POV-Ray : Newsgroups : povray.newusers : Does povray have a C-level library API ? Server Time
26 Nov 2025 22:10:22 EST (-0500)
  Does povray have a C-level library API ? (Message 1 to 3 of 3)
Subject: Does povray have a C-level library API ?
Date: 17 Sep 2009 19:03:32
Message: <4AB2C044.4000900@msgid.danisch.de>
is it possible to use povray's objects and tracing capabilities, but
without povrays language and parser?
What I have in mind is to write a binding for a scripting language like
Ruby to use povray objects as objects in the programming language and
e.g. write functions in a scripting language.
regards
Hadmut
Subject: Re: Does povray have a C-level library API ?
Date: 17 Sep 2009 20:00:54
Message: <4ab2cdb6@news.povray.org>
There are several answers to your question:
- No, POV-Ray does not provide a C API.
- POV-Ray is open source software, so you are free to replace the parser
with some other code to drive the engine, provided you can wrap your
head around it.
- According to POV-Ray's licensing terms, while you could hack up such a
binding for your private purposes, you may not distribute a version
including such an interface.
I reckon it will actually be a good deal easier to create POV-Ray SDL
scene files and launch POV-Ray to parse and render those. You wouldn't
be the first to do that however :-)
Date: 18 Sep 2009 15:04:49
Message: <4ab3d9d1@news.povray.org>
  Note that POV-Ray's license is bound to change at some point to be more
liberal about this.
