POV-Ray : Newsgroups : povray.newusers : Is it possible to extrude a 3D shape? Server Time
17 Nov 2026 20:42:57 EST (-0500)
  Is it possible to extrude a 3D shape? (Message 1 to 2 of 2)
Subject: Is it possible to extrude a 3D shape?
Date: 18 Mar 2009 14:45:50
Message: <49c1415e$1@news.povray.org>
Generally, is there a built-in feature in POV Ray to create a solid
object from sweeping an existing solid object along a path?
If not, is it at least possible to sweep it along a straight line?
If still not possible, maybe my special case is possible some other way.
I actually want to extrude a planar sphere-sweep. So supopose I have a
spline on the y plane, and I use sphere-sweep to turn this into a tube
lying on the y plane. Now I want to turn that tube into a "sheet" with
round edges by extruding it along the y axis. Is this possible?
Perhaps is there a way to construct an equivalent shape by using
something other than sphere-sweep?
Thanks
Timwi
Subject: Re: Is it possible to extrude a 3D shape?
Date: 18 Mar 2009 17:43:08
Message: <p$rM5GBprWwJFwZN@econym.demon.co.uk>
>way. I actually want to extrude a planar sphere-sweep. So supopose I
>have a spline on the y plane, and I use sphere-sweep to turn this into
>a tube lying on the y plane. Now I want to turn that tube into a
>"sheet" with round edges by extruding it along the y axis. Is this
>possible?
In this particular case you could make three copies of the sphere sweep.
Place one copy at y=0
Translate one copy in the y direction
Scale the third copy by a huge amount in the y direction and intersect
it with the y=0 and y=1 planes. [If it were possible to scale it by
infinity in the y direction, it would fit perfectly, but scaling by, say
1e12, will create a shape that's off by less than a millionth of a pixel
unless your original shape is huge.]
#declare D=10;
union {
   object {Sweep}
   object {Sweep translate y*D}
   intersection {
     object {Sweep scale <1,1e12,1> translate y*D/2 }
     plane {-y,0}
     plane {y,10}
   pigment {rgb 1}
Mike Williams
Gentleman of Leisure
