POV-Ray : Newsgroups : povray.newusers : Any help in colors and java convertions ? Server Time
12 Jun 2026 07:23:34 EDT (-0400)
  Any help in colors and java convertions ? (Message 1 to 6 of 6)
Subject: Any help in colors and java convertions ?
Date: 28 Sep 2019 11:35:42
Message: <5d8f7dce$1@news.povray.org>
Hello,
I'm trying to make pictures of the mandelbrot set. I found several
examples on the web but I have a problem to adapt the sources.
Signifiant part of Java code building colors table :
import java.awt.Color;
int max = 1000;
int[] colors = new int[max];
for (int i = 0; i<max; i++) {
   colors[i] = Color.HSBtoRGB(i/256f, 1, i/(i+8f));
Displaying "colors" table give :
    0 : 0.000000 0.000000 0.000000
    1 : 0.109804 0.003922 0.000000
    2 : 0.200000 0.007843 0.000000
    3 : 0.274510 0.019608 0.000000
    4 : 0.333333 0.031373 0.000000
    5 : 0.384314 0.043137 0.000000
    6 : 0.427451 0.058824 0.000000
    7 : 0.466667 0.078431 0.000000
    8 : 0.501961 0.094118 0.000000
Trying to do in POVRay :
#declare Max = 1000;
#declare ColorsArray = array[Max];
#declare i=0;
#while(i<Max)
   #declare ColorsArray[i] = CHSL2RGB(<i/256, 1, i/(i+8)>);
   #declare i=i+1;
"ColorsArray" give :
    1 : 0.222222 0.003704 0.000000
    2 : 0.400000 0.013333 0.000000
    3 : 0.545455 0.027273 0.000000
    4 : 0.666667 0.044444 0.000000
    5 : 0.769231 0.064103 0.000000
    6 : 0.857143 0.085714 0.000000
    7 : 0.933333 0.108889 0.000000
    8 : 1.000000 0.133333 0.000000
he result is very different and, of course, the image does
not give the same thing... iI suspect the value 'hue' passed to the
macro, but after several attempts I can't do it (i/360, i*360/max,...)
A little help would be welcome :)
Refs :
* Page for Java source - Let’s draw the Mandelbrot set!
<http://jonisalonen.com/2013/lets-draw-the-mandelbrot-set/>
* Page for online java execution if you want to test code...
<https://www.tutorialspoint.com/compile_java_online.php>
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: Any help in colors and java convertions ?
Date: 28 Sep 2019 16:35:00
Message: <web.5d8fc2e7ad658b704eec112d0@news.povray.org>
Looks like the numbers in the java are hexadecimal, so 256f = 9583 and 8f is
143.
The color map will go from _0 to 1_, so you'd need i/1000, and since HSL goes
from 0 to 360, i'd have _i_ run from 0 to i*(360/1000)
Not sure why they use i+143 as a divisor, but you can fiddle with that as well.
You'll need to go up to and not including ColorsArray[Max-1], correct?
(I never use #while, so I'm assuming if you get no errors, that i<Max gives you
that.)
Maybe check out:
https://www.youtube.com/watch?v=kY7liQVPQSc
for more inspiration.
Date: 29 Sep 2019 04:25:55
Message: <5d906a93$1@news.povray.org>
> 143.
I'll try it with this... and playing with 0x08 :)
> that.)
Array and index is not a problem.
> Maybe check out:
Really interesting link.
Thanks
Kurtz le pirate
Date: 29 Sep 2019 12:17:29
Message: <5d90d919$1@news.povray.org>
Le 28/09/2019 à 17:35, kurtz le pirate a écrit :
> Hello,
> int max = 1000;
Beware, HSBtoRGB truncate the H part to keep only the part after the
decimal point, multiply it by 360 to get the Hue.
> #declare i=0;
> #while(i<Max)
>   #declare i=i+1;
> #end
for Hue, the macro expect something between 0 to 360, so adaptation
would be :
CHSL2RGB( < 360*i/256, 1, i/(i+8) > )
Date: 29 Sep 2019 12:25:14
Message: <5d90daea$1@news.povray.org>
> 143.
Sorry to disappoint you, but 256f is notation for a literal float for
256. (bad bad Java !)
Due to division rules, it is important that to get a float, at least one
argument of the / is a float (i.e. int/int gives an integer, which is a
bad idea for hue in HSBtoRGB ).
https://stackoverflow.com/questions/41289696/floating-point-literal-floating-literal-double-literal/41289715
Date: 30 Sep 2019 12:57:14
Message: <5d9233ea$1@news.povray.org>
> would be :
hum... < 360*i/Max, 1, i/(i+8) > ?
Kurtz le pirate
