POV-Ray : Newsgroups : povray.newusers : wireframe rendering Server Time
6 May 2026 10:20:17 EDT (-0400)
  wireframe rendering (Message 1 to 9 of 9)
Subject: wireframe rendering
Date: 5 Jul 2002 09:11:23
Message: <B94B5920.415%fidel.viegas@artrecognition.co.uk>
Hi guys, I was wondering if it is possible to render an object as wireframe
with povray. If that is possible, how do I do that.
Thanks in advance
Fidel.
Subject: Re: wireframe rendering
Date: 5 Jul 2002 09:25:02
Message: <Xns9242D9B527918mrartchesapeakenet@204.213.191.226>
Fidel viegas scribis
news:B94B5920.415%fid### [at] artrecognitioncouk:
> wireframe with povray. If that is possible, how do I do that.
> Thanks in advance
> Fidel.
The only way I know of is if your object actually *is*
a wireframe. There is no switch, no option, no setting that
is native to POVRay that displays a wireframe version of
your scene. :(
Gis poste, Arto.
Date: 5 Jul 2002 09:27:21
Message: <ja7biucv1htc8lgo66aa4pi1ag1qgc4csb@4ax.com>
On Fri, 05 Jul 2002 14:09:36 +0100, Fidel viegas
Internal representation of objects not contains wireframe structures. But
since SDL can do everything ;-) take a look at
http://news.povray.org/search/?s=povgui
ABX
Date: 5 Jul 2002 10:00:58
Message: <3D25A69A.6E58F44D@gmx.de>
> Thanks in advance
Apart from what has been said:
http://www.students.tut.fi/~warp/povQandT/languageQandT.html#wireframes
Last updated 30 Jun. 2002 _____./\/^>_*_<^\/\.______
Date: 5 Jul 2002 12:05:31
Message: <3d25c3cb@news.povray.org>
> your scene. :(
  That's because there exist no concept of "wireframe" in a raytracer.
A wireframe needs essentially edges, and there are no edges in smooth
surfaces.
  A raytracer handles mathematical surfaces, not polygons. An object made of
polygons can be represented as "wireframe" (by drawing a line for each edge
of the polygon); that's because an object made of polygons has edges. But
POV-Ray doesn't use polygons to represent objects.
Date: 5 Jul 2002 21:37:19
Message: <3D2649C1.4208BAFE@pacbell.net>
> > your scene. :(
> surfaces.
And besides all that, POV-Ray has no internal support for wire frame views
of objects.
Ken Tyler :)
Date: 7 Jul 2002 13:41:10
Message: <Xns92451107E6045mrartchesapeakenet@204.213.191.226>
Ken scribis news:3D2649C1.4208BAFE@pacbell.net:
> of objects.
Didn't I say the same thing?
Gis poste, Arto.
Date: 10 Jul 2002 04:34:16
Message: <3d2bf188@news.povray.org>
"Fidel viegas" <fid### [at] artrecognitioncouk> wrote in message
news:B94B5920.415%fid### [at] artrecognitioncouk...
Dave Dunn had made some headway into creating wireframes of objects and I
believe has posted the file(s) in one of the newsgroups here. Would be worth a
look, called POV-GUI, I think. I would locate it for you but it's a cumbersome
process for me at this time.
bob h
Date: 23 Jul 2002 07:43:32
Message: <B962FF6D.1445%fidel.viegas@artrecognition.co.uk>
I'll have a look at it.
Thanks for the info.
Fidel.
in article 3d2bf188@news.povray.org, Bob H. at
per### [at] aolcom?subject=PoV-News:%20&body=Relating%20to%20POV-Ray:
wrote on 10/7/02 9:27 am:
> bob h
