POV-Ray : Newsgroups : povray.newusers : area_light looks like a point light Server Time
3 May 2026 23:12:50 EDT (-0400)
  area_light looks like a point light (Message 1 to 7 of 7)
Subject: area_light looks like a point light
Date: 15 Jul 2003 18:50:01
Message: <web.3f14840fae9fae549cfc34200@news.povray.org>
I'm trying to model one of those lights put above paintings: basically, a
flourescent tube inside of a 'c' cross sectioned piece of brass.  My idea
was to use an area light on the x-z plane to simulate this light and then
make it look_like an ambient cylinder.
The problem that I'm running into is that it doesn't look like the area
light is working at all.  I get a single high light in my shiny picture
frame and I'm only getting illumination on the picture from the center of
the bulb.  i.e.
it looks like I'm not doing a point light rather than an area light.  My
light code looks like this:
#local halfw=.5;
#local framewidth=.025;
#local wallthickness=(framewidth*2/25);
light_source { < 0, halfh+framewidth, -framewidth*4>  color Gray50
 area_light x*((2*halfw) - (2*wallthickness)), z*framewidth, 10, 10
        } //light_source
image here: http://homepage.mac.com/sstrange/POV/libraryatnight3.jpg
full code here: http://homepage.mac.com/sstrange/POV/pictureframe.inc
As always, apologies if I'm missing something really, really obvious.
thanks,
Steven
Subject: Re: area_light looks like a point light
Date: 15 Jul 2003 21:09:28
Message: <3f14a5c8@news.povray.org>
Area_lights are only used to calculate soft shadows. For
specular highlights, it still is a point-light. To achieve
what you want, you'd have to use an actual array of light-
sources (with toned down RGB, as they will add up
later).
Tim
Tim Nikias v2.0
> the bulb.  i.e.
> #local halfw=.5;
>         } //light_source
> thanks,
> Steven
Version: 6.0.501 / Virus Database: 299 - Release Date: 15.07.2003
Date: 15 Jul 2003 21:15:01
Message: <web.3f14a6a5231f8c259cfc34200@news.povray.org>
Thanks Tim, I'd been banging my head against that one for a while now.
many thanks,
-Steven
>later).
>Regards,
>Tim
>Tim Nikias v2.0
>Homepage: http://www.digitaltwilight.de/no_lights
Date: 16 Jul 2003 03:13:04
Message: <3f14fb00@news.povray.org>
We all do at some point. It's just the problem
of thinking in terms of the algorithms. Specular
is just a "hack" to create highlights, it has nothing
to do with actual lightsources, lightreflection etc.
Arealights are used to soften shadows and one
is easily lead to think that an arealight would
actually cover a certain area.
I think there are some other "side-effects" like that
spread throughout POV-Ray, where one would
like to expect the intuitive result, but get different
ones. It takes time and patience figuring all of them
out.
But eventually, you'll know them all (which isn't
meant to say that I know them all... :-)
Tim
Tim Nikias v2.0
> many thanks,
> -Steven
> >later).
> >Regards,
> >Tim
Version: 6.0.501 / Virus Database: 299 - Release Date: 14.07.2003
Date: 16 Jul 2003 04:15:25
Message: <3f15099c@news.povray.org>
You might want to read this:
http://www.students.tut.fi/~warp/povQandT/misconceptions.html#arealightconfusion2
  As a side note, also:
Date: 16 Jul 2003 22:55:01
Message: <web.3f160f69231f8c259cfc34200@news.povray.org>
I've been stumbling through and learning, and the lighting misconsceptions
page was a big help. :)
Using an array of lights (not area lights) gave me almost exactly what I
wanted.
image here: http://homepage.mac.com/sstrange/POV/libraryatnight4.jpg
light source code:
  light_source { < currposition, lightcenterheight + 5*wallthickness,
lightcenterdepth>  color red .05 green .05 blue .05
 jitter
 fade_distance 4  fade_power 2
The problem is that the banded shadows coming off of the side of the lamp
makes it obvious I'm using a bunch of descreet lights.  (specifically 30)
One fix I've considered is to also put an area light in there with
extremely high density of area_light in there also.  Is there a better way?
 Should I just bite the bullet and put enough lights in there that the
banding becomes less obvious?
Thanks again for your help on this.  The image is already many many times
better than when I started.
-Steven
Date: 17 Jul 2003 01:07:28
Message: <3f162f10$1@news.povray.org>
"oldmicah" <nomail@nomail> wrote in message
news:web.3f160f69231f8c259cfc34200@news.povray.org...
> wanted.
> light source code:
>  jitter
Might as well remove the keyword 'jitter' since it only works on area_light.
What you could try using instead is spotlight. That way you can attain soft
edges which should blend together and also help to cut down on render time
(maybe). You might need to arrange each of their point_at vectors in such a
way as to be the most efficient and effective. Of course this means there
will ultimately be a directional lighting from the sign's light, if that's
okay.
Bob H.
