POV-Ray : Newsgroups : povray.newusers : Light emitting media and NKFlare Server Time
17 Jul 2025 05:40:48 EDT (-0400)
  Light emitting media and NKFlare (Message 1 to 5 of 5)
Subject: Light emitting media and NKFlare
Date: 21 Mar 2005 15:25:01
Message: <web.423f2d627ac04ce31bec960e0@news.povray.org>
I am attempting, largely through trial and error, to make a scene including
the entire solar system. So far, I have a starfield background and a sun (a
sphere containing light emitting media).
Code to get me this is:
#include "textures.inc"
#include "stars.inc"
camera
        location <0, 0, -1000>
        look_at <0, 0, 0>
sphere // transparent sphere containing media
 { <0,0,0> 1
  /*texture
   crackle scale 100 turbulence 100
    color_map {
      [0.0 rgbf <1, 0, 0, 0.1>]
      [0.2 rgbf <1, 0.85, 0, 0.4>]
      [0.7 rgbf <1, 0.75, 0, 0.7>]
      [1 rgbf <1, 1, 0, 0.4>]
 pigment {rgbt 1} hollow
  interior
   { media
     { emission 20
       density
       { spherical density_map
         { [0 rgb 0]
           //[0.4 rgb <1,0,0>]
           [0.8 rgb <1,1,0>]
           [1 rgb 1]
  scale 80
sky_sphere
        granite
        color_map {
            [ 0.000  0.270 color rgb < 0, 0, 0> color rgb < 0, 0, 0> ]
            [ 0.270  0.290 color rgb <.5,.5,.4> color rgb <.8,.8,.4> ]
            [ 0.290  0.470 color rgb < 0, 0, 0> color rgb < 0, 0, 0> ]
            [ 0.470  0.490 color rgb <.4,.4,.5> color rgb <.4,.4,.8> ]
            [ 0.490  0.680 color rgb < 0, 0, 0> color rgb < 0, 0, 0> ]
            [ 0.680  0.700 color rgb <.5,.4,.4> color rgb <.8,.4,.4> ]
            [ 0.700  0.880 color rgb < 0, 0, 0> color rgb < 0, 0, 0> ]
            [ 0.880  0.900 color rgb <.5,.5,.5> color rgb < 1, 1, 1> ]
            [ 0.900  1.000 color rgb < 0, 0, 0> color rgb < 0, 0, 0> ]
    turbulence 1
    sine_wave
    scale .5
    scale 0.1
The pigment in the sky sphere is taken from the stars.inc file. I am also
messing around with a 'crackle' effect to get that slightly broken look on
the sun, but it doesnt look very good so i have commented it out.
Before I move onto the other planets, I want to make the sun have a flare. I
pursuit of this I have been trying to use NKFlare, but I really _can't_ get
the damm thing to work.
I have followed all the instructions (.flr file and nkflare.inc in the
include folder, added this to the library path, .flr files and .inc file in
the same directory as my source file) and included the appropriate
variables and include files. My code now looks like this:
#include "nkflare.inc"
#include "space2.flr"
camera
        look_at <0, 0, 0>
#declare cam_loc = <0, 0, -1000>   // use the x, y, and z of your camera
#declare light_loc = <0,0,0> // use the x, y, and z of the light
                              // you wish to flare
#declare lookat = <0, 0, 0>    // the look_at vector of your camera
#declare sky_vect = <0,1,0>
 { <0,0,0> 1
 /*texture
    color_map {
  interior
   { media
     { emission 20
       density
         { [0 rgb 0]
           //[0.4 rgb <1,0,0>]
           [0.8 rgb <1,1,0>]
           [1 rgb 1]
  scale 80
sky_sphere
        granite
        color_map {
    turbulence 1
    sine_wave
    scale .5
    scale 0.1
I have been messing around with the scale a bit (hence scale 80 on the
sphere).
Anyway, when I try to render this POV-Ray jumps to the nkflare.inc file, and
hihlights the line
#local lf_2light = cam_loc - light_loc;
and says (at the bottom) "Parse Error: Cannot initialise uninitialised
identifier"
Can anyone help me to get this to work? It would be much appreciated.
I am using POV-Ray 3.6 for Windows, and this is my third day of POV-Ray.
Thanks
PS sorry about the length of the post
Subject: Re: Light emitting media and NKFlare
Date: 21 Mar 2005 15:44:31
Message: <JUphKDAmIzPCFw7D@econym.demon.co.uk>
>hihlights the line
>identifier"
The order in which you do things matters. NKFlare wants to use variables
like "cam_loc", "light_loc", and a pile of stuff that's created in the flr
file, so you have to declare those variables before the #include, and call
space2.flr before nkflare.inc.
Like this:-
#declare cam_loc = <0, 0, -1000>;   // use the x, y, and z of your camera
#declare light_loc = <0,0,0>;       // use the x, y, and z of the light
#declare lookat = <0, 0, 0>;        // the look_at vector of your camera
#declare sky_vect = <0,1,0>;
Mike Williams
Gentleman of Leisure
Date: 21 Mar 2005 16:00:00
Message: <web.423f3580a6783e921bec960e0@news.povray.org>
> Like this:-
> Mike Williams
Thankyou very much, that works very well and looks damm cool too!
Date: 21 Mar 2005 17:40:00
Message: <web.423f4c5da6783e921bec960e0@news.povray.org>
Anger!
This question may or may not be related to the flare, but I didn't want to
post another thread.
Anyway if I render my code:
#declare cam_loc = <0, 0, -10>;
#declare flare_brightness = 5;
#include "bigstar.flr"
camera
        location <0, 0, -10>
        look_at <0, 0, 0>
 { <0,0,0> 1
  interior
   { media
     { emission 10
       density
         { [0 rgb 0]
           [0.8 rgb <1,1,0>]
           [1 rgb 1]
sky_sphere
        granite
        color_map {
    turbulence 1
    sine_wave
    scale .5
    scale 0.1
The sun is there and the flare is very nice. Note I am 10 units back on the
Z axis. The shpere radius should also be 1 unit. If I move the camera back
to 100, or 1000 units on the Z axis, the sun still appears to be same size
on the scene!
This isn't what I want to happen - I effectively want to zoon out to get a
wider view. What I am doing wrong and/or have missed in documentation/FAQs?
Thanks very much for your help.
PS If you change the camera position be sure to change cam_loc (near the
top) to the same values.
Date: 21 Mar 2005 20:34:30
Message: <ZgllHAAVY3PCFw6d@econym.demon.co.uk>
>on the scene!
But that's how camera flares behave. If that's not what you want, then
don't use nkflare.
Mike Williams
