POV-Ray : Newsgroups : povray.newusers : (vector) sum of two objects Server Time
4 May 2026 00:39:09 EDT (-0400)
  (vector) sum of two objects (Message 1 to 10 of 52)
Subject: (vector) sum of two objects
Date: 23 Apr 2003 11:10:11
Message: <web.3ea6ac9f97d4f590e54f3efb0@news.povray.org>
Is there a (CSG-like?) possibility to create the vector sum of objects or at
least of simple solids?
Thanks for your help.
Achill
Subject: Re: (vector) sum of two objects
Date: 23 Apr 2003 11:11:50
Message: <e5bdav85ocv9r6vskit389p7ftvhqtlr6r@4ax.com>
Before answer, can you describe more? Example with description of two components
and expected result...
ABX
Date: 23 Apr 2003 12:33:01
Message: <3EA6C026.6010005@ma.tum.de>
Mathematically, the (vector) sum A+B of two sets A and B is defined as
the set of all points x=a+b with a in A and b in B.
A+B = { x : x=a+b, a in A and b in B }.
A "simple" example is the sum of two convex polyhedra (cube,
tetrahedron, octahedron, etc.) which is again a polyhedron.
Another example is the sum of a set A with a sphere of radius r,
centered at <0,0,0>, which gives the set of all points "within distance
r of A". This would give a nice "rounding effect".
I hope this gives a little idea of what i had in mind.
Achill
Date: 23 Apr 2003 12:45:02
Message: <r7gdavcrboohskhfqaniuo3dai0tgd8s9k@4ax.com>
On Wed, 23 Apr 2003 18:32:38 +0200, Achill Schuermann <ach### [at] matumde> wrote:
In my knowledge sum of sets is
A+B = { x : x in A or x in B }
which can be union{} or merge{} object in POV.
Not for me :-(
A I said initially as a 'sum' i thought you mean union{}
http://www.povray.org/documentation/view/171/
http://www.povray.org/documentation/view/40/
but in above text you seam expect that sphere+box=rounded box. This link can
help http://www.povray.org/documentation/view/261/#round_box_union
ABX
Date: 23 Apr 2003 13:07:03
Message: <3EA6C837.BB38782A@gmx.de>
I have no idea what you are talking about but we are not dealing with sets
of points but with surfaces.  Your definition of a vector sum does not
seem to be applicable for surfaces.
That's not an example.
Let's say we have a unit cube between <0,0,0> and <1,1,1> and a sphere at
<0,0,0> with radius 1.  What is the 'vector sum' of these objects?
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 23 Apr 2003 13:07:21
Message: <3EA6C82F.1070205@ma.tum.de>
I did not mean "union". Although, the (vector) sum can be viewed as the
union of all possible vector additions a+b with vectors a in A and b in B.
> Not for me :-(
Thank you for the hint. The macros
   Round_Box_Union(PtA, PtB, EdgeRadius),
   Round_Box_Merge(PtA, PtB, EdgeRadius),
   Round_Cylinder_Union(PtA, PtB, Radius, EdgeRadius),
   Round_Cylinder_Merge(PtA, PtB, Radius, EdgeRadius),
   Round_Cone_Union(PtA, RadiusA, PtB, RadiusB, EdgeRadius),
   Round_Cone_Merge(PtA, RadiusA, PtB, RadiusB, EdgeRadius)
with Radius=EdgeRadius and RadiusB=EdgeRadius respectively seem to give
special examples of sums with a sphere.
Still, it would be nice to have a general "sum" or at least a "sum with
a sphere"...
Achill
Date: 23 Apr 2003 13:33:13
Message: <3EA6CE43.2060102@ma.tum.de>
The defintion is applyable to arbitrary pointsets --- also too surfaces.
Besides, I thought povray is using solids also.
Well, ok.
A concrete example would be the sum of the tetrahedron T with vertices
<0,0,0>, <1,0,0>, <0,1,0> and <0,0,1> with "its negative" -T with
vertices <0,0,0>, <-1,0,0>, <0,-1,0> and <0,0,-1>.
The outcome is a polyhedron (polytope) with vertices
<-1, 0, 0>, <0, -1, 0>, <0, 0, -1>, <1, 0, 0>, <1, -1, 0>, <1, 0, -1>,
<0, 1, 0>, <-1, 1, 0>, <0, 1, -1>, <0, 0, 1>, <-1, 0, 1>, <0, -1, 1>.
Generally, such vector sums of polytopes can be evaluated for example
with the program "polymake" (www.math.tu-berlin.de/polymake/)
As far as I understand the macro
"Round_Box_Union(PtA, PtB, EdgeRadius)",
it would be "Round_Box_Union(<0,0,0>, <1,1,1>, 1)".
Achill
Date: 23 Apr 2003 14:07:24
Message: <3EA6D65B.4BAB8280@gmx.de>
Achill wrote:
> Well, ok.
Well, so much for polyhedra - you can surely create any polyhedron you
want with meshes.
So the vector sum of an arbitrary surface and a sphere at <0,0,0> with
radius 1 is the same as with any other sphere with the radius 1?  Sounds
strange.  Furthermore this means that this sum is not commutative.
Date: 23 Apr 2003 15:44:28
Message: <Xns9366DDB084CCEtorolavkhotmailcom@204.213.191.226>
Achill <ach### [at] matumde> wrote in news:3EA### [at] matumde:
>>>as the set of all points x=a+b with a in A and b in B.
Why isn't <0, 0, 0> in the outcome list ?
Tor Olav
Date: 24 Apr 2003 01:50:40
Message: <7fueavs379noqouu7nvbj2vck3mojfa1u6@4ax.com>
I have never seen practical usage of it (can you deliver some url references ?)
but the only solution I can imagine is script based solution. First make some
smart macro to achive array with grid of points of result based on two input
patterns/objects/arrays. Then turn it into density file and render as
media/isosurface.
ABX
