POV-Ray : Newsgroups : povray.newusers : light diffraction using photons Server Time
22 Jan 2025 12:06:25 EST (-0500)
  light diffraction using photons (Message 1 to 3 of 3)
Subject: light diffraction using photons
Date: 12 Nov 2010 14:30:35
Message: <op.vl2og7jg3wevk9@amilo.fritz.box>
Hello,
I want to deal with light diffraction using photons. In the PovRay manua
l
chapter 3.6.3.1.1 there are shown
two examples. Where can I find the related source code?
mail/
Subject: Re: light diffraction using photons
Date: 12 Nov 2010 20:11:55
Message: <4cdde5db$1@news.povray.org>
> Hello,
> manual chapter 3.6.3.1.1 there are shown
POV-Ray support reflection and refraction. Refraction also support
chromatic dispersion.
Diffraction is NOT supported as it depends on waves interference and
there is no light waves in the model used.
You should continue your reading for the following sections: 3.6.3.2 to
3.6.4
There is no diffraction in either of those scenes. There is also NO
dispersion.
The first image show only a single white light_source.
The second one DON'T actualy use dispersion but fake it using 3
light_sources, one red, one green and one blue.
To my knowlege, the POV files for those scenes are not included with the
distribution.
The following sample files use photons and are included in the
distribution. They can be found in the advanced folder:
diffract.pov
newdiffract.pov
optics.pov
grenadine.pov
NONE of those show any diffraction.
What is important to know:
1 - You must turn photons ON in the global_settings, and specify ether
the total number of photons (count) to shoot OR the density of the
photons (spacing). There are other oprional parameters.
2 - The objects that are meant to interact with the photons need a
photons block to set them as target and enable reflection or refraction.
3 - You don't need any photons block for the light_source. ALL
light_source without "shadowless" automaticaly shoot photons whenever
photons are enabeled.
  - shadowless light_source NEVER shoot any protons. They also never
cause any highlight.
4 - For ANY transparent object that have an ior and dispersion set to a
value different than 1 AND zero, the dispersion will affect photons.
There is nothing else to add.
Thin film interference CAN be simulated using irid in the finish.
Date: 14 Nov 2010 09:48:42
Message: <op.vl50rd2h3wevk9@amilo.fritz.box>
Hello Alain,
thank you for the hints. I will study the mentioned sample files. If I
have further questions, I will come back to here.
Herbert
Am 13.11.2010, 02:11 Uhr, schrieb Alain <aze### [at] qwertyorg>:
>> Hello,
o
> 3.6.4
> dispersion.
he
> distribution.
> diffract.pov
> newdiffract.pov
> optics.pov
> grenadine.pov
n.
a
> Alain
mail/
