At first, make a white ball and then make a red box, which is bigger than
the ball, in front of the ball.
If I use the command "filter" or "transmit", I could see the ball through
the box.
But the color of ball(white) seem to be redder and dimmer than its original
because the light traverse through the red box.
If I put more red boxes in front of the ball, I will not be able to see the
ball because many boxes screen the light emitted from the white ball.
How can I see the white ball even if there are many boxes between the ball
and the camera?
Thank you.
JH
Yonsei University, Department of Astronomy
Seoul, South Korea
Graduate Student, Room #703
Joo Heon Yoon in GEM
jhy### [at] galaxy yonsei ac kr
yoon nous apporta ses lumieres en ce 17/07/2006 12:05:
> the box.
> and the camera?
> Thank you.
> JH
As you add transparent box, you need to trace through more and more surfaces.
The maximum number of surfaces you can pass is set by max_trace_level, it's
default value is 5. So, with 3 box you get 2 levels for each box (front and back
face) and 1 for the sphere, making a total of 7. You thus need to set
max_trace_level 7 to be able to see the sphere, otherwize, you see black.
Add:
global_settings{ max_trace_level TraceValue} to your scene. Adjust TraceValue so
that your transparency is completely restored. The global_settings{} block can
be about anywhere in the scene, but is usualy placed near the beggining.
Keep your boss’s boss off your boss’s back.
> the box.
> and the camera?
> Thank you.
> JH
> Seoul, South Korea
absolutly untested....
but I first would try out:
The pigment-color of the box = "Clear"
The pigment-color of the sphere = white*1.2"
(to lighten the "white" of the sphere)
Thank you.
But, both methods do not work.
I put a large number of boxes in front of the ball and the maximum of the
"max_trace_level" 256. It is not enough large I think...
"Meothuru" <nomail@nomail> wrote in message
news:web.44bf14fc8936040dbc6f282e0@news.povray.org...
>> the box.
>> original
>> the
>> ball
>> and the camera?
>> Thank you.
>> JH
>> Seoul, South Korea
Subject: Re: making perfectly transparent object with color
Date: 20 Jul 2006 18:30:22
Message: <44c003fe@news.povray.org>
yoon nous apporta ses lumieres en ce 20/07/2006 11:22:
> Thank you.
Why do you want to see trough over 128 boxes?
If it's to increase the colouring, you should be better to use this:
interior{fade_color Red fade_distance 1}
If you reduce the fade_distance, the colouring will increase.
By the way, the ball (sphere) don't emit light, it's normaly lighted by a
light_source.
The only way that an object can effectively emit light, is in a radiosity scene
if the object have a non-zero ambient value.
'I had to hit him -- he was starting to make sense.'
