POV-Ray : Newsgroups : povray.newusers : meshes and rotation Server Time
3 May 2026 20:11:51 EDT (-0400)
  meshes and rotation (Message 1 to 3 of 3)
Subject: meshes and rotation
Date: 20 Nov 2003 22:20:02
Message: <web.3fbd82efbdd378f4a5634560@news.povray.org>
I'm trying to use a mesh to generate a clump of grass. I'm having a problem
because apparently I can't rotate the individual triangles within the mesh.
I'll show the erroneous code I'm using, so you can see what I am trying to
do:
#declare grassclump =
mesh
  #local numblades = 0;
  #local maxblades = 60+int((rand(randseed)*40));
  #while(numblades < maxblades)
    #local rotationx = rand(randseed)*30;
    #local rotationy = rand(randseed)*360;
    triangle
      <.02,0,0>,<-.02,0,0>,<.018,1.2,0>
      rotate < rotationx,0,0>
      rotate <0,rotationy,0>
    triangle
      <-.02,0,0>,<-.018,1.2,0>,<.018,1.2,0>
    triangle
      <-.018,1.2,0>,<.018,1.2,0>,<0,2.5,0>
    #local numblades = numblades+1;
  texture
    pigment
      color rgb <.1,1,.26>
I am using 500,000 of these clumps of grass in my scene, randomly placed. I
could just keep the grassblade as the individual mesh and then use union to
form the clump, but as I have so many, I think I need to be able to keep
the whole clump as a single mesh to keep the number of objects down, right?
Subject: Re: meshes and rotation
Date: 20 Nov 2003 23:32:33
Message: <U+zGgFAOUZv$EwsQ@econym.demon.co.uk>
>do:
You could use syntax like this to rotate the points individually and
then use the rotated points to form the mesh
mesh
    triangle
      #declare P1 = vrotate(<.02,0,0>,<rotationx,rotationy,0>);
      #declare P2 = vrotate(<-.02,0,0>,<rotationx,rotationy,0>);
      #declare P3 = vrotate(<.018,1.2,0>,<rotationx,rotationy,0>);
      P1,P2,P3
    triangle
      #declare P1 = vrotate(<-.02,0,0>,<rotationx,rotationy,0>);
      #declare P2 = vrotate(<-.018,1.2,0>,<rotationx,rotationy,0>);
      P1,P2,P3
    triangle
      #declare P1 = vrotate(<-.018,1.2,0>,<rotationx,rotationy,0>);
      #declare P2 = vrotate(<.018,1.2,0>,<rotationx,rotationy,0>);
      #declare P3 = vrotate(<0,2.5,0>,<rotationx,rotationy,0>);
      P1,P2,P3
  texture
    pigment
Mike Williams
Gentleman of Leisure
Date: 21 Nov 2003 14:38:44
Message: <cjameshuff-C8A151.14332621112003@netplex.aussie.org>
In article <web.3fbd82efbdd378f4a5634560@news.povray.org>,
> do:
...snip...
Right general idea...you need to have it a single mesh, so you can copy
it and have several objects that refer to the same object. However, you
can't apply transformations to individual mesh triangles as you can to
triangle objects. Someone already mentioned the vrotate() function, if
you have a more complex transformation, you might try the vtransform()
macro in transforms.inc. To keep things fairly organized, you might want
to make a macro to create transformed triangles:
#macro Triangle(PtA, PtB, PtC, Trans)
    #local tmpFn = function {transform {Trans}};
    triangle {
        tmpFn(PtA.x, PtA.y, PtA.z),
        tmpFn(PtB.x, PtB.y, PtB.z),
        tmpFn(PtC.x, PtC.y, PtC.z),
mesh {
    Triangle(<.02,0,0>, <-.02,0,0>, <.018,1.2,0>,
        transform {
(the transform{} block is necessary)
http://tag.povray.org/
