POV-Ray : Newsgroups : povray.newusers : Translate include files? Server Time
19 Jul 2025 04:10:35 EDT (-0400)
  Translate include files? (Message 1 to 4 of 4)
Subject: Translate include files?
Date: 8 Nov 2004 04:35:01
Message: <web.418f3d0bf0a0efb8a1ddd0d50@news.povray.org>
I have an include file in the wrong place on the x direction.
Rather then change every single x in the file, can I translate the include
file in the main scene?
TIA.
Subject: Re: Translate include files?
Date: 8 Nov 2004 04:48:50
Message: <418f4102@news.povray.org>
  I think you are using the wrong terminology. An "include file" has no
location, orientation or anything. An include file is just a file like
any other file which you can include into your main scene file.
  You are probably talking about an *object* inside that include file,
but without knowing how that object has been declared it's difficult
to give a definite answer.
Date: 8 Nov 2004 05:00:01
Message: <web.418f42de621770a6a1ddd0d50@news.povray.org>
You're right.
The include file is objects/differences/etc. In this case the centre spindle
bit of a CD case (the bit you press). But stupidly I got the x value wrong
and it's off centre when the whole CD (base and lid) is rendered.
At the end of my cd.pov, is the line...
#include "cd3.pov"
I'd rather not edit cd3.pov and change every x value. (But it looks like I
will)
Date: 8 Nov 2004 09:11:10
Message: <418f7e7e$1@news.povray.org>
> #include "cd3.pov"
> will)
This will probably work:
union {
#include "cd3.pov"
translate x*whatever
Or you could just put the union {} block inside cd3.pov to be cleaner.
 - Slime
 [ http://www.slimeland.com/ ]
