POV-Ray : Newsgroups : povray.newusers : Convert Wavefront OBJect files to POV-Script Server Time
17 Nov 2026 20:53:09 EST (-0500)
  Convert Wavefront OBJect files to POV-Script (Message 1 to 11 of 11)
Subject: Convert Wavefront OBJect files to POV-Script
Date: 28 Aug 2008 05:56:55
Message: <8vscb4lo00auo1mubpu5dtt3u3jgd75cun@4ax.com>
I used to use a (simple, but effective) rendering program called
Renderise Live, but for some reason it doesn't work on Windows XP.
Hence I need to start learning POV-Script; with any luck POV-Ray will
be around for many more years.
My 3D models collection are all in Wavefront Object format (.OBJ --
probably the most stupid choice of filetype *ever*, as I can't use
them on XP unless I rename them to append a .txt extension), as that
was the only object file type I could find which the modelling program
output as text (the DXFs it created were the binary variety), and thus
the only one I could figure out so I could generate models using
programs of my own.
Is there a program to convert Wavefront .OBJ files into .pov files?
Perhaps an .svg->.pov converter would also be a good idea...
Subject: Re: Convert Wavefront OBJect files to POV-Script
Date: 28 Aug 2008 06:16:44
Message: <48b67b0c$1@news.povray.org>
"Robert Baker" <kor### [at] gmailcom> wrote in message
news:8vscb4lo00auo1mubpu5dtt3u3jgd75cun@4ax.com...
The downloadable PoseRay application converts .obj files to POV-Ray objects.
SVG is only a 2D graphics format whereas POV-Ray is 3D. The downloadable
InkScape SVG editor can save SVG files directly into POV-Ray format,
creating a series of POV-Ray prism objects to represent the 2D shapes in 3D.
Chris B
Date: 28 Aug 2008 12:59:17
Message: <q7mdb41abjto0nmhs7233ami65e2llotuo@4ax.com>
Thanks for both of those; I already have Inkscape (and it's great) but
haven't explored its possibilities very much as yet.  I must get the
other prog you mentioned.
Date: 29 Aug 2008 12:27:30
Message: <lq8gb4to0hscidm9dukt6h8dnsk390vk2l@4ax.com>
On Thu, 28 Aug 2008 10:56:50 +0100, Robert Baker <kor### [at] gmailcom> wrote:
PoseRay is a very good program for this.
http://mysite.verizon.net/sfg0000/
Regards
Date: 30 Aug 2008 03:40:05
Message: <48b8f955$1@news.povray.org>
What exactly is your problem with using *.obj files on XP?
Date: 3 Sep 2008 23:56:17
Message: <48bf5c61$1@news.povray.org>
I was going to ask the same question. I use several programs on my XP
box that both read and write .obj files. Sounds like you've got a "file
association" problem...
Date: 27 Sep 2008 18:56:16
Message: <48deba10$1@news.povray.org>
A dedicated obj -> pov converter is on my to-do list. (Pose-Ray is nice,
but I'm on Linux, and sometimes I just don't want to mess with Wine.)
No promises if/when I'll get to work on it (unless you're willing to
bribe me).
I believe Inkscape already exports to Pov. As others have mentioned, it
is a strictly 2D format, but Inkscape can be useful for generating
lathes and prisms.
William Tracy
Now we know everything there is to know about ML, except how to program!
     -- Jeffrey D. Ullman, _Elements of ML Programming_
Date: 28 Sep 2008 01:05:00
Message: <web.48df0f9c79aba58cf9a454800@news.povray.org>
> programs of my own.
assuming windows = must have a few things for pov
<web.485747fce7b65d90d361a0c10@news.povray.org>
There are many Blender models, couple of stargates in collada and lightwave
Blender loads almost everything -> exports obj
obj -> PoseRay -> povScript.
Couldnt do much til I had:
Imagemagick
Inkscape (image scanner to bezier splines)
Blender
PoseRay
Bezier editor (if previous programs have none, I dont know everything)
wrote my own SVG to POV prism/lathe, and Bezier editor.
Date: 28 Sep 2008 11:29:25
Message: <48dfa2d5$1@news.povray.org>
Inkscape is supposed to do that sort of thing.
William Tracy
The flavor of Redcode used in this guide is (mostly) the current de
facto standard, the ICWS '94 Standard Draft with pMARS 0.8 extensions.
(Sort of like the Netscape extensions to HTML... Hmm... Luckily we still
don't have a Microsoft Corewar Simulator. Maybe they think the market's
too small.)
     -- Ilmari Karonen, http://vyznev.net/corewar/guide.html
Date: 28 Sep 2008 12:02:19
Message: <sjavd4h6elb50hf7b5ro382911afse09vd@4ax.com>
On Sun, 28 Sep 2008 08:29:26 -0700, William Tracy <wtr### [at] calpolyedu> wrote:
>Luckily we still
Corewar? That's going back a bit. Memories hmm!
Regards
Date: 28 Sep 2008 22:20:00
Message: <web.48e03a9979aba58ca7a018af0@news.povray.org>
> William Tracy
> afi### [at] gmailcom -- wtr### [at] calpolyedu
> too small.)
THat is was I was getting from reading comments. Its either real hard to find or
not there in versio .41, latest version I think will run here.
