POV-Ray : Newsgroups : povray.newusers : Non-infinite Planes... Server Time
17 Nov 2026 21:45:10 EST (-0500)
  Non-infinite Planes... (Message 1 to 9 of 9)
Subject: Non-infinite Planes...
Date: 28 May 2007 16:28:11
Message: <465b3b5b@news.povray.org>
Anyone know how I can get a plane that is non-infinite? I tried to do an
intersection with a box and of course got everything in the box that was
below the plane. I really want a lamina...
I'm currently using a VERY narrow box but... Any help appreciated.
Thanks!
Subject: Re: Non-infinite Planes...
Date: 28 May 2007 16:39:17
Message: <465b3df5$1@news.povray.org>
That's actually probably the best solution. :-)
Otherwise, you could look into using triangles/mesh.
William Tracy
|a|f|i|s|h|i|o|n|a|d|o|@|g|m|a|i|l|.|c|o|m|
|w|t|r|a|c|y|@|c|a|l|p|o|l|y|.|e|d|u|
You know you've been raytracing too long when you can draw things
quicker in POV-Ray than you can using a pencil and paper.
Dylan Beattie
Date: 28 May 2007 16:39:20
Message: <465b3df8@news.povray.org>
"Simon" <povray@*NOSPAM*SOWare.co.uk> a écrit dans le message de news:
465b3b5b@news.povray.org...
> Thanks!
A union of 2 triangles
MArc
Date: 28 May 2007 18:06:37
Message: <465b526d$1@news.povray.org>
"Simon" <povray@*NOSPAM*SOWare.co.uk> wrote in message
news:465b3b5b@news.povray.org...
> Thanks!
Hi Simon,
It depends which infinite dimension you're not happy with and why. If a box
doesn't do what you want then it sounds like you don't want something
completely finite. You can make something that's only infinite in certain
directions by intersecting the desired number of planes.
So, the following example uses 3 planes that give a thin slice that
stretches away infinitely in the z, x and -x dimensions, but gives a crisp
edge in the foreground. I've made the top surface slightly translucent so
you can see the checkered plane beneath.
camera {location <0, 0.8,-2> look_at  <0,0,0>}
light_source { <0, 50, -30> color rgb <1,1,1>}
intersection {
  plane{y,0.01 pigment{color rgbt <1,1,1,0.3>}}
  plane{-y,0.01 pigment{checker}}
  plane{-z,0 pigment{color rgb <1,0,0>}}
Chris B.
Date: 28 May 2007 19:10:47
Message: <465b6177@news.povray.org>
IIRC infinitely thin boxes are actually allowed and render correctly.
  But I would go with a polygon or two triangles.
Date: 28 May 2007 19:55:02
Message: <web.465b6b55d3b25be25e73ab330@news.povray.org>
> Thanks!
Outside the suggestions already posted, the problem you were having is
because planes in POV are infinite, but they are not an infinite thin
surface.  Rather they have an inside and outside that extend in either
direction from the plane surface.  So any kind of intersection will get
what you did.
An alternative to use planes still would be to use the clipped_by rather
than intersection or difference, but the other suggestions are just as good
(maybe even better).
-tgq
Date: 28 May 2007 20:51:10
Message: <465b78fe$1@news.povray.org>
You could use a polygon...
polygon {
    4, // number of corners
    <0, 0>, <0, 1>, <1, 1>, <1, 0>
Polygons can take 3D vectors, but they are
touchy about being flat, it's better to make
them 2D vectors then move it where-ever
if it isn't flat to one of the standard planes.
If you need a functional planar lamina you can
use an isosurface and let the containtained_by
box be mostly flat. Something like...
isosurface { // a cylinder
   function{ sqrt(pow(x,2) + pow(z,2)) - 1 }
   contained_by { box { <-2,-0.001,-2>, <2,0,2> } }
   threshold 0
Date: 29 May 2007 06:06:53
Message: <465bfb3d@news.povray.org>
How about a disc?
Date: 4 Jun 2007 20:27:01
Message: <4664add5@news.povray.org>
Personally I use a disc, polygon, or this:
plane {
    y, 0
    clipped_by { box { <-1,-1,-1>, <1,1,1> } }
clipped_by works sort of like intersection but it makes the sides of the box
invisible.
BTW all of these shapes can cause problems if you want your shape to be
translucent, infinitely thin surfaces can mess up certain effects. This can
be fixed if it happens, but hopefully you won't run into that problem.
Tek
http://evilsuperbrain.com
> Thanks!
