POV-Ray : Newsgroups : povray.newusers : Subtract Planes ? Server Time
3 May 2026 11:44:43 EDT (-0400)
  Subtract Planes ? (Message 1 to 2 of 2)
Subject: Subtract Planes ?
Date: 24 Sep 2004 18:30:00
Message: <web.41549f48342b5660536167b10@news.povray.org>
I head the idea to construct a screw and the opposite part; a nut ? (Sorry,
For this I had the idea to contruct a flat polygon (6 corners), cut off a
circle inside, sweep it to the third dimension and then use CSG to do the
remaining.
But how to cut off the circle inside the polygon ?
So, the first step is to define the polygon.
# declare Radius_Aussen = 0.5;
# declare Radius_Innen  = 0.3;
# declare Anfangswinkel = 0.0;
# declare Mittelpunkt   = <0.0, 0.0, 0.0>;
# declare Winkel = Anfangswinkel;
# declare Increment = pi/3.0;
# declare X_Koordinate  = 0.0;
# declare Y_Koordinate  = 0.0;
# declare Eckpunkt      = array [6];
# declare Index         = 0;
# while (Index < 6)
  # X_Koordinate = Mittelpunkt.x + Radius_Aussen * Winkel; // This does not
work
  # Y_Koordinate = Mittelpunkt.y + Radius_Aussen * Winkel; // This does not
work
  # Eckpunkt [Index] = <X_Koordinate, Y_Koordinate>;
  # Index = Index + 1;
  # Winkel = Anfangswinkel + Index * Increment;
# end
# declare Grundflaeche =
polygon
  6, Eckpunkt[0], Eckpunkt[1], Eckpunkt[2],
     Eckpunkt[3], Eckpunkt[4], Eckpunkt[5]
Thank you
Subject: Re: Subtract Planes ?
Date: 25 Sep 2004 09:30:49
Message: <41557309@news.povray.org>
Hans-Werner nous apporta ses lumieres ainsi en ce 2004-09-24 18:27... :
>remaining.
># while (Index < 6)
>work
>work
># end
>polygon
>Thank you
Planes are objects that can be intersected (intersection{}) or
diferenced (difference{}), they do have a deffinite interior and exterior.
In your case, you can start with a cylinder or a sphere, use 6 planes to
chop off the faces and a cylinder to bore the hole.
You can also start with a prism from whitch you subtract a cylinder.
