POV-Ray : Newsgroups : povray.newusers : Wave type Server Time
11 Jun 2026 18:23:55 EDT (-0400)
  Wave type (Message 1 to 6 of 6)
Subject: Wave type
Date: 8 Nov 2023 04:16:22
Message: <654b51e6$1@news.povray.org>
Hello
Is it possible to customize "wave_form" in color patterns ?
Thanks
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: Wave type
Date: 8 Nov 2023 07:00:00
Message: <web.654b77ffe2639fbb1f9dae3025979125@news.povray.org>
kurtz le pirate <kur### [at] gmailcom> wrote:
> Hello
> Thanks
Well, ... yes, but as far as I know, you can only do it in the TOK / Bald Eagle
over-complicated "write the whole thing yourself from scratch" method.
You know that you can use a function to define a pigment pattern,
pigment {function {}}
and that you can have POV-Ray convert any inbuilt pigment pattern into a
function.
function {pigment {}}
So what you do, is you take your pattern, convert it into a function, and then
use a user-defined function to modulate that 0-1 range according to the
wave_type that you implement in your function.
#declare f_Pattern = function {pigment {}}
#declare f_Wave = function {my_wave_type}
#declare WavePattern = function {f_Pattern * f_Wave}
Then you make a texture using the "average" pattern, and use the product of your
pattern function and wave function to control the rgbft values in the average
texture.
 #declare WaveModifiedPigment =
          average
          pigment_map {
                  function { WavePattern (x, y, z).red }
                  color_map {
                      [ 0 red 0 ]
                      [ 1 red 5 ]
          ... etc
Depending upon your exact needs, you _might_ need to create a special cumulative
distribution function (cdf) using a spline, and then employ importance sampling
by writing a probability density function (pdf) to return your color_map value
from the cdf for any given pattern value.  And THAt will be your actual f_Wave
function that you use in the average texture.
Hope that "helps".
- Bill
Date: 8 Nov 2023 10:27:30
Message: <654ba8e2$1@news.povray.org>
>> Hello
>> Thanks
> function.
> texture.
>   texture {
>    pigment {
>           average
>           pigment_map {
>                   color_map {
>                       [ 0 red 0 ]
>                       [ 1 red 5 ]
>           ... etc
> Hope that "helps".
> - Bill
Always there to help ;)
I've already found one method :
	user_defined {
		function { f_sinc (x)*2 } // only red
	} // end of pigment
This is a partial answer to what I wanted to do, but this method can't
be combined (at least not yet) with existing patterns.
The ideal solution (for me) would be :
	onion
	color_map { ... }
	myWaveTypeFn // for the wave
myWaveTypeFn same as standard cubic_wave, poly_wave, ...
Your (and TOK) suggestion with :
pigment { average pigment_map { [ function ...
is very good and well know.
I use it to color the plane and TOK does the same.
See previous messages about domain coloring and complex numbers.
I'll keep searching ...
Kurtz le pirate
Date: 8 Nov 2023 13:30:10
Message: <654bd3b2$1@news.povray.org>
> pigment {
> 	onion
> 	color_map { ... }
I confess I'm, unsure what you are trying to do.
The code below works today, FWIW.
Aside: One of the changes yuqk made was so that poly_wave always chains
after the other wave modifiers. Meaning you can use, for example,
'triangle_wave poly_wave 2' and the code runs both modifiers with
poly_wave always being executed last.
Bill P.
     // Sample scene. 'povray onion.pov +w800 +h800 +p +mv3.8'
     global_settings { assumed_gamma 1.0 }
     #declare VarOrthoMult =
         3.0/max(image_width/image_height,image_height/image_width);
     #declare Camera01z = camera {
         orthographic
         location <0,0,-2>
         direction z
         right VarOrthoMult*x*max(1,image_width/image_height)
         up VarOrthoMult*y*max(1,image_height/image_width)
     #declare FnOnion = function { pattern { onion triangle_wave } }
     #declare Fn = function {
         FnOnion(x,y,z) * 6.0 // = 'frequency 6'
     plane { -z 0
             function { Fn(x,y,z) }
             poly_wave 2
             // I'm using the default color map, but you can chain
             // the functions as deep as you want and each chain
             // could be a color channel in a user_defined pigment.
         finish { emission 1 }
     camera { Camera01z }
     // If you want to see linear values in the preview display
     // over gamma corrected ones, add display_gamma=1.0 to the
     // command line.
Date: 8 Nov 2023 16:45:00
Message: <web.654c014be2639fbb1f9dae3025979125@news.povray.org>
> pigment {
>  onion
>  color_map { ... }
I think this might work:
Take onion, and make it
#declare Onion = function {pigment {onion}}
Now define a user-defined wave function to apply to the domain of the original
pigment function
#declare Wave = function {sin (Onion (x, y, z)*tau)}
  Onion
  color_map { ... }
  // and now the wave function is already built into the pigment pattern
You just need to use the 0-1 values returned by your pigment pattern as the
input for your wave function.
If you're going to be using a pigment pattern that POV-Ray assigns an in-built
color_map to, then you need to override that in your original pigment function
with a user-defined color map going from black (1) to white (1).
#declare Onion = function {pigment {onion} color_map {[0 rgb 0] [1 rgb 1]}}
- BW
Date: 9 Nov 2023 06:45:35
Message: <654cc65f$1@news.povray.org>
FWIW. A better option, when all you want is a pattern's scalar value for
a function is:
#declare Onion = function {pattern {onion}}
It avoids the conversion to grey - and, of course, no worries about the
default color map.
Aside: I saw your other posts on select() and yuqk/v4 ideas, but it'll
be a bit before I can even read through them. I'm still working through
tuple / batch assignment issues. Once I manage that bit,
'local'/'global' pseudo dictionary and 'optional' issues will pop off
the debug stack.
Busy with real life later today too.
Bill P.
