POV-Ray : Newsgroups : povray.newusers : Lighting question Server Time
17 Jul 2025 05:28:01 EDT (-0400)
  Lighting question (Message 1 to 5 of 5)
Subject: Lighting question
Date: 12 Apr 2005 04:10:00
Message: <web.425b82292c3b529f51a594900@news.povray.org>
So I'd expect in a scene with no lights and no ambient values I'd get a pure
black render, but I can see my objects.  What am I missing?  The scene is
just a blue sphere and nothing else.
Subject: Re: Lighting question
Date: 12 Apr 2005 04:33:21
Message: <425b87d1@news.povray.org>
pure
Have you set "ambient_light" in global_settings to 0? And did you set the
ambient in the finish of the objects to 0? If both are the case, then you
should get a pure black image, unless you're using some emitting media.
Otherwise, the ambient-term will take care that an object is never 100%
black (unless the texture is black itself).
You might want to look up "ambient" and "ambient_light" in the docs.
Tim
"Tim Nikias v2.0"
Date: 12 Apr 2005 04:43:37
Message: <425b8a39@news.povray.org>
news:web.425b82292c3b529f51a594900@news.povray.org...
pure
If not precised, default ambient value is 0.1
If you want to modify that, write
#default {
  texture { finish{ambient 0} }
at the begining of your file
(it can be even compulsory if you use radiosity because ambient>0 emits
light in this case)
Marc
Date: 12 Apr 2005 08:28:39
Message: <425bbef7@news.povray.org>
  If ambient_light in global_settings is 0 then the ambient of objects
do not matter.
  sky_sphere is not affected by amient_light (and probably other more
unusual features such as rainbow).
Date: 12 Apr 2005 09:42:01
Message: <425bd029$1@news.povray.org>
the
> do not matter.
Hm, you're correct, and I actually do know that. My line of thought was:
"These two are responsible, do one or the other." Maybe I should have
phrased it differently. Then again, in povray.newusers I try never to give
the answer right away, but give a very obvious hint where to look. :-)
>   sky_sphere is not affected by ambient_light (and probably other more
I think fog would be in the same category of "ambient doesn't matter here",
and might even influence the image in the way Mienai is referring to, but
that's just a wild guess.
"Tim Nikias v2.0"
