Warning: non-newbies will face palm. Three times.
In my earliest POVing days, I had scene files on two different
computers, transporting them back and forth via floppy disks. Nowadays,
both sets of files are on one computer, in separate directory trees.
Over time, I have been gradually syncing the files and merging them into
one tree.
The biggest challenges have been two #include files. One of them is my
3rd generation prefab render rig, and the other is a set of common
definitions that I used to use a lot. These two files are not a concern
for me nowadays because I no longer use them for new scenes; my render
rig is in its 4th generation, and most of the common definitions have
found their way into the Object Collection. But over the years, I had
made scene-breaking changes to these files, and for the first few months
(face palm warning) I did not document these changes.
This means that, as I merge old scene files that #include these two
files, I need to re-render them to see whether they still work, and with
which #include file versions. Usually, it's just a matter of setting
version switches, but lately, I've been merging some of my oldest
scenes, deep into undocumented updates territory. I am running into
multiple levels of intractable incompatibilities.
But this latest snag--it's not even a matter of documentation, as I did
comment the reason for the change. I did not provide for backward
compatibility, because I figured the change was transparent. I
originally defined functions Sqr(), Cubed(), and Sign().[1] Then (two
face palms incoming) I decided these functions were too slow, so I
converted them to macros!
The POV-Ray 3.5 reference manual made clear that calling external macros
incurs overhead. Based on the date stamps of the scene files that call
Sqr(), I had already been using POV-Ray for nearly 3 months, plenty of
time to have learned this. Where was my head?
And in isosurfaces? The macros would resolve at parse time, and the
render halt complaining about an undeclared identifier. What possessed
me to write general-purpose macros for use in functions?
All I can think of today is that at the time I figured these functions
were simple enough that resolving them at parse time would not cause
complications. The macro overhead would be irrelevant during the render
phase. I must have gotten lucky with the first few scenes I rendered
with the change. Either that or I had been so frustrated with the
slowness of previous isosurface renders that I never bothered
re-rendering them after changing the #include file. Anyhow, I pretty
quickly stopped using these macros in new scenes. But as I re-render
the old scenes, the problem surfaces.
In the intervening years, I have decided that if a procedure can be
defined as either a macro or a function, it is better to define it as a
function. One just has to keep in mind POV-Ray's scope leakage
problems[2] when choosing names:
- Once a macro is defined, its name cannot be reused as a global or
local identifier--though it can be reused as a macro formal
parameter.
- Once a function is defined, its name cannot be reused as a global
or local identifier--though it can be reused as a macro formal
parameter.
- Once *any* identifier is declared, it cannot be reused as a macro
name.
function name.
function formal parameter. (If you were unlucky, math.inc 3.5
would bomb out for this very reason. Precautions were taken
starting with math.inc 3.6; for an example, you can take a look
at function adj_range2().)
Also, document everything!
________________________
[1] I hadn't yet discovered f_sqr() and sgn() from math.inc, but they
are tangential to the matter anyway. Fortunately, the existence of
these functions eases the conversion of the affected scenes.
[2] If you have formal computer science education, you are mortified by
these restrictions, wondering how people smart enough to create POV-Ray
could have allowed such boneheaded violations of modular practice. I am
assured that the current development team is aware of such problems.
Yes, I will keep complaining about the scope leakage until it is fixed.
> parameter.
> parameter.
> name.
> function name.
These things are good to know.
Scope can get pretty tricky and anxiety-inducing when I'm using things like
nested loops inside of macros, etc.
I'm never really sure when my identifier is valid/retains its value and when it
gets "released".
One day, when i get other things out of my hair, I'll probably try to write an
example scene that does all sorts of identifier backflips and other other
calisthenics.
I'm not sure why things like sgn() aren't in the source code. It drives me
crazy when certain things I'd consider central to the operation of a lot of code
aren't written in the source code, and need to rely on include files...
And we don't really have very many proper matrix handling macros - which I kind
of found surprising for a 3D graphics package.
Thanks for you summary of the scope issues - these should make their way into
the official documentation.
hi,
> ... One just has to keep in mind POV-Ray's scope leakage
> name.
maybe I misunderstand. the following works on alpha.10064268.unofficial
-----<snip>-----
#version 3.8;
global_settings {assumed_gamma 1}
#declare A = 0;
#undef A
#macro A(b_)
b_
#declare B = A(1);
#debug concat("B = ",str(B,0,0),"\n")
-----<snip>-----
(if you remove the '#undef', ie try to create macro with same name while the
identifier still _is_in_use_, error "expected undeclared identifier" occurs.
which is as it should be, aiui)
regards, jr.
I think you're being to hard on yourself. Pretty much anytime I go back
to something after a while, I see issues with what I did previously! :-)
POV-Ray doesn't have name spaces which would be a help with name
collisions.
That said, the major issue I see is not having a 100% reliable way to
avoid a declare in an include causing problems for a function parameter
in another include or scene. Namely something like:
// #declare _a = 1.0; // Causes issue for Fn*s
#declare Fn00 = function (_a,_b) { _a*_b }
#declare Fn01 = function (_a,_b) { _a+_b }
#declare _a = 1.0; // This OK
#macro Mc00 (_a,_b) (_a*_b) #end
#macro Mc01 (_a,_b) (_a+_b) #end
#debug concat("Fn00(3,3) = ",str(Fn00(3,3),2,3)," () \n")
#debug concat("Fn01(3,3) = ",str(Fn01(3,3),2,3)," () \n")
#debug concat("Mc00(3,3) = ",str(Mc00(3,3),2,3)," () \n")
#debug concat("Mc01(3,3) = ",str(Mc01(3,3),2,3)," () \n")
#error "\nStop before render."
We have the convention today users should not declare IDs with lower
case characters because such things might become, or might already be,
SDL keywords. What I'm thinking about for povr is adding checking such
that users cannot declare/local a name with only (lower case ascii, _)
characters. #declare _a =... would be a parsing error.
With this in place, I think it would then be the case we could always
use something like _<lowercase_parm> for all our parameters without
worry of collisions. The _ leading character would never be part of a
keyword.
Am I missing something with this planned approach?
Your post touches on other changes I've made in povr. You mentioned
math.inc defining - via our scene description language - functions
which look like fully inbuilt keywords/functions. We have also the all
lower case eval_pigment macro. I think these lower case names bad form
and I've changed them to have upper case characters in addition to
moving the functions from math.inc to functions.inc. Plus eval_pigment I
moved to math.inc, as Eval_Pigment, because it's a macro not a function.
Using your example, instead of the following in math.inc :
// Adjusts values in a specified range [Rmn, Rmx] to the specified
// range [Min, Max]
#declare adj_range2 =
function (x, y, z, _Math_INC_OMn, _Math_INC_OMx) {
((x - y)/(z - y))*(_Math_INC_OMx - _Math_INC_OMn) + _Math_INC_OMn
I have in functions.inc :
// Adjusts passed (x) values relative to a specified range [Rmn, Rmx]
// to a new value relative the specified range [Min, Max]. Normally (x)
// in input range, but it need not be.
#declare F_adj_range2 = function (x,y,z,_mn,_mx) {
((x-y)/(z-y))*(_mx-_mn)+_mn
I want to get to where f_ prefixed functions indicate inbuilt functions.
The F_ prefixed functions indicate SDL defined functions shipped in povr
include files.
Something I've stumbled over is seeing odd(...) in a scene file and
thinking it's an SDL keyword - but then not seeing any documentation for
it. I might not always be getting today's math.inc odd() in any case. At
least if I see the F_ prefix I'll know it's something defined in an
include and I need to be careful.
Bill P.
Le 2020-06-23 à 04:42, jr a écrit :
> hi,
>> name.
> -----<snip>-----
> #version 3.8;
> #declare A = 0;
> #undef A
> #macro A(b_)
> b_
> #end
> #declare B = A(1);
> -----<snip>-----
> regards, jr.
Well, that's precisely the purpose of #undef.
After the #undef statement, you are in a state similar to that of that
identifier never having even existed.
You're welcome; and egregious design flaw though they be, yes, these
booby traps should be documented.
>> name.
> -----<snip>-----
> #version 3.8;
> #declare A = 0;
> #undef A
> #macro A(b_)
> b_
> #end
> #declare B = A(1);
> -----<snip>-----
Of course you can reuse any identifier after you undefine it. But why
should you have to go through such nonsense?
No. It. Shouldn't.
What if the macro was defined in an include file written by someone
else? If the user declares A, they obviously have no need for macro A,
so why should they have to worry about whether a macro by that name
already exists?
But this is less serious an issue; the fact remains that if you declare
a *local* variable with the same name as a macro, the scene will not
parse. This means that anyone who writes a macro must make sure they do
not use local variables with the same name as a macro in any other
include file--even include files written by total strangers. The same
goes for function formal parameters.
This TOTALLY 100% defeats the purpose of local variables and formal
parameters! In order to write a robust POV include file, you must
essentially read the mind of every POVer on the planet.
This is why I complain about scope leakage. As far as I'm concerned,
the only acceptable level of scope leakage is ZERO.
> collisions.
Yes, that certainly would help! It could resolve the disagreement I
have with jr. over macro name persistence. I would love it, although it
would be massive work for the dev team. Fixing the local variable and
function formal parameter problem is far more important and should be
prioritized.
> [snip]
> keyword.
I suppose it could work. It could potentially break old scenes, but I
don't suppose many such scenes exist. None of the stock include files
have any such names that I can find.
How widespread are you recommending this convention? It would violate
the existing Object Collection namespace conventions, unless we amend
the conventions. Since Chris Bartlett disappeared, I don't know if we
even have a formal mechanism for deciding Object Collection policy.
The problem with renaming functions and macros is that it would break
older scenes. But keeping the old names alongside the new names would
solve that problem. Since these old names are already part of the
POV-Ray canon, avoiding new keywords with these names should not be a
problem.
> Plus eval_pigment I
It seems to me that Eval_Pigment() belongs in textures.inc.
> include files.
I personally use fn_ or Fn_, because I already use f_ for finishes. Of
course, I can always distinguish between my finish and inbuilt functions
by noting the one or more capital letters in my finish.
What do you think of e and o in consts.inc? I think o would be better
as O, because the Cartesian origin is normally denoted with a capital O.
But Euler's constant is always lowercase e. Would it be worth making
a keyword?
hi,
> > maybe I misunderstand. ...
> No. It. Shouldn't.
hm, we all see things differently. fwiw, the fact that POV-Ray is .. lax enough
to allow me to do:
#declare A = "foo";
#declare A = <1,2,3>;
#declare A = 0;
without complaint, makes me unhappy. I'd much prefer "stronger" typing.
> already exists?
for the same reason one would be careful when including some library header in a
C translation unit? given the absence of namespaces (as you note else-thread),
there's only careful design and documentation of .inc file, to alleviate the
situation.
need to think, and perhaps experiment, re "scope leakage".
regards, jr.
It might help obviate "reading the mind of every Povver" if some mechanism were
implemented to prepend/append some designation to the variables to make them
"unique" to any given include file.
BE23062020inc_var1 = pow(e, i*pi);
Verbose, more work, jr will have an apopleptic fit, but serves as a functional
workaround.
I would love to be able to declare identifiers using some form of formula or
concatenation - though I don't know what that would involve in the source code.
If I wanted a01 through a10, then I could write a for loop that would declare
those identifiers.
#for (N, 1, 10)
#declare Identifier ("a" + str(N)) = pow(N, 2);
(not proper syntax, but you get the _idea_)
And if THAT were possible, then at the top of the include file, one could
#declare INC_PREFIX = "BE23062020inc_";
write a small macro to prepend that to any identifier name, and then
#declare INC(a) = 0;
would be the/a way you'd handle all of the names in that file.
I know we have that parse thing (the name always escapes me) that writes to a
file and includes it back in...
Why not make them ... fully inbuilt keywords/functions?
> problem.
How much does it take to implement an alias system?
It would be ever so nice to be able to rename inbuilt keywords and functions.
> > Plus eval_pigment I
Move it into source code! :)
> > include files.
odd, even, and those sorts of functions should be in source code.
I find it ridiculous to include a whole file simply for one little function.
Or have to hunt down the include file to copy/paste the code.
> a keyword?
YES
On 6/23/20 2:25 PM, Bald Eagle wrote:
Aside: I see my response is one where the formatting got wonky. Unsure
why it happens. I've looked for offending settings in thunderbird. Maybe
particular newsgroups or original quoted text with certain characters a
trigger? I don't know. Apologies, but I don't see the issue on sending.
First, reminding everyone 'povr' is not POV-Ray. I'm combining my
responses and when I start to think about major revisions to POV-Ray's
SDL, I begin to think seriously about bindings to lua, tcl and python.
--- The _<lowercase> arguments would be the way to avoid parameter
collisions. Nothing required, but if you don't want trouble...
--- On the idea of per include file generated unique names(1) and
sorting on include order as a way to decide which 'Thing1' you want.
Includes very often include other files. It can be an unstable tangle.
The 'topological sort' can change relative to low level includes based
on adding other includes, user settings, macro settings, etc. We
struggle with these same ordering issues in c, c++ header files as jr
pointed out. Most programming languages have collision issues / scope
issues which you have to understand(2) - even with namespace support(3).
(1) - In my tcl library I have a UniqueName command which uses a global
counter to create unique names. The counter value gets used as a suffix
to create, say, 'Union_0123' and there are options for padding and
delimiting characters. This generated unique id approach works well in
languages with good 'list' (c++ std::vector) support. It has the
exposure things can blow up storage wise if you aren't careful. I've
found it easy to duplicate. Today, POV-Ray internally flattens /
duplicates - excepting meshes and a few other things. Perhaps, not a bad
approach practically - if we had the list support.
(2) - Excepting those languages which never allow re-definition/undef
within any given scope. This is the central concept used in functional
programming languages. I'm toying with povr working in this way - for
non SDL programming elements (objects, textures, macros, functions).
Namely all name collisions and undefs being illegal for classes of
things not needed for program control. Toying != knowing how. :-)
(3) - Most namespace languages to which I've been exposed support a
'using <namespace>::min' sort of declaration. These often get used -
because people don't like to type - but, allowing the shorthand can
weaken the namespace protections.
--- On jr's point about no type checking. I think we are not too
exposed. While there is no strict up front type checking, it looks to me
like the parser tracks the current id types so you cannot incorrectly
use the wrong type due a bad/unfortunate assignment somewhere.
--- On making the lower case named functions in math.inc inbuilt. I
might with some/all. I'm ever refining. Everything takes time and nearly
always more than I first imagine. Step one for me was just getting clear
what they really were and moving them to functions.inc where I've
already slowly been changing f_agate and similar wrappers to inbuilt
functions.
--- On eval_pigment / Eval_Pigment (and alias capability). I've never
liked eval_pigment! It's not inbuilt, but we talk about it like it is.
The functionality is already inbuilt. It's this:
#include "strings.inc"
#declare Vec = <1,2,3>; // *** ***
#declare FnPig00 = function { pigment { rgb <0,1,0,0.2,0.3> } }
#declare Rslt = FnPig00(Vec.x,Vec.y,Vec.z);
#debug concat(" ",CRGBFTStr(Rslt,2,2),"\n")
The problem with things like eval_pigment and alias capability is they
hide the actual code/functionality mostly on the argument of less
typing(4). If you want to type less, add hot key sequences to your
editor to insert code templates. There's a place for the ability to
alias or redefine inbuilt functionality in a language, but it should not
be generally used. It makes things harder to learn and harder to debug.
I was once handed code to debug where the user had, almost completely,
redefined the actual input language with aliases.
I cannot add Eval_Pigment to texture.inc. The only include files
currently packaged with povr are:
arraycoupleddf3s.inc functions.inc rand.inc strings.inc
arrays.inc math.inc shapes.inc transforms.inc
My povr approach is includes will be in their own code repository.
Except rarely where what's in the include is essential to core
functionality. I've moved Eval_Pigment to math.inc for now as core
functionality, but it's on my 'maybe it should just go away' list.
(4) - And, yep. I don't like the DBL, SNGL in our source code since
v1.0. Or the PRECISE_FLOAT Christoph asked me to add to a pull request
years back which then never got adopted. PRECISE_FLOAT now needs to be
yanked at some point from povr and I'd like to drop DBL and SNGL too.
Today you can find the bare 'foat/double' declarations in the source
code depending on who wrote what. This makes it unlikely we can really
ever change DBL to be anything but double, for example. Certainly not
without a lot of type conversions even if, by some chance, everything
works correctly.
--- On additional lower case constants becoming in-built. I'm not
opposed so long as they are very common. V38 added tau.
Bill P.
hi,
so, it is late and I had too much coffee, probably.. :-)
how about replacing the SDL, wholesale?!
not knowing the codebase[*], but if the "SDL" was simply a (Tcl) "safe
interpreter", with all the SDL language constructs as commands, then we could
write something like:
set version 3.8
array set global_settings {
assumed_gamma 1
light_source {-1 0 -1 10e5} {color {1 1 1} parallel}
[*] assuming that the source except 'frontend' and 'parser' stuff would be
(relatively) unaffected.
added, potential, incentives: storing the distribution .inc files,
pre-processed, in a Sqlite db; using a zip VFS for managing/distributing
projects with many files; "reflected channel" to read compressed .inc files (for
large meshes, or Hilbert curves :-)).
flights of fancy..
> (1) ... if we had the list support.
would be built in. ;-)
a typical "Problem Exists Between Chair And Keyboard" problem.
sure, I just think that, just like for regular arrays, when an identifier has
been "cast" to type A, a subsequent assigning of type B should output a warning
(preferably cause an error). because, in all likelihood, it'll be a typo or
logic error.
naive question. calling the macro returns the colour in pigment at given point.
but what good is that information, given that lighting is not part of the
process?
regards, jr.
Too much _something.
WTH is "too much coffee?" :P
That has its merits, and may be a method of addressing all of the double/single
issues in the process...
> logic error.
Could be. But I like the flexibility afforded by re-casting things on the fly.
Learning good coding practices aside, allowing scenes to WORK (newbies to
POV-Ray in mind) is something we should encourage.
Issue warnings and suggestions - but full stop halts of parsing can be a real
bummer.
I like the capability, but I agree with the obfuscation. I've learned SO much
from WP and the do-it-from-scratch ShaderToy community. Perhaps eval pigment
should be an example scene illustrating how to write functions that process
patterns.
But also, given that we often use it with things like ("large") images in
image_pattern, I'd like to see a speed improvement by moving something like that
to source, so that an array of RGB values can be accessed and acted upon
speedily, via compiled code.
> process?
Because you're not trying to jump ahead in time beyond when the lighting and
ambient occlusion get applied. You're looking to inspect the "color
composition" of the base object.
perhaps for pattern purposes.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.52ede41cd6fcc84f7a3e03fe0@news.povray.org%3E/?mtop=391443&m
off=7
http://news.povray.org/povray.binaries.images/message/%3C3b8946fd%40news.povray.org%3E/#%3C3b8946fd%40news.povray.org%3
E
http://news.povray.org/povray.binaries.images/thread/%3C5078802b%40news.povray.org%3E/
or for use as a map to place objects
http://www.povcomp.com/entries/124.php
http://news.povray.org/povray.binaries.images/message/%3C409135b4%40news.povray.org%3E/
Similar questions have been raised:
http://news.povray.org/povray.general/thread/%3C5be81e8e%241%40news.povray.org%3E/
If you want lighting, you can render, and then use eval pigment on the rendered
image, which obviously has the lighting effects in the final computation of the
pixel color value.
hi,
</grin>
> > ... because, in all likelihood, it'll be a typo or logic error.
> bummer.
the flip side is, every such "flexibility" comes, somewhere down the line, at
some cost. for instance, allowing:
#declare A = "foo";
gives flexibility, but also means that (automatically) optimising code has
become too costly (in time), if not impossible altogether.
> Similar questions have been raised: ...
interesting thread, thanks.
regards, jr.
Suppose the short answer is it's harder than it looks... And I agree
with Bald Eagle about there never being enough coffee. When did I last
drink water, straight... :-)
I have a somewhat complete set of tcl wrappers for POV-Ray 'SDL'
creation which I use about as often as POV-Ray's SDL itself when
creating scenes. It's an effort started as a small limited utility which
grew into something to explore what a tcl scene description language
might be like. It's an experiment so approaches drift and change. Some
parts are now quite old/dated.
There are a good many subtle things POV-Ray's language (the parser) does
to help us code that are not easy to replicate even supposing one knows
what they all are... I guarantee I've still got lots of bugs in this
aspect of my wrapping.
With respect to actual bindings, the source code is better partitioned
than it was - thanks mostly to Christoph. Still, any bindings reasonably
complete are a ways off from doable in my opinion. This doesn't mean
it's not possible to create particular bindings today. Somewhere I have
an experiment where I was binding particular shape functions for testing
purposes. A kind of tcl unit test, but it's work since gone cold.
The aim with what I have is that every scene entity is a definable item
with an ID. POV-Ray started with this approach and then dropped this
concept when certain features were added - radiosity, warps, etc. - over
time. Not sure of all the whys. With define-ability in place you can
define RadiosityQuick and RadiosityFinal for example and then pick in
the 'SDL/Tcl' which to use by name.
The start of a scene with my wrappers looks like:
set FID "FIDmain"
DefVersion Version $FID "3.8" -unofficial povr
DefGlobalSettings Global00 $FID -assumed_gamma 1.0
DefBackground Background00 $FID -color Grey50
DefLight Light00 $FID -location 50.0,150.0,-250.0 -color White
#... ending with:
Scene tmp.pov $FID -i Version -i Background00 -i Global00
-i Camera00 -i Light00
Every command has inbuilt help; fairly extensive checking; most have
inbuilt examples which can be used for testing and some have specific
test scenes too. Where you see -color the color definition is created on
the fly when not already done from a large library of color names. What
gets included in any particular scene/include file is based on
dependencies from the -i, -d and -c Scene flags.
Anyway. Details not that important. The point is I've been playing with
a wrapper for a long time (10 years on and off now) - and while
extensive, it's not complete. Parts of it I look at today and want to
rework, but where it's mostly working, I leave it. It's an experiment.
It's not quite what you posted example wise, but I do sometimes wonder
how far one might get creating a tcl intepreter supporting POV-Ray's
commands as is. Meaning, aiming more for a parser replacement without
trying to address existing shortcomings from the start.
Bill P.
> #declare A = "foo";
I don't know how it gets optimized, or why allowing recasting would break that.
If I can envision a macro that checks if an identifier that I'm trying to use is
defined - and if it is, then first I undefine it, and then proceed as usual -
then I would imagine that such a thing could be done in C / c++.
It would be very nice indeed if we had a way in SDL (or povr) to determine the
type of an identifier. This would be _extremely_ useful when importing data
with #read and probably other cases as well.
As much as I like the programming aspect of POV-Ray, it is of course, a
raytracer, and the point is to make renders, not pedantically ram "best coding
practices" down some newbie doodler's throat.
At that point, perfect becomes the mortal enemy of good, and we lose a lot of
otherwise new USERS - which POV-Ray will die without. Having recently been
thrust into coding the Arduino, which is supposed to be designed for "beginners"
and kids - dealing with all of the esoteric BS involved with strings and serial
input, buffers, types, etc --- it's a REAL PITA to even perform otherwise simple
tasks. And I'll bet some people simply give up out of frustration.
Do we really want to repel people with an even steeper learning curve?
I mean, I see us stuck between accessibility, speed, and accuracy.
And the multithreaded source code has already become a vast, organically
interwoven behemoth. It's hard to say what the best route to take is.
> works correctly.
Except, that is not why they are there: DBL is in the source code
because there was a time when you could not depend on "double" actually
doing what you wanted it to do. A time when certain CPUs had 80 bit
floating point numbers, and other odd things with software emulated
floating-point. In this world it was essentially that the floating-point
representation could be changed. These days are long over, but the code
just happens to be so old that it still has these leftovers.
Thorsten
hi,
thanks for giving me/us some insight in to your "personal" tools.
on parser replacement, I guess that's what I meant by a "safe" interpreter
pre-loaded with commands; the example was just off the top the head. in fact,
had I thought ahead, I'd written:
set version 3.8
include colors.inc
array set global_settings {...}
light_source location {-1 1 -1 10e5} color white mods {parallel shadowless}
ie use 'dict' style lists as arguments, throughout.
anyway, personally, I look forward to more Tcl .. influence on development.
(re lists. I think a distribution .inc file implementing an i/f similar to Tcl
lists would (could?) be sufficient/"good enough")
regards, jr.
>> works correctly.
Yes, thanks. A good point.
It's easy to forget while playing with code today that those who created
POV-Ray were working in a much tougher, unstable environment. Plus we
now have ready access to so much more information - Wikipedia, papers,
on line code, etc.
Bill P.
> on line code, etc.
Ah, the same things existed back then. They were called books ;-)
Thorsten
This is an area where I've harbored suspicions and trepidation, due to
subconscious knowledge gathered from reading the newsgroups and docs over the
past years.
Jr and I have recently been working on some code, and while implementing /
rewriting a macro, some recursion was introduced, and a variable identifier was
passed back into the macro as an argument. Debugging hilarity ensued.
If I understand it all correctly:
When you #declare variable N to have some value, and then use N as the
"temporary" variable name of what gets passed into the macro, and then use
#local to declare N's new in-macro / in-loop value .... the global / higher
level value of N gets redeclared.
So apparently "POV SDL apparently makes no distinction between passing-by-value
and passing-by-reference, as other languages do."
Or maybe I have that wrong somehow - because reading the docs seems to
contradict that assertion:
2.2.2.2.3 Identifier Name Collisions
http://www.povray.org/documentation/view/3.6.1/237/
Perhaps we can have some more educated and astute (than I am) commentary on
this?
This goes back to a point I've made many times. Documentation is fine - but
code examples give you something that is undeniable and that you have far less
likelihood of misunderstanding.
THIS works (as expected intended):
THIS does not: (because...)
THESE are a few tricky examples....:
Now here's the interesting part - which I had NO IDEA was even a thing:
"turns out, there's a (documented *) way to force POV-Ray to always treat a
macro argument as pass-by-value. Add a '+' in front of the identifier name and
voila, POV-Ray is not "not allowed" to pass-by-reference because we're not using
an identifier, but an expression.
so:
A(+N)
will leave N alone."
http://www.povray.org/documentation/view/3.6.1/243/
* "Consider these examples.
#declare Value=5.0;
MyMacro(Value) //MyMacro can change the value of Value but...
MyMacro(+Value) //This version and the rest are not lone
MyMacro(Value+0.0) // identifiers. They are float expressions
MyMacro(Value*1.0) // which cannot be changed.
Although all four invocations of MyMacro are passed the value 5.0, only the
first may modify the value of the identifier."
> past years.
Ah, yes, I've run across this before. Take a look at macro CH2RGB() in
colors.inc. The parameter HH used to be H before I blundered into the
pass-by-reference trap and my scene file fell into an infinite loop.
Thanks to Jerome for figuring out the problem, and to whoever fixed it
in time for the POV-Ray 3.7 release.
I ran across it again in Lightsys IV. (That bug was also fixed in 2012.)
Which area are you concerned about, scope leakage, or accidental
pass-by-reference?
I would say that it does, but the distinction is not explicit; the
distinction manifests in how you express the argument, as you have
discovered below.
> [snip]
> so:
> A(+N)
> [snip]
I have no problem with this. At the *very* worst, it's a "I don't like
the way this works so it must be a bug," but I won't even go that far.
While pass-by-reference is dangerous if misused, it is still an
important tool, and making POV-Ray strictly pass-by-value would
compromise its flexibility. C can be strictly pass-by-value it because
one can pass an address to effect pass-by-reference.
While I admit it would be nice for POV-Ray to have an explicit
distinction between pass-by-value and pass-by-reference, I would give it
a low priority. POV-Ray's implicit distinction is clearly defined and,
as you have noted, well documented, confusing though it may be. As long
as you are careful with your coding, it is not a problem.
Scope leakage is a different matter.
> > past years.
> pass-by-reference?
Scope leakage.
Pass-by method is fine so long as it's stable and reliable and constant.
Not knowing what scope I'm working in - that can be a real issue.
I'll have to think about the permutations and write a pov and inc file to see
how I can try to either break or retain the scope of a given variable between
the two files, and with loops and macros throw into each as well.
>> created POV-Ray were working in a much tougher, unstable environment.
>> Plus we now have ready access to so much more information - Wikipedia,
>> papers, on line code, etc.
And we can call 911-COMPU$ERVE :)
http://weblog.mixart-myrys.org/?post/2021/01/Laissez-nous-exister-%21
Am 23.06.2020 um 19:25 schrieb Cousin Ricky:
>> keyword.
Been there. Done that.
Curesed a lot.
Look harder.
`functions.inc` is what made me put the idea on the back burner.
Am 24.06.2020 um 19:53 schrieb William F Pokorny:
I'm trying to jog my memory here to recall what that PRECISE_FLOAT was
all about, but for the love of it I can't find no reference to it,
except mentions by you yourself: One in 2019-02-17 in povray.beta-test
where you posted a snippet apparently from a custom
`polynomialsolver.cpp` where it appears in a comment, and one in a pull
request from LeForgeron, titled "fix for FS324, regression on triangle"
(pull request #358), where you mentioned "the new PRECISE_FLOAT compile
hook" on 2019-06-06.
Can you help me out which pull request of yours that would have been,
for which I suggested the use of PRECISE_FLOAT?
The Interwebkraken knows nothing else about it, GitHub can't seem to dig
it up, and even in all my dozen unpublished half-finished branches that
spun off at different times in history and still reside on my computer,
none of them seems to contain the character sequence "PRECISE_FLOAT".
Is there a publicly accessible repo for your povr branch? Seeing where
you're using the thing might bring my memory back up to speed.
Related to selective use of long doubles where the hardware supports
80/96 bits or more.
There is today no value to you or the POV-Ray code mainstream to dig
into this. It's my code base stuck with something once thought might be
of value which - knowing what I know today - isn't. It doesn't hurt
anything other than my code's esthetics to have it sitting in there. It
just bugs me that it is there.
Bill P.
>>> be, SDL keywords. What I'm thinking about for povr is adding checking
>>> such that users cannot declare/local a name with only (lower case
>>> ascii, _) characters. #declare _a =... would be a parsing error.
>>> keyword.
> Curesed a lot.
> Look harder.
Yes, there's that and more for complications. I've had some success with
it and it's how I've been running day to day for near a year now(1).
Twiddle with the hacked in code now and again as I pick up some detail -
recently performance impacts doing millions of calls to macros. Made it
better, but, thinking now even when compiled in there should perhaps be
a run time switch - but given how our macros work even simple that would
be seen performance wise in the worst cases.
Today, I'd say it'll stay in as a configure option for sure, but we'll see.
Bill P.
(1) - It lines up with my coding style/aim where it won't with all.
