POV-Ray : Newsgroups : povray.newusers : can't i rotate a pigment? Server Time
16 Oct 2026 04:07:30 EDT (-0400)
  can't i rotate a pigment? (Message 1 to 14 of 14)
Subject: can't i rotate a pigment?
Date: 7 May 2015 04:34:48
Message: <554b23a8$1@news.povray.org>
I have a scene with
	mesh2 {
	        pigment { Tufte rotate N*y }
but the pigment does not rotate.  (Tufte is my own creation.)
Have I forgotten something?
*\\* Anton Sherwood *\\* www.bendwavy.org
Subject: Re: can't i rotate a pigment?
Date: 7 May 2015 07:42:52
Message: <554b4fbc$1@news.povray.org>
On 7-5-2015 10:34, Anton Sherwood wrote:
> I have a scene with
>      mesh2 {
There is no reason why it should not, imo. We need a bit more info
though. First of all, is the mesh2 uv_mapped? From the basic
construction of your code I suppose not, but...
Date: 7 May 2015 13:16:36
Message: <554b9df4$1@news.povray.org>
D'oh!  Tufte is made of "slope"s; one can understand that
rotating it might not work.  I'll try this:
	object {
		rotate -N*y
		pigment { Tufte }
		rotate N*y
Date: 7 May 2015 14:04:55
Message: <554ba947@news.povray.org>
On 2015-5-07 10:16, Anton Sherwood wrote:
> I'll try this:
> 	object {
> 		rotate -N*y
> 		pigment { Tufte }
> 		rotate N*y
No luck.
Date: 7 May 2015 16:11:32
Message: <554bc6f4$1@news.povray.org>
>> I'll try this:
>>     object {
>>         rotate -N*y
>>         pigment { Tufte }
>>         rotate N*y
> No luck.
Try changing the direction vector
   slope {
     < 0.500, 0.000, 0.500 >  // <- Direction
   color_map {
     [0.000 rgbft <1.000,0.000,0.000,0.000,0.000>]
     [0.534 rgbft <0.000,1.000,0.000,0.000,0.000>]
     [1.000 rgbft <0.000,0.000,1.000,0.000,0.000>]
Regards
Date: 8 May 2015 02:58:43
Message: <554c5ea3$1@news.povray.org>
>> I'll try this:
>>     object {
>>         rotate -N*y
>>         pigment { Tufte }
>>         rotate N*y
> No luck.
No surprise: You rotate /the object/ a certain value around the y-axis,
apply the pigment, rotate the object back the same value. You have not
rotated /the pigment/ itself.
However, if the pigment is a slope pattern (along y-axis I suppose) I do
not expect much to happen if you rotate it around the y-axis in any case.
Date: 8 May 2015 03:18:00
Message: <554c6328@news.povray.org>
Why not?  Generally
	object { ...
		texture { foo }
		translate ...
is not the same as
	object { ...
		translate ...
		texture { foo }
> I do not expect much to happen if you rotate it around the y-axis
> in any case.
Not even if it's built of slopes along, say, some other vector(s)?
Download 'tufte.inc.txt' (1 KB)
Date: 8 May 2015 03:19:14
Message: <554c6372$1@news.povray.org>
As there's only one object in the scene, I sidestepped the problem by
rotating the object *and* the camera while letting the pigment stay put.
Date: 8 May 2015 03:27:21
Message: <554c6559$1@news.povray.org>
> Why not?  Generally
>      object { ...
>          texture { foo }
>          translate ...
> is not the same as
>      object { ...
>          translate ...
>          texture { foo }
Hmm yes. I stand corrected for that one :-)
>> in any case.
You are tickling the limits of my knowledge ;-)  Slope is a difficult
pattern to use in my experience and I always need a lot of
experimentation to get it right.
I shall need to make a test scene to see what happens. Back soon.
Date: 8 May 2015 03:54:46
Message: <554c6bc6$1@news.povray.org>
After testing, I can confirm that it is not possible to rotate a slope
pattern, in contrast to other patterns. Even more puzzling, I can
confirm that this is true too when applying the pigment and then
rotating the object: the pigment remains unchanged and does not rotate
with the object.
I do not know if this is a bug or is intentional. If the latest case,
the documentation does not mention it while at the same time indicating
the use of Pigment Modifiers in the example.
I believe we need the voice of an expert now.
Date: 8 May 2015 04:41:05
Message: <554c76a1$1@news.povray.org>
> with the object.
And I thought that you were the expert. ;-)
My understanding of the slope pattern is that the colour (value) is
dependant on the normal of the point on the object being tested and the
direction vector. So the pigment is tied to the object's shape. To
rotate the patern, rotate the direction vector.
> The slope value at a given point is dependent on the angle between the <Direction>
vector and the normal of the surface at that point. For example:
> - When the surface normal points in the opposite direction of the <Direction> vector
(180 degrees), the slope is 0.0.
> - When the surface normal is perpendicular to the <Direction> vector (90 degrees),
the slope is 0.5.
> - When the surface normal is parallel to the <Direction> vector (0 degrees), the
slope is 1.0.
Regards
Date: 8 May 2015 07:21:55
Message: <554c9c53@news.povray.org>
>> with the object.
I am sorry to disappoint you ;-)
>> <Direction> vector and the normal of the surface at that point. For
>> example:
>> <Direction> vector (180 degrees), the slope is 0.0.
>> (90 degrees), the slope is 0.5.
>> degrees), the slope is 1.0.
Yes that is my understanding too, up to a point. What mystifies me is
when an object is patterned with slope and then rotated: why is the
pattern not following the rotation of the object? That is not correct to
my understanding.
Date: 8 May 2015 10:15:03
Message: <554cc4e7$1@news.povray.org>
You don't.
> my understanding.
It might have helped if I actually rotated the object.
Puzzling.
Try this instead.
     object {
         rotate N*y
         pigment { Tufte }
It is hard to see on the SuperEllipsoid I was using.
Regards
Date: 9 May 2015 03:29:32
Message: <554db75c$1@news.povray.org>
In summary, after a night pondering the issue, the slope pattern is
applied at world-axis level, regardless of any transformation at
local-axis level of the object. This makes slope different from the
other patterns. This is consistent with the Docs.
To reduce confusion like we have experienced now, I think that the Docs
should be adapted accordingly with an additional entry under *Note*,
explaining why basic transformations of the pattern or the object do not
work as expected.
As a solution to the initial question, I see two possibilities:
- Baking the texture using the mesh camera. See for an excellent
explanation: http://www.ignorancia.org/en/index.php?page=mesh-camera
Using a proximity pattern technique as was developed e.g. by Sam Benge
or Edouard Poor. This is not exactly the same as a slope pattern but can
come close. Personally, I prefer, and use, Edouard Poor's method. I do
not have the exact location at hand but look for the code in
povray.binaries.scene-files, under author Edouard, date 10-9-2009.
