-0400)
  How to extrude a box along curve? (Message 1 to 2 of 2)
Subject: How to extrude a box along curve?
Date: 24 Apr 2005 22:30:00
Message: <web.426c55ab608a2a4d1362b3f50@news.povray.org>
Now I wanna extrude a box along curve(or circle), but don't know how to
achieve that.
Anyone here could help me?
Subject: Re: How to extrude a box along curve?
Date: 25 Apr 2005 03:26:23
Message: <426c9b9f@news.povray.org>
> achieve that.
These examples might at least give you some
ideas or help clarify the problem.
method #1
if the curve is a circle or at least in the same plane you  might
be able to use plain old csg
method #2
boxes can be strung along a spline using Reorient_Trans from
transforms.inc, but this does not create a continuous curved box
shape, just a string of boxes.
Also the uneven weighting of the spline
can be obvious
method #3
Reorient_Trans can be used to local a series of "corner points"
along the spline.  These can then be used to create a mesh.
***In addition to these ideas there is the possibility of sweeping prism
shapes along a spline
http://www.econym.demon.co.uk/isotut/splines.htm
#include "transforms.inc"
#local Method = 1;
#switch ( Method )
   #case ( 1 )
     intersection {
           difference {
                   torus { 10, 2 }
                   cylinder { y*-2, y*2, 9 }
           cylinder { y*-2, y*2, 11 }
           box {  <-15, -1, -15> <15, 1, 15> }
           pigment { rgb <1,1,0> }
   #break
   #case ( 2 )
     #local Spline =
     spline { natural_spline
             0/2 <0,0,0>
             1/2 <10,10,0>
             2/2 <20,10,0>
     #local   Granularity = 20;
     #local I=1;#while(I<Granularity)
             #local Orientation =
             Spline ( I/Granularity ) - Spline ( (I-1)/Granularity );
             //use Reorient_Trans to reorient the box
             box { <-1,0,-1>, <1,-1,1>
                     Reorient_Trans ( y, Orientation )
                     translate  Spline ( I/Granularity )
     #local I=I+1;#end
   #break
   #case ( 3 )
     #local Spline =
             0/2 <0,0,0>
             1/2 <10,10,0>
             2/2 <20,10,0>
             //use Reorient_Trans to define a transform
             #local Trans =
             transform { Reorient_Trans ( y, Orientation )};
             #local P0 =
             vtransform ( <-1,0,0>, Trans) + Spline ( I/Granularity );
             #local P1 =
             vtransform ( <1,0,0>, Trans) + Spline ( I/Granularity );
             #local P2 =
             vtransform ( <1,0,1>, Trans) + Spline ( I/Granularity );
             #local P3 =
             vtransform ( <-1,0,1>, Trans) + Spline ( I/Granularity );
             #if ( I=1 )
                     #local PrevP0 = P0;
                     #local PrevP1 = P1;
                     #local PrevP2 = P2;
                     #local PrevP3 = P3;
             #else
                     mesh {
                             triangle { PrevP0, P0, P1 }
                             triangle { PrevP0, P1, PrevP1 }
                             triangle { PrevP1, P1, P2 }
                             triangle { PrevP1, P2, PrevP2 }
                             triangle { PrevP2, P2, P3 }
                             triangle { PrevP2, P3, PrevP3 }
                             triangle { PrevP3, P3, P0 }
                             triangle { PrevP3, P0, PrevP0 }
                     #local PrevP0 = P0;
                     #local PrevP1 = P1;
                     #local PrevP2 = P2;
                     #local PrevP3 = P3;
     #local I=I+1;#end
   #break
   location  < 30.0, 40.0, -50.0>
   look_at   <1.0, 1.0,  0.0>
   angle 35
light_source {
   0*x
   color rgb <1,1,1>
   translate <-200, 200, -200>
