POV-Ray : Newsgroups : povray.newusers : How to rotate a declared object using normal? Server Time
18 Jul 2025 22:38:59 EDT (-0400)
  How to rotate a declared object using normal? (Message 1 to 3 of 3)
Subject: How to rotate a declared object using normal?
Date: 9 Jan 2005 16:45:01
Message: <web.41e1a5142d0a0d53b3941e880@news.povray.org>
I've just started experimenting with the Trace() function, and I need to
know if it is possible to use the normal returned to rotate an object that
was already declared. I tried to do this:
// Trace object Spike onto object Ball's surface.
#declare Norm = <0, 0, 0>;
#declare Start = <-8, 20, 0>;
#declare Inter = trace (Ball, Start, -y, Norm);
#if (vlength (Norm))
  object { Spike rotate Norm translate Inter }
The spike is translated to the correct position, but it is not rotated; it
still points straight up.  So how would I use the returned normal to rotate
the spike so it points the same direction as the surface normal at Inter?
Here's the entire scene file:
// Test scene file.
#include "shapes.inc"
// Objects
#declare Ball =
object {
  sphere { 0, 10 }
    pigment { color Blue }
    finish { ambient 0.5 phong 1 }
#declare Spike =
object {
  cone { <0, 0, 0>,0.5, <0, 1, 0>, 0 }
    pigment { color Red }
// Scene
  location <0, 20, -20>
  look_at <0, 0, 0>
light_source { <3000, 10000, 5000> color White }
object { Ball }
Subject: Re: How to rotate a declared object using normal?
Date: 9 Jan 2005 17:03:07
Message: <41e1aa1b@news.povray.org>
Use the Reorient_Trans macro in transforms.inc.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 9 Jan 2005 17:35:00
Message: <web.41e1b066227c4738b3941e880@news.povray.org>
>  - Slime
Thanks for the quick response, Slime!  Using Reorient_Trans(y, Norm) gave
the result I was looking for!
Tranceaholic
