POV-Ray : Newsgroups : povray.newusers : Returning user - Simple ? question Server Time
21 Jan 2025 09:01:44 EST (-0500)
  Returning user - Simple ? question (Message 1 to 10 of 10)
Subject: Returning user - Simple ? question
Date: 27 Sep 2015 09:47:29
Message: <ftrf0blauc12ias0fg98mau9hsc9137d6b@4ax.com>
Hi
I have not used POVray for about 10 years since i retired and it
appears I have forgotn much that I thought I used to know.
Wood turning is a main hobby and I want to use POV as a virtual
protype.
I have one question that I am finding frustrating.
I have a virtual block made of several wood that I want use a sphere
to cut a depression onto to make it into a bowl.  When I try it the
pigment of the sphere shown on the surface hiding the laminations.  I
am sure in the past I could get this to work.  Any advice would be
appreciated.
Subject: Re: Returning user - Simple ? question
Date: 27 Sep 2015 14:24:00
Message: <56083440$1@news.povray.org>
Am 27.09.2015 um 15:47 schrieb AQ:
> appreciated.
My spontaneous thought is that simply using an untextured sphere should
do the trick.
Date: 28 Sep 2015 13:47:22
Message: <56097d2a$1@news.povray.org>
Hash: SHA256
>> sphere to cut a depression onto to make it into a bowl.  When I
>> try it the pigment of the sphere shown on the surface hiding the
>> laminations.  I am sure in the past I could get this to work.
>> Any advice would be appreciated.
> should do the trick.
My second thought would be to look at cutaway_textures
> http://wiki.povray.org/content/Reference:Cutaway_Textures
But beware of the killing note:
POV-Ray will determine which texture(s) to use by doing insidedness
tests on the objects in the difference or intersection. If the
intersection point is inside an object, that object's texture will be
used (and evaluated at the interior point).
If the parent object is a CSG of objects with different textures, then
the textures on overlapping parts will be averaged together.
which means that your wood's parts should be clean (and not just
hidden by another part).
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlYJfSoACgkQhKAm8mTpkW38oQP/UEmqnrc1qz8wjHRxoUcuXF5z
rc8xJNJyIJvxjUk4jPmm7RkPZU0L//DbWXtmCVp8As+Y3TM4p7T68b6IkpZr+hzk
8oytAKSHIxgJQOnoHnGunGO/fvt7BlWMDT/vrFPJmy8QtFHLlQRqs62cLvya1OqK
wTkDQMptjjQ+sdHC4w0=
=Dy6h
-----END PGP SIGNATURE-----
Date: 30 Sep 2015 17:18:05
Message: <6ako0bdmrts7ob3v5odf4kftha72020m1c@4ax.com>
On Mon, 28 Sep 2015 19:47:22 +0200, Le_Forgeron <jgr### [at] freefr>
wrote:
>-----BEGIN PGP SIGNED MESSAGE-----
>Hash: SHA256
>Version: GnuPG v2
>=Dy6h
Thank you I will have to think about what that means
John
Date: 30 Sep 2015 18:01:29
Message: <4pmo0btug9qvgbl7kqtqq5bc9cne7mgo84@4ax.com>
>Hash: SHA256
>Version: GnuPG v2
>=Dy6h
Thank you that cutaway_textures keyword was new to me but it solved
all the problems.
Date: 30 Sep 2015 19:58:10
Message: <560c7712@news.povray.org>
> Hi
> protype.
> appreciated.
My may:
Model the untextured outside of your bowl.
Use an untextured sphere to cut the depression.
Finaly, apply the texture to the whole object.
Generic sample:
difference{
  object{Bowl_Outside}// No texture here
  sphere{Depression_Center, Depression_Radius}//Also no texture here
  texture{My_Wood}
Date: 2 Oct 2015 12:55:08
Message: <560eb6ec@news.povray.org>
AQ wrote:
> Hi
> protype.
I like wood work too. The others have answered your question about
textures. I like to talk about the bowl. I would use POV's lathe to make
my bowls. I know it can be hard to learn how to write the lathe code by
hand. There are several programs out there that can help.
  My own is at http://leroywhetstone.s5.com/Pages/Win_Programs.html
POV's lathe can produce almost anything that can be made on a real
lathe. I've seen on PBS where a guy made cowboy hats.
POV's sor can produce dales, pickets, anything that doesn't have an
interior cut.
Have fun!
Date: 17 Oct 2015 05:50:01
Message: <web.56221655826cb05833c457550@news.povray.org>
> appreciated.
As Clipka said, the cutaway-textures feature has an *averaging* behavior-- but
that only occurs when you have *overlapping* textured objects (like concentric
solid spheres within spheres.) If you want to see the 'pure' textures of your
various pieces of wood when you carve your bowl, the way to do it is to build
your initial 'block' of laminated wood (prior to CSG) out of separate,
NON-overlapping pieces, each textured individually. It
appears that you have already done this.  ;-)  Then, use NON-textured spheres
as the cutaway objects, as has already been mentioned.
Here's some example code that I threw together (based on the POV-Ray features in
v3.6.2.) The separate wood 'layers' have very tiny gaps between them, to avoid
overlaps and any coincident-surface problems.
(Side note: The code uses the 'inverse' keyword for one of the cutaway spheres;
you might want to add an additional bounded_by object to the final CSG, for
efficiency.)
#declare Thin_Wood_Layer =
box{<0,0,0>,<2,.14999,2> // not quite .15000 in thickness
 // no texture yet
#declare Total_Wood_Block=  // prior to CSG
union{
object{Thin_Wood_Layer
 texture{Wood_Texture_1}
 texture{Wood_Texture_2}
 translate .15*y
 texture{Wood_Texture_3}
 translate .3*y
 texture{Wood_Texture_4}
 translate .45*y
 texture{Wood_Texture_5}
 translate .6*y
 texture{Wood_Texture_6}
 translate .75*y
//----- the CSG and the cutaway ------
difference{
object{Total_Wood_Block translate <-1,0,-1>}
// to center it on origin in x and z, for ease of CSG.
// Block is <2,.9,2> in size (minus .00001 in y, actually}
sphere{0,.9 // to carve away the inside of the bowl
 // no texture
 scale <1,.7,1>
 translate .75*y
sphere{0,.99 // to carve away the outside of the bowl
 // no texture
 inverse
 scale <1,.7,1>
 translate .72*y
 cutaway_textures
 rotate -60*x
 rotate -30*y
 translate 1.2*y
Date: 18 Oct 2015 14:42:34
Message: <5623e81a@news.povray.org>
>> appreciated.
Another way would be to use a gradient pattern with a texture_map
containing the various wood, or any other, textures to be used.
Advantage: Faster rendering as the object will be much simpler as it can
now be a single base object.
Disadvantage: You must carefully scale the gradient and apply an oposite
scaling to the individual textures.
Date: 20 Oct 2015 03:50:01
Message: <web.5625f201826cb05833c457550@news.povray.org>
You're right, that's a very good alternate way of doing it. I didn't think of
that.
As always, there are multiple ways of solving any POV-Ray problem. :-)
