POV-Ray : Newsgroups : povray.newusers : Possible Photon Error Server Time
17 Nov 2026 14:41:08 EST (-0500)
  Possible Photon Error (Message 1 to 4 of 4)
Subject: Possible Photon Error
Date: 2 Sep 2014 05:04:56
Message: <54058838$1@news.povray.org>
hello,
i have an issue using photons on one scene.
i get this error :
	"Possible Photon Error: Photon map for media is empty."
excerpts from the source :
#declare usePhotons = true;
global_settings {
	assumed_gamma 1.80
	max_trace_level 32
	#if (usePhotons)
		photons {
			#if (file_exists(photonFile))
				load_file photonFile
			#else
      			count 1000000
      			autostop 0
    	  		jitter 0.20
			save_file photonFile
light_source {
	p2r(30, 50, 1000,false)
	color White //Wheat // White
	#if (usePhotons)
	   photons {
			refraction on
			reflection on
	sphere {
		<0, rSphere, 0>, rSphere
		translate <xIndex,0,zIndex>*2*rSphere
		translate index*deltaY*y
		translate index*<1,0,1>*rSphere
		material { materialVerre }
		#if (usePhotons)
			photons {
				target
				refraction on
				reflection on
				collect off
who can help me find my error ?
thanks
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: Possible Photon Error
Date: 2 Sep 2014 06:18:53
Message: <5405998d@news.povray.org>
Am 02.09.2014 11:04, schrieb kurtz le pirate:
> hello,
> i get this error :
It's only a "possible" error. IIRC it means that you have some interior
media (probably in "materialVerre") and POV-Ray for some reason thinks
you would want caustics to show within the media, but finds that after
photon shooting no photons have hit the media.
Date: 3 Sep 2014 15:30:32
Message: <54076c58@news.povray.org>
Le 14-09-02 05:04, kurtz le pirate a écrit :
> hello,
> i get this error :
> global_settings {
>      assumed_gamma 1.80
>      max_trace_level 32
>      #if (usePhotons)
>          photons {
>              #else
>                   count 1000000
>                   autostop 0
>                   jitter 0.20
>              #end
>      #end
> light_source {
>      #if (usePhotons)
>         photons {
>              refraction on
>              reflection on
>      #end
>      sphere {
>          #if (usePhotons)
>              photons {
>                  target
>                  refraction on
>                  reflection on
>                  collect off
>          #end
> thanks
> Kurtz le pirate
I've found that this message can show when you save photons for later
use and there is NO media in the scene. In my case, there was fog but no
proper media.
I suspect that it can also appen if there is no media and no fog.
A little hint:
You don't need to add any photon block to your light_source unless you
want to use photons{ area_light }.
The default photons block for all light_source, except shadowless, is:
photons{ reflection on refraction on area_light off}
Also, having a photons block when photons is not activated in the
global_settings block don't have any effect. So, the
#if (usePhotons)...#end have no real use outside of the
global_settings{...} block.
Date: 6 Sep 2014 11:49:52
Message: <540b2d20$1@news.povray.org>
Le 02/09/2014 11:04, kurtz le pirate a écrit :
> hello,
> i get this error :
clipa, alain, thanks for your light :)
Kurtz le pirate
