Some tests with media.
Whit this code :
hollow
pigment { rgbt 1 }
interior {
media {
emission 1.0
density {
spherical
density_map {
[ 0.00 rgb <0.39607808, 0.45490193, 0.97254896> ] // exterior
[ 0.25 rgb <0.54705858, 0.59117645, 0.97941172> ]
[ 0.50 rgb <0.69803905, 0.72745097, 0.98627448> ]
[ 0.75 rgb <0.84901953, 0.86372548, 0.99313724> ]
[ 1.00 rgb <1.00000000, 1.00000000, 1.00000000> ]
1) : images are same whit or without step 0.25,0.50,0.75 in density_map.
Why ?
2) : here, spherical pattern is use for density. is it possible to use
other thing like gausssian curve for exemple. More generaly, how to
change pattern with f(x,y,z) for density pattern.
Thanks
Kurtz le pirate
Compagnie de la Banquise
> Whit this code :
> hollow
> pigment { rgbt 1 }
> interior {
> media {
> emission 1.0
> density {
> spherical
> density_map {
> Why ?
Have you tried more contrasting colours? I do that to check how the
pattern changes. Also be aware that in a density pattern colours are
interpreted as grey tints.
You can use any pattern you like and also warp. See for example my
sunset media in p.b.i. (there is an example there).
kurtz le pirate <kur### [at] gmail com> wrote:
I'm not sure where the media and camera is in the scene, nor the scale. I'd
either do a small separate test scene with your spherical pattern and color map,
or make a few temporary drastic changes to your scene to see "what gives"
I would guess it would just be something like this:
> density {
function (x, y, z) YourEquations.......
The docs have an "example" in the gradient pattern section.
" A more general solution is to use function{abs(x)} as a pattern instead of
gradient x and similar for gradient y and gradient z."
the complete scene :
// --- start ----------------------------------------------------------
global_settings {
assumed_gamma 1.80
max_trace_level 10
location <10,0,0>
up y
look_at <0, 0, 0>
angle 36
light_source {
<1000,0,0>
color White
background {
color White*0
#declare radiusObject = 2.0;
#declare useSphere = true;
#declare displayEdge = false;
#if (useSphere)
sphere {
0, radiusObject
#else
cylinder {
<0,0,0>, <2,0,0>, radiusObject
hollow
pigment { rgbt 1 }
interior {
media {
emission 1.0
density {
spherical
density_map {
#if (displayEdge)
torus {
radiusObject, 0.01
pigment { color Red }
finish { ambient 0 emission 0.40 diffuse 0.60 }
rotate 90*z
// --- end-------------------------------------------------------------
Kurtz le pirate
grey tints... interesting.
great exemples with 'standard' patterns.
I have difficulty understanding the relationship between the value of
the pattern and the value of the function and how to write pattern
function for Povray.
Classic equation for Gauss curve is :
x^2 z^2
2.a^2 2.b^2
y = A.e
Povray documentation sample
(http://www.povray.org/documentation/view/3.6.1/378/) say :
#declare Foo = function { x + y + z}
function { Foo(x, y, z) }
[PIGMENT_MODIFIERS...]
So, #declare f_gauss = function { ? }
Thanks for your help.
Kurtz le pirate
Am 24.07.2016 um 10:19 schrieb kurtz le pirate:
> density_map {
> Why ?
Because those steps are just a linear interpolation of the values at
0.00 and 1.00? ;)
If you really want steps, you'll need to specify two colour values for
one and the same parameter values, e.g.:
density_map {
[ 0.25 rgb <0.39607808, 0.45490193, 0.97254896> ]
[ 0.50 rgb <0.54705858, 0.59117645, 0.97941172> ]
[ 0.75 rgb <0.69803905, 0.72745097, 0.98627448> ]
[ 1.00 rgb <0.84901953, 0.86372548, 0.99313724> ]
Look up "function pattern" (not to be confused with "pattern function").
Am 24.07.2016 um 12:50 schrieb Thomas de Groot:
Actually, no, they're not. They do modify the media's effective colour.
It CAN get quite confusing.
I've actually spent most of last night and all of this morning doing just that.
I'd take a look at the isosurface tutorial in the documentation, as well as Mike
Williams' excellent and comprehensive tutorial:
http://www.econym.demon.co.uk/isotut/
and Friedrich Lohmueller's extensive and indispensable site:
http://www.f-lohmueller.de/pov_tut/addon/00_Basic_Templates/40_Isosurfaces_basic_functions/__index.htm
> x^2 z^2
> 2.a^2 2.b^2
> y = A.e
Pardon my ignorance, but what is e, what is A, and what is your "dot notation" -
does that signify multiplication?
If you plan on doing a lot of mathematical visualization to work things out, I
keep running into this during my web searches on various topics and it looks to
be quite interesting:
http://euler-math-toolbox.de/Programs/03%20-%20Povray%20in%20Euler.html
It would be nice to supplement the docs with some scene files showing how some
of the more common as well as more complex and interesting 3D-plots can be
implemented in POV-Ray.
Add some trace(), eval_pigment(), and a few other tricks, and I'm sure there's
all sorts of fun to be had expanding on:
http://www.cescg.org/CESCG-2001/DBezak/page8.html
> x^2 z^2
> 2.a^2 2.b^2
> y = A.e
Based on:
https://en.wikipedia.org/wiki/Gaussian_function#Two-dimensional_Gaussian_function
my HSV color map:
http://news.povray.org/povray.binaries.scene-files/message/%3Cweb.56e1ce6a2f1b67735e7df57c0%40news.povray.org%3E/#%3Cwe
try this:
#declare X0 = 0;
#declare Z0 = 0;
#declare A = 1;
#declare a = 0.5;
#declare b = 0;
#declare c = 0.5;
#declare Gaussian = function {y - A * exp( -( a*pow((x-X0),2) -
2*b*(x-X0)*(z-Z0) + c*pow((z-Z0),2) ) ) }
isosurface{ //------------------------- "sombrero"
function {Gaussian (x, y, z)}
open
threshold 0
contained_by{box{<-10, -1, -10>, <10, 1, 10>}}
texture{
pigment{ TempGradient scale <1, 1.1, 1>}
//normal { ripples 0.5 scale 0.125}
//finish { phong 1}
translate <0, -0.1, 0>
} // end of texture
scale <1, 5, 1>
rotate <0,0,0>
translate <0, 0, 0>
} // end of isosurface ----------------
Yes, but are the 'colours' used /inside/ the density statements not read
as grey tints? That is what I have understood (which doesn't mean
anything of course). ;-)
I looked that up and was put back right on my feet again. I must have an
alternate universe documentation file in my head... :-)
That's what I thought. That it averaged the colour values.
Where about in the documentation. Do you have a reference?
Regards
Am 25.07.2016 um 10:32 schrieb Stephen:
It is neither a grey value, nor a plain average.
I suspect your misconceptions may have their roots somewhere in the fact
that there are two knobs available to introduce colour to media: The
`emission`, `scattering` or `absorption` statement, respectively, and
the `density` statement.
And it is?
I'm thinking of the value that the `density` statement passes to the
media statement. Which it gets from the df3 file.
Regards
In the media section [3.4.8.4.2 Density with color_map]. In the wiki
that probably is at a different paragraph number.
Like you, was under the impression that colour values were averaged and
I don't remember where I got that notion from :-(
Is it possible your thinking of the hf_gray_16 output file, of which the docs
say:
height = 0.3 * red + 0.59 * green + 0.11 * blue
I took a look at the documentation regarding df3 and didn't see anything
relating to this same formula, except I'm going to guess it might be used when a
df3 is put into a normal {} statement.
I sure can't say what's what about this, just thought I would mention what it
made me think of and that was the height field formula above.
But it says:
The pattern function returns a value from 0.0 to 1.0 and the value is
passed to the color map to compute what color or blend of colors is used.
When I said "averaged" I meant it in the non technical sense.
So that is what I was thinking about. That value is not a vector.
When I made colour df3's I made them using R, G & Blue filters. Then
combined them in three media statements. It was clean and simple.
Regards
> say:
It could very well be. It looks as if some thought has gone into the
formula. :)
Pause for thought. I've never considered using one in a normal
statement. I've only used them with media.
One of those things we thing we know and when you look closely. You find
you don't. :)
Regards
Am 25.07.2016 um 11:35 schrieb Stephen:
>>>>>> colour.
>>>>> read
>>>> have an
> And it is?
Just the plain colour.
Uh... no, `density` does /not/ get its value from "the df3 file". It
gets its value (which is actually a colour) from a `density_map` and
pattern.
That pattern /can/ be a df3 file, using the `density_file` pattern, but
it is just one of many options.
On 7/25/2016 4:19 PM, clipka wrote:
>> And it is?
> Uh... no, `density` does/not/ get its value from "the df3 file". It
> pattern.
> That pattern/can/ be a df3 file, using the `density_file` pattern, but
I appreciate the lesson in logic but I am not being paid to write a
spec. :-P
And thanks for the answer, btw. :)
Regards
> say:
A DF3 file is intrinsicaly gray level based. It's linearly encoded on 8,
16 or 24 bits.
If you want to have colours, you need one or both of:
A non-gray emission, absorbtion or scattering value.
A non-gray colour map associated with the density.
>>>>> colour.
>>>> read
You may get average-like or looking results when the path through the
media cross areas that have different coloration.
In emissive media, you get an additive result, and absorbing media is
subtractive.
With scattering medias, you get a mix of the two.
This is in turn combined with whatever background you may have.
