POV-Ray : Newsgroups : povray.newusers : OK, this time really counts... Server Time
3 May 2026 20:11:42 EDT (-0400)
  OK, this time really counts... (Message 1 to 7 of 7)
Subject: OK, this time really counts...
Date: 5 Nov 2003 20:32:36
Message: <matt-pace-7B05E0.17323505112003@netplex.aussie.org>
Last time I asked a isosurface question, it was a stupid error on my
part, and thats what I get for coding too late at nite...  This time,
though, I am really confused.  IF (IF) I understand isosurfaced
correctly here, (tell me if Im wrong), POV checks to see which parts of
the containing box fit into the function to equal the threshold.  if
this is true, take the following scene:
camera
   location <3,12,-15>
   look_at  <0,0,0>
light_source
   <5,14,-10>
   color rgb <2,2,2>
   area_light
   <3,0,0>,<0,0,3>,5,5
   adaptive 1
   jitter
isosurface
   function{-y}
   threshold 0
   contained_by{sphere{0,5}}
   pigment
      color rgb <1,1,1>
and help me out here.
1) Wouldnt just a plane show up?  y equals 0 on only one plane, doesnt
it?
2) If y is negative, why is the positive part of the sphere shaded?
thanks a lot.
Subject: Re: OK, this time really counts...
Date: 5 Nov 2003 20:46:23
Message: <3fa9a7ef@news.povray.org>
> it?
  By default POV-Ray will take any point which is *inside* the isosurface
as the surface of the object. This means that if the surface of the
container object is inside the isosurface, it will show up.
  You can use "open" to stop it from doing this.
  Because it makes the check -y<0, which is the same as y>=0.
Date: 5 Nov 2003 21:04:19
Message: <matt-pace-F64595.18041905112003@netplex.aussie.org>
In article <3fa9a7ef@news.povray.org>, Warp <war### [at] tagpovrayorg>
> > it?
Oh ok, thanks, I should have guessed...
And that makes sense too, because what is inside a function is generally
considered to be true too.  Thanks.  Last question:  is there a way to
make it so that it is function=threshold?  Thanks
Date: 5 Nov 2003 21:18:01
Message: <matt-pace-A623ED.18180105112003@netplex.aussie.org>
nevermind that last post...
Date: 5 Nov 2003 21:19:11
Message: <QUzMZFAk9aq$EwWG@econym.demon.co.uk>
>it?
Because you missed out the "open" keyword.
When the contained_by object is "closed", you see the parts of the
container that intersect with the inside of the isosurface. It's like
the difference between intersection and clipped_by in CSG.
So the shape you see is the intersection of the inside of the sphere and
The inside of an isosurface is considered to be the places where the
function has a negative value. (The function is positive outside and
zero on the surface). The logic is exactly the same as the following CSG
operation. The inside of the {-y,0} plane is in the positive y
direction.
intersection {
  plane {-y,0}
  sphere {0,5}
  pigment {rgb 1}
Mike Williams
Gentleman of Leisure
Date: 5 Nov 2003 21:47:00
Message: <cjameshuff-EB9E52.21464205112003@netplex.aussie.org>
In article <mat### [at] netplexaussieorg>,
I don't really understand your explanation of what you think happens, so
I will just explain what happens. ;-)
An isosurface is a surface composed of all points where a function is
equal to a certain threshold value. All points where that function is
less than the threshold are considered "inside" the isosurface. Because
of computational constraints, the isosurface shape in POV-Ray limits
isosurfaces to within a container shape. By default, if a part of the
container is inside the isosurface, it is considered part of the
surface. Using the "open" keyword will remove these container surfaces,
giving you holes into the interior of the isosurface where it intersects
its container.
> it?
A plane and all parts of the container where the function is less than
the threshold.
By "shaded" I assume you mean present...and the +y half of the container
is visible because -y is below the threshold for those points.
Hope this helped...
http://tag.povray.org/
Date: 6 Nov 2003 04:02:02
Message: <41ep71-kc2.ln1@triton.imagico.de>
This is all explained in the isosurface tutorial in the documentation:
http://www.povray.org/documentation/view/61/
BTW: It is a good idea to use a subject line that actually tells
something about the content of the posting...
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
