POV-Ray : Newsgroups : povray.newusers : Mismatched reflections Server Time
3 May 2026 10:23:40 EDT (-0400)
  Mismatched reflections (Message 1 to 2 of 2)
Subject: Mismatched reflections
Date: 7 Oct 2004 05:05:00
Message: <web.416506687ca873e1841517f40@news.povray.org>
Recently I started working on an image that requires mismatched reflections,
as in Gilles Trans' "Dark Side of the Trees". Can anyone tell me how this
is accomplished?
The best idea I've had so far is rendering the image once then cutting out
the pond surface and applying it as a surface to a plane in the actual
render with different objects.
Is there a better way?
Subject: Re: Mismatched reflections
Date: 7 Oct 2004 05:27:04
Message: <Xns957B747D4BFD9jgrimbertmeandmyself@203.29.75.35>
> reflections, as in Gilles Trans' "Dark Side of the Trees". Can anyone
> tell me how this is accomplished?
> out the pond surface and applying it as a surface to a plane in the
> actual render with different objects.
a simple no_image vs no_reflection come to mind.
I guess that no_shadow should also be applied to the image-less.
In fact, you could as well perform a 3-ways mismatch:
 an object with a different reflection and a different shadow...
 object { A no_image no_shadow }
 object { B no_reflection no_shadow }
 object { C no_image no_reflection }
l'habillement, les chaussures que le maquillage et les accessoires.
