POV-Ray : Newsgroups : povray.newusers : problem using rotate in a while loop Server Time
27 Jul 2025 05:23:42 EDT (-0400)
  problem using rotate in a while loop (Message 1 to 7 of 7)
Subject: problem using rotate in a while loop
Date: 10 Feb 2003 17:12:09
Message: <pan.2003.02.10.22.12.09.759527@suso.org>
I'm trying to make a scene where several boxes form a circle and
are tangent to the circle.  in other words, each box would be
rotated a certain amount as they are placed around the circle.
I tried doing this with a while loop and a couple of variables.
I can get the translation to work, but the rotate doesn't work.
What could I be doing wrong?  By the way, I already tried making
the box a declared object that is defined outside the while loop.
Thanks for your help.
light_source { <-10, 20, 0> color White }
light_source { <0, 50, 0> color White }
plane {
    y, -1
    pigment { checker color Black color White scale 5 rotate y*45 }
    location <0, 20, 0>
    look_at <0, 0, 0>
#declare rad = 10;     // radius of circle
#declare objects = 9;  // number of objects in circle
#declare position = 0;  // starting position
#declare increment = 2*pi / objects;  // increment between objects
#declare degree = 180/pi;  // Radian to degree conversion
#declare thisobject = box {
    <-1,-1,-1>
    <1,1,1>
    pigment { color Green }
    rotate <0,increment*degree,0>
#while (position < 2*pi)
    box {
        <-1,-1,-1>
        <1,1,1>
        rotate <0,increment*degree,0>  // rotate the box so that it is tangent.
        translate <cos(position)*rad, 0, sin(position)*rad>
    #declare position = position + increment;
Subject: Re: problem using rotate in a while loop
Date: 10 Feb 2003 17:30:11
Message: <web.3e4827d1367de2c2b417814a0@news.povray.org>
>plane {
>    y, -1
>camera {
>    location <0, 20, 0>
>    look_at <0, 0, 0>
>    <-1,-1,-1>
>    <1,1,1>
>    box {
>        <-1,-1,-1>
>        <1,1,1>
>#end
You can just change this line:
- to this:
rotate <0,-position*degree,0>
Tor Olav
Date: 10 Feb 2003 17:50:03
Message: <web.3e482bfc367de2c2b417814a0@news.povray.org>
>>plane {
>>    y, -1
>>camera {
>>    location <0, 20, 0>
>>    look_at <0, 0, 0>
>>    <-1,-1,-1>
>>    <1,1,1>
>>    box {
>>        <-1,-1,-1>
>>        <1,1,1>
>>#end
>- to this:
But I would recommend writing the code like this:
plane {
  y, -1
  location <0, 20, 0>
  look_at <0, 0, 0>
#declare increment = 2*pi/objects;  // increment between objects
  box {
    -<1, 1, 1>, <1, 1, 1>
#declare thisobject = object { thisobject translate rad*x }
  object { thisobject rotate degrees(position)*y }
Or even like this:
#version 3.5;
plane {
  y, -1
  pigment { checker color Black color White scale 5 }
  rotate y*45
  location 20*y
  look_at 0*y
#declare Radius = 10;
#declare NrOfObjects = 9;
#declare dAngle = 360/NrOfObjects;
#declare BoxObject =
  box {
#declare BoxObject = object { BoxObject translate Radius*x }
#declare Cnt = 0;
#while (Cnt < NrOfObjects)
  object { BoxObject rotate Cnt*dAngle*y }
  #declare Cnt = Cnt + 1;
#end // while
Tor Olav
Date: 10 Feb 2003 19:12:20
Message: <3E483FE5.3AFC8F53@computermuseum.fh-kiel.de>
Hi Sosu,
your main error is rotating by 'increment' which doesn't change in the
loop. Use '-position' instead. (POV-angles are counted in the opposite
direction as math-angles -- that's the reason for the '-'.)
The declared 'thisobject' is not used, so it will not appear. To put
it in the scene, use
   object { thisobject /*texture, rotate etc. may come here*/ }
POV-Ray has functions to convert from degrees to radians and reverse:
   degrees ( Angle_in_radians )
   radians ( Angle_in_degrees )
Names of variables should have at least one uppercase letter in them
to avoid confusion with (current or future) keywords of POV-Ray. You
have a near miss with 'degree' which is almost the keyword 'degrees'!
Instead of
   rotate <0, -degrees(Position), 0>
   translate <cos(Position)*Rad, 0, sin(Position)*Rad>
let POV-Ray do the trigonometry:
   translate Rad*x // put onto the circle
   rotate -degrees(Position)*y // swing around the origin to destination
You can even omit the conversion to degrees, if you express the
Position in degrees instead of radians.
Due to floating point inaccuracies, your loop might not reach 2*pi
after nine additions of 'Increment' and create an additional box
rotated by slightly less than 2*pi. Integers will be treated
correctly (when all intermediate results also are integers!), so
it is better to use an integer number in loops and calculate the
non-integer Position from it -- or increment the position, but count
with integers.
Putting all this together, leaving out the superfluous 'thisobject'
and fiddling around here and there gives this:
// BEGIN OF POV-SCENE //////////////////////////////////////////////////
plane {
    y, -1
    location 20*y
    look_at 0
#declare Rad     = 10;  // radius of circle
#declare Objects =  9;  // number of objects in circle
#declare Increment = 360/Objects;  // degrees increment between objects
#declare Number  =  0;  // starting number
#while (Number < Objects)
    box { -1, 1
        translate Rad*x
        rotate -Number*Increment*y // let POV do the sin and cos
    #declare Number = Number + 1;
#end//while Number
// END OF POV-SCENE ////////////////////////////////////////////////////
   Sputnik
e-mail: fr### [at] computermuseumfh-kielde
Date: 10 Feb 2003 22:53:42
Message: <3e4873c6$1@news.povray.org>
Oh I get it now.  POV-Ray really functions reverse of what I expected.
Being a programmer, I was expecting it to keep track of what the box's
previous rotational angle was on the last iteration of the while loop.  I
should have realized that I wasn't doing that with the position.  Thanks
for your help.  Both of you.
> - to this:
> Tor Olav
Date: 11 Feb 2003 05:26:35
Message: <3e48cfda@news.povray.org>
Well, at each iteration it creates a new box from scratch, so...
BTW, no need to resort to trigonometry here, just do the translation before
rotation:
#declare Rad = 3;
#declare Rot = 0;
#while(Rot < 360)
  box {
   -1, 1
   pigment { rgb y }
   translate Rad*z;
   rotate Rot*y
  #declare Rot = Rot + 30;
Date: 11 Feb 2003 05:52:06
Message: <3e48d5d6@news.povray.org>
  It works pretty much like a programming language would.
  When you make a "#declare Object = box { ... }", that's a bit like
saying "struct Object { ... }" or "class Object { ... }" in C/C++.
When you make an instantiation of the box with "object { Object }", that's
like making an instantiation of the struct/class in C/C++, like
"Object obj;". If you now modify *this* instantiation it naturally doesn't
modify any other instantiation you may have of the same class.
