POV-Ray : Newsgroups : povray.newusers : this is very strange!! Server Time
27 Jul 2025 10:21:38 EDT (-0400)
  this is very strange!! (Message 1 to 4 of 4)
Subject: this is very strange!!
Date: 11 Dec 2002 17:30:04
Message: <web.3df7bbc0306b460ede2a6cfb0@news.povray.org>
#include "Colors.inc"
camera{
   location <0,10,0>
   look_at <0,2,0>
light_source{ <-10,10,-10> color White}
plane{ y,0 pigment{ checker Black White } }
box{ <0,0,0> <.1,6,.1> rotate <30,0,-30> translate <-2,0,-2> pigment{Grey}}
box{ <-.05,0,-.05> <.05,6,.05> pigment{Green} finish{ambient .3} }
When you render this scene, you see a grey rod next to a green one. I don't
understand why they don't intersect?! Looking to the rotation of the grey
rod, it should be crossing a point where x=0 and z=0 (the green rod).
But it doesn't...
I thought a lot about this but i realy don't understand.
can someone please explain what's wrong here?
Subject: Re: this is very strange!!
Date: 11 Dec 2002 20:48:19
Message: <BA1D9A05.7FD8%fidel.viegas@artrecognition.co.uk>
in article web.3df7bbc0306b460ede2a6cfb0@news.povray.org, Lenx at
lenx_@hotmail.com wrote on 11/12/02 10:27 pm:
> camera{
> location <0,10,0>
> look_at <0,2,0>
> But it doesn't...
For you to have an intersection, you need to use the CSG. In your case, you
need to wrap your two boxes above with the keyword intersection as follows:
intersection {
  box{
    <0,0,0>,
    <.1,6,.1>
    rotate <30,0,-30>
    translate <-2,0,-2>
    pigment{Grey}
  box{
    <-.05,0,-.05>,
    <.05,6,.05>
    pigment{Green}
    finish{ambient .3}
But the two boxes above do not have an intersection point. So, in this case
it is useless. What exactly are you trying to create? Have a look at your
code again and fiddle with it so that you have an intersection area that
matches your requirements.
Also, have a look at the documentation on section 3.3 for general CSG and
section 3.3.3 for intersection. That should help you out.
All the best
Fidel.
Date: 12 Dec 2002 05:47:05
Message: <3df86929@news.povray.org>
> But it doesn't...
  You are assuming that after rotating 30 degrees around the x-axis and
then -30 degrees around the z-axis, the rod will be 45 degrees from both
axes (only that way it would cross the y axis when translated to <-2,0,-2>).
  This isn't so.
  If you want the rod to cross the y-axis, you need to truely rotate it
45 degrees around the y-axis. That is:
box{ <0,0,0> <.1,6,.1> rotate <30,45,0> translate <-2,0,-2> pigment{Grey}}
Date: 12 Dec 2002 09:13:31
Message: <BA1E48AF.803C%fidel.viegas@artrecognition.co.uk>
in article 3df86929@news.povray.org, Warp at war### [at] tagpovrayorg wrote on
12/12/02 10:47 am:
>> But it doesn't...
> This isn't so.
I guess I misread the question. Sorry, I thought he was looking for CSG
stuff.
Thanks for clearing that out Warp.
All the best
Fidel.
