POV-Ray : Newsgroups : povray.newusers : Searching for Military Texture Server Time
3 May 2026 11:44:15 EDT (-0400)
  Searching for Military Texture (Message 1 to 4 of 4)
Subject: Searching for Military Texture
Date: 24 Sep 2004 15:10:01
Message: <web.415470a25c7b40d4536167b10@news.povray.org>
for clothing and vehicles (NATO). Im new to POV-Ray. How could I create
such a texture ?
One of the problems is that every colour has a special area coverage of for
know if the "patches" have a minimum and a maximum area size. Or a
parameter for the minimum and maximum number of "patches". As I know the
"patches" are concav not convex.
this ?
Thank you for help
Subject: Re: Searching for Military Texture
Date: 24 Sep 2004 15:50:17
Message: <41547a79$1@news.povray.org>
"Hans-Werner" <nomail@nomail> wrote in message
news:web.415470a25c7b40d4536167b10@news.povray.org...
one
> such a texture ?
for
> this ?
> Thank you for help
i might be a little off target but to specify color percentages something
like a color_map with one color and then transparency might work. then layer
a few of these together. someone might have a more elegant solution, but
maybe this will start you off.
-ross
// your base color
#local c0 = texture {
    rgb <0.2, 0.4, 0.1>
// add another color, with less coverage
#local c1 = texture {
    bumps
    scale .25
    turbulence 0.25
    color_map {
     [0.00 rgb <0, 0.5, 0>]
     [0.50 rgb <0, 0.5, 0>]
     [0.51 rgbt <0.0, 0.0, 0.0, 1.0>]
     [1.00 rgbt <0.0, 0.0, 0.0, 1.0>]
// second color, a little bit less coverage
#local c2 = texture {
    bumps
    scale .25
    turbulence 0.25
    color_map {
     [0.00 rgb <0.5, 0.5, 0.5>]
     [0.30 rgb <0.5, 0.5, 0.5>]
     [0.31 rgbt <0.0, 0.0, 0.0, 1.0>]
   rotate <15, -30, 35> // rotate it some, so the transparent parts aren't
all the same
// another color with even less coverage
#local c3 = texture {
    bumps
    scale .25
    turbulence 0.25
    color_map {
     [0.00 rgb <0.5, 0.25, 0.15>]
     [0.30 rgb <0.5, 0.25, 0.15>]
//stack them all together now
#local military =
texture {c0}
texture {c1}
texture {c2}
texture {c3}
sphere {
 0.0, 1
  military
Date: 24 Sep 2004 18:20:00
Message: <web.41549c8348c38943536167b10@news.povray.org>
Thank you Ross,
maybe this will help.
I think I will declare a camera and a light and look at this.
Date: 25 Sep 2004 13:10:00
Message: <web.4155a57b48c3894386e5b6190@news.povray.org>
One difference is that in the real military texture one colour is not
included in another colour. They are all beneath on another.
