POV-Ray : Newsgroups : povray.newusers : Text symbols Server Time
24 Jan 2025 03:33:11 EST (-0500)
  Text symbols (Message 1 to 4 of 4)
Subject: Text symbols
Date: 28 Jul 2006 10:43:15
Message: <44ca2283$1@news.povray.org>
I am trying to insert a copyright symbol into a string of text for an
image.  I cannot get this to work - if I copy the symbol in from word it
appears in the povray editor, but when rendered appears as a blank
space.  I've not found a font where the copyright symbol can be typed in
using the normal keys on the keyboard.  I've tried using different fonts
with no luck.  Is there a way around this?  Can a directly select a
character using it's font and hex code?  For example, the copyright
symbol is #00E3 in "symbol.ttf".
Thanx in advance
Bryan
Subject: Re: Text symbols
Date: 28 Jul 2006 11:48:17
Message: <HkAiWBA0GjyEFwIt@econym.demon.co.uk>
Have you tried setting charset utf-8 in your global settings?
The default charset is ASCII.
Mike Williams
Gentleman of Leisure
Date: 28 Jul 2006 12:05:47
Message: <44ca35db$1@news.povray.org>
That will not help at all as the character he enters won't be a valid UTF-8
character. He needs to either use \u00E3 in the string or use a UTF-8 input
file (not create-able with the POV-Ray editors currently), as explained in
the documentation.
	Thorsten, POV-Team
Date: 28 Jul 2006 15:17:42
Message: <44ca62d6$1@news.povray.org>
>>> it appears in the povray editor, but when rendered appears as a blank
>>> in using the normal keys on the keyboard.  I've tried using different
>>> fonts with no luck.  Is there a way around this?  Can a directly
>>> select a character using it's font and hex code?  For example, the
>>> copyright symbol is #00E3 in "symbol.ttf".
>> Have you tried setting charset utf-8 in your global settings? The
> UTF-8 character. He needs to either use \u00E3 in the string or use a
> UTF-8 input file (not create-able with the POV-Ray editors currently),
> as explained in the documentation.
>     Thorsten, POV-Team
The \uooE3 inside the string worked perfectly.  Thank you for your help.
Bryan
