POV-Ray : Newsgroups : povray.newusers : how can i make dust ? Server Time
17 Mar 2026 11:06:14 EDT (-0400)
  how can i make dust ? (Message 1 to 7 of 7)
Subject: how can i make dust ?
Date: 27 Nov 2005 10:02:05
Message: <pan.2005.11.27.15.02.04.367146@web.de>
Hi all,
i have a driving car in the desert. How can i make a dust cloud behind the
car.
I'm not so familiar with all texture possibilities and need a hint.
I thought about a cone with a half transmission but it's too regular and
really a cloud.
thx
Alex
Subject: Re: how can i make dust ?
Date: 27 Nov 2005 10:55:09
Message: <4389d6dd@news.povray.org>
> really a cloud.
You could take a particle system, e.g. Rune's (www.runevision.com) or mine
(www.nolights.de) and use those to place lots of spherical particles filled
with media, or discs facing the camera, with a transparent rim and slightly
less transparent center.
Hope that gives you a start,
Tim
aka "Tim Nikias v2.0"
Date: 27 Nov 2005 11:43:39
Message: <4389e23b$1@news.povray.org>
Alexander Nagel nous apporta ses lumieres en ce 2005-11-27 10:02:
> Hi all,
> car.
> really a cloud.
> thx
> Alex
Another way: (normaly, you can't see individual particles in the dust cloud)
Start with an object with about the shape you want, a blob should be a good start.
Now, make it totaly transparent: texture{pigment{ rgbt 1}finish{ambient 0 diffuse 0}}
Make it hollow: add the "hollow" keyword.
Fill it with media. Make the media scathering. Try several pigments as density and add
some turbulence.
You can use the cone filled with media close to the tires and merge it with a blob
some distance
away from the car.
Please note that scathering media is the slowest kind of media.
DON'T use high intervals value, increase the samples count instead. MUCH faster!
That's for the
default media sampling method.
If the dust is to transparent, you can increase the density, one (1) is not the
maximum, there is no
maximum.
It doesn’t matter what you do. It only matters what you say you’ve done and what
you’re going to do.
Date: 27 Nov 2005 12:54:34
Message: <4389f2da@news.povray.org>
> car.
  I'm sure you can adapt this technique for your needs:
http://www.oyonale.com/ressources/english/sources13.htm
Date: 27 Nov 2005 19:26:17
Message: <pan.2005.11.28.00.26.18.868924@web.de>
Am Sun, 27 Nov 2005 16:54:41 +0100 schrieb Tim Nikias:
> Tim
It seems it is a bit more complicated than i thought.
thanks for your help.
Alex
Date: 27 Nov 2005 19:29:56
Message: <pan.2005.11.28.00.29.54.19551@web.de>
Am Sun, 27 Nov 2005 11:42:43 -0500 schrieb Alain:
0}}
add some turbulence.
some distance
> away from the car.
That's for the
> maximum.
Nice idea. I'll try that. Rendertime is not that big problem. I have a
pretty fast box.
But the cloud scenes from Warp take a long time to render.
thx
Alex
Date: 27 Nov 2005 19:32:47
Message: <pan.2005.11.28.00.32.48.394894@web.de>
Am Sun, 27 Nov 2005 12:54:34 -0500 schrieb Warp:
>> car.
Wow, really cool.
But it takes a long time to render.
Meanwhile you can increase the earth' population ;-)
thx
Alex
