I've been playing with rendering various text objects with different fonts.
I used a standard (ie. from the "Insert" menu) text object, plug in my text,
then type in the font I want to try and render away. However, certain font
don't render correctly. That is, the letters are scrambled, and often
aren't in the text string I entered in the text object. I'm reasonably
certain that the font is not corrupt because I can use it in a standard word
processing program or paint tool like Print Shop or any tool that lets you
select your font.
Here's an example that works just fine:
text
ttf // font type (only TrueType format for now)
"arial.ttf", // Microsoft Windows-format TrueType font file name
"123456",
TextDepth, // the extrusion depth
CharSeparation // inter-character spacing
texture { Text_Tex }
rotate <0, -2, 0>
translate <-3, 0.3, 2>
Now, I've got quite an extensive collection of font types because I do a lot
of web development and associated graphics design. I'm always looking for
the right font for a given job. I wanted to do some 3d rendering of the
fonts I'm using for some web graphics. I'm finding that quite a few fonts
aren't working in POV-Ray quite as expected.
Is this a known problem?
- Patrick
> text, then type in the font I want to try and render away. However,
> certain font don't render correctly.
Look into, "Insert/Statements/charset", this needs to be in a global setting
statement.
Thanks, Stephen, than helped a bit. Now at least the characters that render
are the ones I expect to see. Mostly...
Some of the characters still don't render, though. For example, if I try to
render the string "abcdefg" for one font I get the 'a' through 'f', but the
'g' comes out as one of those little empty boxes. (For different fonts the
missing letter is something different. This is just an example. And this
problem does NOT happen for MOST fonts types.) Using the same font in
another tool shows the 'g' to be there as normally as all the other
characters. Also, in the Windows Font folder, if you double-click the
font's ttf file, you can see all the characters that are defined for the
font, and the 'g' is certainly one of them.
Some of the fonts I have only have definitions for the letters, some of them
only for the upper case or only the lower case letters. I'm not trying to
render in POV-Ray letters that are not defined in the font.
It still seems that there's a text/font rendering problem in POV-Ray.
- Patrick
"StephenS" <stephen@nospam> wrote in message
news:44a65900$1@news.povray.org...
> setting statement.
> Stephen
At this point some additional information would be needed.
What version of POV-Ray are you using?
Are any of the fonts you are having problems with publicly available?
Can you post a short code that illustrates the problem(in the appropriate
group).
POV-Ray version 3.6.1c.id8.win32 according to the popup window.
I believe at least some of the fonts are freely available publicly, if you
go to the right web site. I can include by attachment one or two with the
posted code, if that would help. (After, of course, I verify that I got the
font from a "free font" web site.)
Finally, what would be the appropriate group for this code posting?
- Patrick
news:44a70292$1@news.povray.org...
> group).
> Stephen
If you can point us to the correct place for the font, and the code is
short(under 20 lines), this group is fine.
If you want to attach files(font, code, picture) a binaries group would be
best, perhaps povray.binaries.scene-files.
Sorry for not replying for a while. Holiday and vacation activities keeping
me otherwise occupied.
Well, I've seen this problem with several fonts. But one that's available
free from multiple web sites is "01-01-00.ttr". I did a Google search and
it showed up all over the place.
So, I'll post below the code that shows the problem.
start code...
#version 3.6;
global_settings
assumed_gamma 1.0
//charset ascii // standard ascii (only 0 to 127 are valid)
charset utf8 // unicode
//charset sys // system specific charset
camera
location <0.0, 1.0, -6.0>
direction 1.5*z
right 4/3*x
look_at <0.0, 0.0, 6.0>
sky_sphere {pigment{ gradient y color_map { [0.0 color blue 0.6] [1.0 color
rgb 1] }}}
light_source
<0, 0, 0> // light's position (translated below)
color rgb <1, 1, 1> // light's color
translate <-30, 30, -30>
#declare Text_Tex = texture
pigment{ color rgb <0.98, 0.83, 0.58> }
normal{ dents 1.2 scale 0.01 }
finish{ phong 0 brilliance 0.7 }
#declare TextDepth = 0.22;
#declare CharSeparation = <0.06, 0, 0>;
#declare FontName = "01-01-00.TTF";
#declare xPos = -3.4;
#declare yPos = 0.4;
#declare zPos = 4.2;
#declare testString1 = "`1234567890-=";
#declare testString2 = "~!@#$%^&*()_+";
#declare testString3 = "qwertyuiop[]\\";
#declare testString4 = "QWERTYUIOP{}|";
#declare testString5 = "asdfghjkl;'";
#declare testString6 = "ASDFGHJKL:\"";
#declare testString7 = "zxcvbnm,./";
#declare testString8 = "ZXCVBNM<>?";
text
FontName, // Microsoft Windows-format TrueType font file name
testString5, // Change string number (1-8) to try different
characters.
rotate <0, -2, 0>
translate <xPos, yPos, zPos>
plane { y, 0 pigment { color rgb <0.7,0.5,0.3> } }
... end code
- Patrick
news:44a85a61$1@news.povray.org...
> Stephen
fwiw, I tried it with the suggested font and got similar problems (windows
XP)
with a test string of
#declare testStringJA = "abcdefghijklmnopqrstuvwxyz1234567890";
with charset UTF-8 I got warning messages of
File: E:!dsPOVlibjaTestFontRenderingProblem.pov Line: 67
Parse Warning: Character 103 (0x67) not found in C:WINDOWSFonts1-01-00.TTF
Parse Warning: Character 108 (0x6C) not found in C:WINDOWSFonts1-01-00.TTF
Parse Warning: Character 112 (0x70) not found in C:WINDOWSFonts1-01-00.TTF
Parse Warning: Character 113 (0x71) not found in C:WINDOWSFonts1-01-00.TTF
Parse Warning: Character 115 (0x73) not found in C:WINDOWSFonts1-01-00.TTF
if you change the charset to ascii, you get a crash. Fair enough.
Maybe Povray does not support all possible valid TTFs or maybe some of them
are invalid.. maybe you just have to do a test render of the full alphabet
to find out .. perhaps the experts can tell us.
Fontviewer from Mike Lischke at
http://www.lischke-online.de/FontViewer.php
displays that unicode font just fine, but very slowly.. also the windows
applet that displays the font is also very slow to render it.
Maybe there is something arcane about it .. some excess hinting?
Well, just to test exactly that theory, I used it in several applications to
make sure it behaved appropriately before I ever posted anything here.
I've not seen anything slow about it or the other fonts I've had the problem
with, but then I'm running a 3GHz dual core processor. The slow-down might
not be enough to notice at that speed.
- Patrick
"Mutley2003" <nomail@nomail> wrote in message
news:web.44adbda1ab1d1e6e2362b6c20@news.povray.org...
This "testing" is in essence meaningless as most applications use the
operating system provided means to display all their text. Hence, they have
no control over the rendering of any font.
However, as POV-Ray needs to ray-trace fonts, it cannot use any font drawing
any operating system supplies. Consequently, it needs to read the font file,
and then extract all the information contained therein that "regular"
applications never even see because they just the the operating system to
draw the text.
> with,
The problem with the one specific font mentioned in this thread
(01-01-00.ttf) is rather simple. It contains a total of three tables
mapping* the characters' geometry (aka glyphs) to actual character numbers
(ASCII/Unicode). Two for Unicode, of which one is defective and does indeed
lack the characters as reported. Most likely (this is a guess) your
operating system deals with the problem by searching through all other
tables to find something usable - which not only is slow, but also should
*never* be necessary for a valid font file.
Due to these problems (the font file actually has other problems, such as
incorrect size specifications for some glyphs), POV-Ray cannot render your
font. The recommended solution would be to find a font repair/editing
program and have it read the font and then output it again. Most programs
for editing font should generate the missing data, or more likely actually
remove the unnecessary and broken first Unicode character mapping table.
Thorsten, POV-Team
* For TrueType fonts, this table is commonly known as "cmap".
> .... The recommended solution would be to find a font repair/editing
What tool would you recomment for this repair process. I've always been
interested in messing around with font files, but have never had the time
nor the need to do so. I guess I will "make" the time, under the
circumstances.
I'm not really too concerned with the specific font I've mentioined for this
example. It was a free download and didn't cost me anything. There are
other fonts with similar problems, for which I've actually paid money, that
I might want to use for a project in POV-Ray. Those I will take the time
and effort to try to repair, if I can get the right tools.
Your helpful recommendations are greatly appreciated.
- Patrick
"Thorsten Froehlich" <tho### [at] trf de> wrote in message
news:44ae1f4b$1@news.povray.org...
>> to
> have
> drawing
> file,
> draw the text.
>> problem
>> with,
> indeed
> Thorsten, POV-Team
