POV-Ray : Newsgroups : povray.newusers : isosurface function - scale,move Server Time
18 Feb 2025 17:25:37 EST (-0500)
  isosurface function - scale,move (Message 1 to 4 of 4)
Subject: isosurface function - scale,move
Date: 30 Jan 2005 11:22:27
Message: <Xns95EEB0AEA7A44raf256com@203.29.75.35>
What is the best way to write syntax like:
  #macro X() x*S.x+W.x #end
  #macro Y() y*S.y+W.y #end
  #macro Z() z*S.z+W.z #end
  function {
    pow(X(),2) + pow(Y(),2) + pow(Z(),2) - 1
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: isosurface function - scale,move
Date: 30 Jan 2005 15:07:55
Message: <41fd3e9b@news.povray.org>
>   function {
  I failed to understand what actually is your question...
Date: 30 Jan 2005 15:34:32
Message: <SzTXjBAOTU$BFwnJ@econym.demon.co.uk>
>  function {
There's all sorts of things that you could mean by that.
I'm going to assume that you want "x", "y" and "z" to be the function
parameters (not shorthand for the unit vectors, which is what they
always are inside a macro).
Note that "S.x+W.x" is a constant, so we can write
  #declare X = S.x+W.x;
rather than using a macro, and it has the advantage that we can evaluate
it in part of the SDL where vector calculations are legal. It is legal
to call a macro from inside a function (it only gets evaluated once, at
parse time) but not one that uses vectors.
So the whole thing becomes
#declare Y = S.y+W.y;
#declare Z = S.z+W.z;
function {pow(x*X,2) + pow(y*Y,2) + pow(z*Z,2) - 1}
which is an ellipsoid.
Mike Williams
Gentleman of Leisure
Date: 30 Jan 2005 16:45:39
Message: <41fd5583$1@news.povray.org>
Judging from your post's topic, I'm assuming you want an easy way to
transform a function (scale/rotate/translate) that you're using in an
isosurface. For that I would suggest the IsoCSG library (
http://www-public.tu-bs.de:8080/~y0013390/pov/ic/ ). Then you can do
something like
#declare myfunc = function {x*x + y*y + z*z - 1}
#declare mynewfunc = IC_Transform (myfunc, transform {scale 3 rotate 90*x
translate y} )
 - Slime
 [ http://www.slimeland.com/ ]
